If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 37 of 40 FirstFirst ... 273536373839 ... LastLast
Results 901 to 925 of 999
  1. #901
    Join Date
    Apr 2008
    Sydney, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: C-ARF Flash Build Thread for All Flash's being built this winter
    ORIGINAL: ricardinho
    what kind of approuch did you have with the full flap..were you low or high... also where did you have you throttle at.. i like to land a jet like a airliner.. nose slightly up using the throttle as the elevator.. drag it in... i dont like just comeing around the corner on final and chopping the throttle. sounds to me you got behind the curve a little... no air over the elevators.. try a lower flap setting until you get more comforable with landings.. if you have a big runway never hurts to come in with a little more safe airspeed...
    Will reduce flap to around 40mm, introduce crow and chop throttle 1 m off the deck. I did chop the throttle 8 m off the deck as advised by my caller! Live and learn me thinks!
    Mav
    Love my Ultra Flash Merlin 140 and F22 Raptor P140 RX Multiplex Royal Pro 16
  2. #902
    Join Date
    Jan 2007
    tampa, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    it happens we all make mistakes.. this is just what works for me.. pat
  3. #903
    Join Date
    Aug 2004
    tulsa, OK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have my flaps set at 45mm with 6 mm of crow. I also have 1-2mm of up elevator mixed in any time the gear is down. With this setting the plane seems to be pretty much in an attitude that is maybe 5 degrees above neutral and allows me to land with or without throttle. If you are hot and high you can chop the power and it will sink pretty fast but still with plenty of authority to drop the nose and obtain a proper flair when you are ready. Or you can put the nose up and throw on some throttle and drag the plane in till you are ready to chop the throttle and drop the nose. The crow seems to take care of wing rock and the plane slows down to a crawl. The plane seems to almost land itself, but I still find ways to insert my dumb thumbs into the equation from time to time.
    Oh well, if it were perfect everytime we probably would not enjoy it so much when it was right!
  4. #904
    Join Date
    Apr 2008
    Sydney, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: sailing1
    Salling,
    This will be my new set up as you describe. Makes total sense. After it bit me I felt like selling it. But when it was flying I just loved it! Back on the horse with bruised ego.
    Mav
  5. #905
    aquaskiman's Avatar
    Join Date
    Dec 2001
    Sedalia, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: sailing1
    This is what I do as well, with the up in it, if the plane climes you are going to fast and slow down tell the plane is flying a constant altitude with the nose a little high. Then you are at the right speed. George
    George
  6. #906
    Join Date
    Dec 2004
    Broken Arrow, OK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    How much rudder is everyone using. The directions call for MAX travel, just wondered what people had for that.
    Dale
  7. #907
    Join Date
    Aug 2008
    kuwait, KUWAIT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Guys,
    I will start building My Flash soon
    In fact, it's first Jet I will build it
    If there are suggestions or advice, I will accept
    Here is my setup
    Jetcat 160SX
    Pro-Lynx Retract (Al's hobbies)
    Futaba R6014HS Receiver
    Futaba 12Z Transmitter
    Smart-Fly SportReg Regulator (ideal for 50cc gas planes and small jets)
    7 Futaba S9156 Servos (ail,ele,rud,flap)
    1 Futaba S3305 for Nose
    2 2600mah Batterys
    And all What I need to build it
    S9156 Is it good servo?
    I heard there is some problems in the gear or so,Is it true??
    As for Smart-Fly SportReg Regulator Is it suitable for my equipment??
    Thanks for ALL
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1642216   Click image for larger version.
    AMA #1030514
  8. #908
    Join Date
    Aug 2008
    kuwait, KUWAIT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Guys,
    I want order (Servo Arms Made for Clevis)
    Do I order 1" or 1-1/4" ?
    Regards
    AMA #1030514
  9. #909
    Join Date
    Jun 2002
    Watford, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    20mm (3/4") is required. Even 1" is too long.
    Dw
    Motors & Rotors. JetCat, Powerbox, Intairco, Behotec, CARF-models Rep. JR Propo for ever!, Jet 1A, MAP, Airtech Germany, Jet Tronics.
  10. #910
    Wayne22's Avatar
    Join Date
    Apr 2002
    Strathcona county, AB, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The Sport Reg has worked well for me..have 2 flying in jets for a couple of years now with zero problems or concerns..I'm just in the finishing stages of #1 Flash, and hope to light a fire in it tomorrow - If I can finish off the dozens of last minute details......
    All I ask is for a chance to prove that money can\'t make me happy......
  11. #911
    dubd's Avatar
    Join Date
    Aug 2007
    Bay Area, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I had 300+ flights on my classic Flash with a SportReg, no problems. My Ultra Flash uses a TurboReg because I had one lying around.
  12. #912
    Join Date
    Aug 2008
    kuwait, KUWAIT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Wayne22 , dubd
    Thanks To answer Guys,Now I'm reassured to use SportReg
    What about S9156 Any information about it?
    Regards
    AMA #1030514
  13. #913
    phjoker's Avatar
    Join Date
    Sep 2005
    Vernon, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: meshari14
    Wayne22 , dubd
    Regards
    I have 9156's all around on mine, 75+ flights with No problems at all..
    Pete H
    Jet Central Falcon
    Jet Central Rhino
  14. #914
    Wayne22's Avatar
    Join Date
    Apr 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    well, "tomorrow" turned into two more weeks. She moved under her own power today...just a couple of glitches to work on before the first flight.
    I shoved everything as far forward as I could and looks like the balance is going to be pretty close by time the cockpit and pilot are added...
  15. #915
    dubd's Avatar
    Join Date
    Aug 2007
    Bay Area, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: meshari14
    Wayne22 , dubd
    Regards
    I am using the S9156 in a Yellow Aircraft F-15. Great servos!
  16. #916
    Join Date
    Jan 2005
    Canton, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well, CG'd my Flash last night...so 370 is the sweet spot???
    Before and after on the turbine install:
ID:	1649386   Click image for larger version.
    AMA Contest Director #7484
    Turbine Waiver #15150
    Jet Pilots Org. (JPO) District V Rep.
  17. #917
    Join Date
    Aug 2008
    kuwait, KUWAIT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks dubd
    Yesterday I received the shipment from Tower Hobbies (Servos) and today I will begin to building
    Thanks guys
    AMA #1030514
  18. #918
    Wayne22's Avatar
    Join Date
    Apr 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    It flew! it flew! IT FLEW!!!!!
    It was a bit of effort as I had moved everything forward to avoid having to add ballast weight, and it paid off.....not sure that I would do that again though..... I had wing and fuselage bags professionally made up for the two Flashes that I am working on.. They have the patterns now, so if anyone is interested, PM me and I will pass on the contact info.
    The weather was pretty crappy for a maiden flight, so the video's are pretty poor...here is a static shot....Although flyable, it is far from finished from an appearance standpoint...it is still a work in progress....
ID:	1650122   Click image for larger version.
  19. #919
    InboundLZ's Avatar
    Join Date
    Oct 2004
    Las Vegas, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Kudos on the maiden! I bet it flew great, as that's what the flash does.
    Don't sell yourself short on the finish/scheme I think it looks great!
    Dave Bottita
    Jet Cat Factory Pilot
    JR America Team Member
    Smart-Fly
  20. #920
    Wayne22's Avatar
    Join Date
    Apr 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    so far yes...it's just not finished yet...
    thanks...its funny...I'm always nervous at maiden flight time, but for this, there is no question that it would fly....
  21. #921
    PaulD's Avatar
    Join Date
    Apr 2002
    Coquitlam, B.C., CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Wayner,
    U bringing a couple of those to Princeton?
    PaulD
    If it\'\'s too LOUD - You\'\'re too OLD
    Www.wircsrc.com
    MAAC Jet Committee
  22. #922
    Wayne22's Avatar
    Join Date
    Apr 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Paul, this one is coming to Princeton...the other one is still in the box...we'll have 3 other jets though.....
  23. #923
    Ali's Avatar
    Join Date
    Apr 2002
    Northamptonshire , UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Just a quick heads up...
    For those of you using the big block turbines... Keep an eye on the inlet to turbine adapter. I had mine start to split length ways. Nothing that a bit of glass bandage couldn't take care of, and I am fully aware that its down to using too big a turbine ( Which I am probably going to be called a fool for ) but I thought I would pass the info on, as I am sure I am not the only one out there...
    Regards Al
    Al's Hobbies, Horizon Hobby, Airworld, BVM, Jet Cat, Skymaster, Rc Jet Centre,pull over, Tomahawk, C-ARF, Jet-Teng,Kingtech
  24. #924
    Mart (Ham)'s Avatar
    Join Date
    Aug 2005
    Wickford, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi guys,
    Thought I would share this video of my flash last weekend.
    http://www.youtube.com/watch?v=xxPnz...e_gdata_player
  25. #925
    Beavis's Avatar
    Join Date
    Oct 2002
    Wellesley, MA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Greetings,
    Does anybody want a brand new set of wing and stabilizer for the Classic Flash? I have one in a custom color scheme (pictured). It's never been assembled and is in perfect condition. It comes with the original C-ARF wing and stabilizer covers (not pictured), also in perfect original condition.
    Please send me a PM if interested.
    Best,
ID:	1675776   Click image for larger version.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
