Flaps with the futaba 14mz
I am unable to set the middle postion for flaps on the 14mz. With the help of end point adjustment, I can get the flap 0 and full flaps to be accurate. However, flap 1 position is unequal. Is there a method to adjust that in the 14mz? I can use offset to adjust the middle position, but that changes the end points as well.. its like a viscious circle. I am sure I am missing something, because I was able to do this very easily on my 9cap using a technique on futaba 9cap FAQpage.
thanks
thanks
RE: Flaps with the futaba 14mz
Well, put the flap stick or slider in the midlle point, i mind center, this is your flap 1 point, in this step adjust the flap manually, not with your radio to achieve the flap 1 point, then you can easely set your full flap and flap raised set up, i hope this help, take care...
If both flaps are not mechanically identical, another option is to assign each flap to 2 channels (say flap2 and flap3) and then define a mix flap->flap2 and flap->flap3 with a curve or line. By doing this, you can precisely control the position of each flaps such as they are exactly equal in all positions.
Arnaud
