DeWalt A123 Packs at Amazon
If you're interested in A123 battery packs and don't mind building them yourself, Amazon has a great deal on 8 cell DeWalt packs. You'll need the security bit set to get the pack open or else cut the screws. $56.50 delivered. I ordered one the other day. Gets you either 2 ECU + 1 RX pack or 4 Rx packs.
http://www.amazon.com/DeWalt-DC9280-...9361787&sr=1-1
Also at Tool King at $49.88 plus whatever for shipping:
http://www.toolking.com/dewalt-dc928...n-nano-battery
RE: DeWalt A123 Packs at Amazon
2300mah M1's. Cut them apart carefully and all you should have to do is add leads, balance taps (if you want) & shrink. The welded tabs take solder nicely.
I'm flying my Flash off of a single 2 cell pack from one of these DeWalt packs using 2 servo leads thru 2 switches. No blinking lights on the Spectrum rx's.
matt, they have 8 A123 2300 cells. I have cut off 4 for a AMT ECU pack and then I have two two's for the twin Rx power.
Wish I could get them at that price in the uk [&o]
Jason
Jason
We have done alot of testing with A123's as receiver packs. They WILL get out of balance if you dont balance them regularly. I use FMA 4 and 10S chargers, and the Multi 4S for balancing charges, and when I use the fromeco cube, I use a blinky at home after field charging. I had a pack with about 100 charges non balanced and it finally blew a cell, and that kicked off a bunch of testing resulting in the findings we had about balancing. They must be checked regulary or balance charged, or some sort of balance circuitry. For two packs, I just solder on a JR connector and put the signal wire on the mid voltage. Andy Low sells a 4S charge wire that matches to that.
I hope that is the question you were asking...
ORIGINAL: smitty1001
goose.... are you saying there is a blinky for A123's?
Greg
ORIGINAL: Jascat100
Anyone got a drawing of how to wire a two cell pack for balancing.
http://scriptasylum.com/rc_speed/_lipo.html
Rob.
ORIGINAL: Robrow
Here ya go...
Rob.
ORIGINAL: Jascat100
Rob.
Thanks Rob. Really useful link.
My Feedback: (10)
OH
Here is an other site that has a good deal on A123s http://holmeshobbies.com/home.php?cat=10 and here is a place to get the Blinky also. http://www.espritmodel.com/index.asp...OD&ProdID=5672
