RAM ECU and A123 Packs
I need to know if anyone is using a 2 cell A123 Pack with a RAM ECU. If you are can you please tell me what kind of performance that you get from it. How many starts between recharges, etc. I bought a 3 cell battery pack to test but was informed that the ECU would not work with a 9.9 Volt pack. Can someone please chime in and let me now if they have had good or bad results. Thanks.
patrick
patrick
RE: RAM ECU and A123 Packs
3 cell 123's are too high in voltage for the ECU built in power
supply. It will run very hot. 2 cells would be better but I
have never tried them. I use Duralite 2 cell li ion ECU
batteries on my new ECU but the RAM ecu's will not run
very well on these. Carlos of RTI and some of his friends
in Florida use 2 cell 123's and say they work fine.
