Tomahawk-Design Bae Hawk 1: 3.5
Reply
Old 06-16-2012, 06:56 AM
  #551
Carsten Groen
Carsten Groen's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Tomahawk-Design Bae Hawk 1: 3.5
I have been working like a crazy here, lots of stuff finished. Less than 3 weeks until painting (the plane will be completely finished before painting). After the paint/decoration/weathering has been done, I will receive the plane at our annual "JetCamp" here in Denmark, final assembly then in the first days, and hopefully maiden at the end of the week
Received a package (the first of two) from Ralle (tailormadedecals) with stickers etc for the plane, next box from him is with the paint
All surfaces/servos are now connected and finished, the shells over the flap hinges are also glued (using some of the nice tips from GBR jets/Marc Scully)
On the radio tray I reserved some extra space for a double valve if it becomes necessary (a seperate for the nose, and a seperate for the mains).
ID:	1772555   Click image for larger version
ID:	1772556   Click image for larger version
ID:	1772557   Click image for larger version
ID:	1772558   Click image for larger version
ID:	1772559   Click image for larger version
Carsten Groen is offline
Old 06-16-2012, 09:39 AM
  #552
c_makhija
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Man Carsten, you work fast.
Chatty.
c_makhija is offline
Old 06-18-2012, 04:36 AM
  #553
u2fast
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thought i would share some detail pics of my hawk. i burned in all the scale rivets. it really adds to the looks of this beast for me. what a pleasure she is to fly. just put the 20th flight on her this weekend. barry
ID:	1773316   Click image for larger version
ID:	1773317   Click image for larger version
ID:	1773318   Click image for larger version
ID:	1773319   Click image for larger version
ID:	1773320   Click image for larger version
u2fast is offline
Old 06-18-2012, 04:50 AM
  #554
Carsten Groen
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Very nice Barry, the rivets looks amazing!
Can you tell a little about your CG, it looks from the pictures that you don't have the detailed cockpit from Tomahawk in it ?
I would be very interested if you perhaps has the CG location, or even better the weight on the frontwheel without fuel ?
Old 06-18-2012, 04:52 AM
  #555
bcovish
bcovish's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Barry, thought I would pass this along. Scott got his electric retract problems sorted out and they worked flawless this past weekend. Many flights were put on the Hawk at Mt. Pleasant without any hiccups.
bcovish is offline
Old 06-18-2012, 02:45 PM
  #556
u2fast
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
carsten, i do have the cockpit. she just wasnt in for the pics. my cg is slightly nose heavy with no weight added. i might move the batteries around a bit. but she flies so nice, i may not.
bob, that is good news. however, mine works perfect with the air system in installed. i am going to leave her the way she is. barry
u2fast is offline
Old 06-18-2012, 03:21 PM
  #557
Carsten Groen
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice Barry
How do you attach the sides in the cockpit to the sides of the fuselage ?
If you get a chance, can you do me a favor and measure how much the frontwheel "weights" ?
Old 06-23-2012, 07:30 AM
  #558
Remco45
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Carsten,
One method is to glue a 2 mm 5 cm high balsa strip along the entire upper (out)side.
Velcro patches are then glued to the balsa and to the inside of the fuselage.
To Barry:
the right hand panel of your rear cockpit should be on the left hand side. The arched part is the throttle base.
Regards,
Remco
Remco45 is offline
Old 06-25-2012, 07:11 AM
  #559
Carsten Groen
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the tip Remco, I will do something with velcro also, makes it easy to remove again (for service etc)!!
I have now all the doors installed, I did struggle a little with the small MLG door, it is still a little "flimsy", not closing perfect on the leading and trailing edge of the door, but that will have to do for now (less than 2 weeks until painting...)
I shot a small video of the main gear working, after I did some lubing of the retract mechanisms and a very little adjustment of the bar that moves in the slot of the retract, they now come down without a loud "bang"
The doors close with a delay of 10 seconds right now, maybe that can be lowered a little, but for some reason, retracts normally takes 5 times as long to go up when flying than on the bench
How much down elevator (if any) do you use with the two settings of flaps ??
And have you changed anything with regrads to the travels in the manual
Elevator +46mm / -35mm
Rudder +/- 45 mm
Aileron +27mm / -18mm
Flaps -47mm and -75 mm
And, can anyone please let me know if they can measure the weight of the nosewheel when the plane is without fuel in the maintank ??
So far I like it [8D]
[youtube]http://www.youtube.com/watch?v=G43df_hzryI[/youtube]
Old 06-25-2012, 08:19 AM
  #560
Remco45
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Carsten,
Yes, in my opinion it's necessary to make everything removable.
I'm still building, presently installing the cockpit, and some additional details.
Will post some pictures soon.
What kind of adjustment did you make on the bar (main gear)?
Regards,
Remco
P.s.: be careful when using the weight-on-nose wheels trick to make sure in what attitude this was measured. Ten degrees up or down makes quite a difference.
Remco45 is offline
Old 06-25-2012, 08:25 AM
  #561
Carsten Groen
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Remco45
Remco, I have no restictors on the gear at the moment, Thomas (Tomahawk) recommended to use a GR-QS-4 Festo restictor (reduces flow in one direction, free flow the other direction) on the "gear down" line to reduce the "knocking" when gear is going down.
I know about the weight stuff, I think the difference would be very low at modest angles (the CG is close to the "rotating point" of the main wheels, 10 degress is only 2 % less weight)
It could be really nice to get some figures by some of the "flying guys", if at the same time they would mention how high the nosewheel is when measuring. I know from the German forum that Andreas thinks that around 850 gram is sufficient, if I put the CG where it is in the manual, I will get around 1000 gram on the nose...
Even better would ofcourse be a precise CG number from a flying model, I have a feeling that the numbers in the manual are conservative...
Old 06-26-2012, 08:49 AM
  #562
Carsten Groen
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Is it correct that there is no "hingestuff" etc with the kit for the small nosedoor, or is it just me that can't find it....
I guess a form of offset hinge is needed on this one, the SG hawk in Marc Scully buildthread is "just" hinged with some small brass hinges, but as far as I can understand, this is not possible on the THawk because the frontleg almost touches the bulkhead and the cover on the nosestrut is actually going "behind" the edge of the bulkhead/skin ?
Old 06-26-2012, 10:53 AM
  #563
Remco45
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Carsten,
Correct, you have to make this yourself.
The T-Hawk guys simply glue the small door to the nose gear, hence the "black hole" when the gear is up as the small door leaves an opening.
Regards,
Remco
Remco45 is offline
Old 06-26-2012, 10:59 AM
  #564
Carsten Groen
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Remco!
I have done this now, waiting for glue to cure...
I used two small brass hinges from Marc Scully, works very nice!
I'll post a picture when it's done
Old 07-01-2012, 06:29 PM
  #565
tobba
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Carsten - amazing building speed. Nice work!
I had some new springs and an adjuster kit turn up for the Hawk mains from Thomas last week... along with a 1.9 futura!
Havent fitted them but hopefully they will solve the problem.
Done a far bit on mine - some shots soon.
tobba is offline
Old 07-01-2012, 06:33 PM
  #566
tobba
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Remco - thanks for the info! Appreciate the effort and be in touch soon.
Thinking the Futura might be easier to drag to Germany.
tobba is offline
Old 07-02-2012, 03:29 PM
  #567
roydefiant
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Craig, what did tomahawk charge for the upgrade spring kit for the hawk mains? Do you know if they are planning to offer this to the rest of us. Thanks Roy
roydefiant is offline
Old 07-02-2012, 03:41 PM
  #568
tobba
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Not sure Roy - was about to email you a shot of the springs and adjuster. Might be best to contact Thomas. As I said I havent fitted them as yet.
tobba is offline
Old 07-02-2012, 03:47 PM
  #569
jetpilot
jetpilot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tobba,
can you post a pic for us?
curious about the adjuster.
Scott
jetpilot is offline
Old 07-03-2012, 03:43 AM
  #570
heraldoboldrin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What is this upgrade on spring guys?
heraldoboldrin is offline
Old 07-03-2012, 11:58 AM
  #571
tobba
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry my Futura and parts for the Hawk showed up and I left on Holiday for a few days.
I asked Thomas about the springs in an email a month or so ago and they just turned up with the Futura kit. Comprises of four springs, 2 soft and 2 hard and what looks like a height adjustment setup. This M5/6 bolt on a sleeve with a lock nut to adjust height.
Will photograph and post as soon as I am back on deck.
tobba is offline
Old 07-05-2012, 03:47 AM
  #572
Carsten Groen
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So the Hawk is finally finished, almost exactly 2 months since I picked it up
Had a friend visit me for a few days (Kasper Holger "CarbonCustoms"), was really nice to have one to help with the last details (the cockpit has quite some work in it!), he was also helpfull when checking CG and so [8D]
It will now go to painting, anf if all goes well, maiden in 3 weeks time
PS: I have also ordered the new main gear spring set, not yet received though
I would really like to thank all of you guys, I have had huge help from you all, Craig Abbott, Scott Marr, Remco, Marc Scully, Mark Schoeder and Maikel Butler (hope I didn't forget any!) and of course Thomas from Tomahawk Design, as well as all the other persons who have contributed to the thread about this marvoulus plane
ID:	1778785   Click image for larger version
ID:	1778786   Click image for larger version
ID:	1778787   Click image for larger version
ID:	1778788   Click image for larger version
Old 07-05-2012, 06:48 AM
  #573
jetpilot
jetpilot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wow! Carsten!! Did you leave your house? You must have set a record! Unbelievable!
Nice job! Can't wait to hear about flight reports.
Please tell me your engine choice again?
Scott
jetpilot is offline
Old 07-05-2012, 07:18 AM
  #574
schroedm
schroedm's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice going Carsten!!!
Scott - that's Stage 3 for you!! Combined with not leaving the house!!
What scheme you going for?
schroedm is offline
Old 07-05-2012, 10:40 AM
  #575
Carsten Groen
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks guys,
Scott, it's a P200SX
The scheme is the 90yrs anniversary, Ralle (tailormadedecals) has been really supportive delivering everything for the scheme, and at a very fair price!
ID:	1778933   Click image for larger version
ID:	1778934   Click image for larger version
ID:	1778935   Click image for larger version
Reply
Display Modes
