Reload this Page >
Tomahawk-Design Bae Hawk 1: 3.5
Old 07-25-2012, 01:15 AM
  #601
Carsten Groen
Carsten Groen's Avatar
Default RE: Tomahawk-Design Bae Hawk 1: 3.5
@Kasper:
You know I will always trust you my planes , but you will have to surrender the Hawk to me in a few days
@Scott,
all inputs are more than welcome
(the 6cm throw on elevator, is that measured at leading or trailing edge ?)
I assume that neutral is when the trailing edge is on the dividing line of the elevator cover ?
I have put the CG in the middle of the two numbers given by Tomahawk on the CD (between 310 and 325 mm), hope that will be ok...
It took more or less exactlly two months to finish it for painting, and yes, I have been quite busy with it, but if this thread hadn't existed, or if I had not had all the super help from you guys, it would not have been possible (at all!). So a big thank you all [8D]
The last week before Kasper got the plane for painting, he was staying here at my house for 4 days, and he helped A LOT (50 hours or so) to make the canopy/cockpit, which was a lot of work, and some things had to be figured out along the build. Luckily Kasper is a real pro builder (as well as a super painter and pilot), so I did get a lot of help with that!
@MarcS: It's your small gadgets that puts the extra touch on the install, all these little things that you perhaps could do without, but using them makes it soooo much more nice and easy !!
Old 07-25-2012, 08:20 AM
  #602
Selleri
Selleri's Avatar
Congrats mate, you'll need to bring your trailer to the field next time I come for a visit!
Old 07-25-2012, 08:23 AM
  #603
jetpilot
My Feedback: (48)
jetpilot's Avatar
Hey Carsten.
the 6cm throw is leading edge and yes the trailing edge is on the divider.
I thought this sounded like a ton of throw but I watched video of it last night and the elevator is pegged the full throw on landing holding the wheelies!
Ill go plug in a wing and get aileron throws.
Scott
Old 07-25-2012, 09:07 AM
  #604
Carsten Groen
@Sverrir,
no problem, just move your butt over here and we will go flying
@Scott, thanks a lot, I will use that as a starting point for the elevator, although it is a bit more than Tomahawk writes (+46 / -35 mm).
When seeing Victor Calvo's videos on youtube of the hawk, there is a lot of movement when landing...
How mch expo are you running on ail/ele ?
Old 07-25-2012, 11:04 AM
  #605
jetpilot
My Feedback: (48)
jetpilot's Avatar
Yea, it uses all the up on holding the nose on landing. Not needed for anything else.
Im using 40% expo.
You got me hard at work on Hawk 100 again! inspired to get going!
Scott
Old 07-25-2012, 11:12 AM
  #606
jetpilot
My Feedback: (48)
jetpilot's Avatar
watch this short video:
starts at :22 seconds
http://www.youtube.com/watch?v=PndRn...layer_embedded
watch this one at 9:30 . shows elevator pegged
http://www.youtube.com/watch?v=Bwh5D5v-nao&feature=plcp
Old 07-26-2012, 11:03 AM
  #607
Carsten Groen
@Scott, had any chance to check ail movement ?
Kasper just delivered the Hawk to me (I had to threaten him to surrender it , well almost)
The painting/weathering is super, nothing less (even my wife fell in love with the plane immediatly)!
This is not the last plane he has painted for me [8D]
ID:	1786164   Click image for larger version
Old 07-26-2012, 11:33 AM
  #608
schroedm
schroedm's Avatar
WOW - she's a big old girl Carsten!!!!
Old 07-26-2012, 11:35 AM
  #609
schroedm
schroedm's Avatar
ORIGINAL: schroedm
eeeeeeek!!! The Hawk mate, the Hawk!!!!! [8D] [8D]
Old 07-26-2012, 11:37 AM
  #610
Carsten Groen
ORIGINAL: schroedm
ORIGINAL: schroedm
You just saved that right on the line
(she smiles here behind me, so think she will not be angry with you at JetPower )
Old 07-26-2012, 09:33 PM
  #611
helicrazy06
good morning carsten and marc wich turbine do you use ? does a 18 kg should be ok? or does it need more power ?
thanks
nico
( carsten i love your painting congratulation )
Old 07-26-2012, 10:57 PM
  #612
schroedm
schroedm's Avatar
Hi Nico,
160 = will fly ok and help stay under 20kg
180 = will fly nicely and should stay under 20kg
200 = will fly superb but will be over 20kg
If you want to compete then it will need to be a 160/180 and built VERY lightly. If it is for normal flying then go for a 200 class turbine and add all the goodies you want
Rgds
Mark
Old 07-27-2012, 08:21 PM
  #613
helicrazy06
thanks for your answer Marc , i will take a 20 kg turbine .
nico
Old 07-30-2012, 11:49 PM
  #614
Carsten Groen
The Hawk has flown
All went well, despite shakin knees I used the throws from the CD, as Scott said, the elevator needs more throw, and the ailerons also. I will have to play a little with that.
Gear all worked perfect, I have adjusted the setscrew about 7 mm out from the bottom, this seems to give a perfect "sit" on the ground.
More pictures/videos etc when I get on a better network, for now just a picture of the proud owner and his plane
Thanks for all your help and support guys!
Old 07-31-2012, 12:08 AM
  #615
jetpilot
My Feedback: (48)
jetpilot's Avatar
Whoohoo!
That has to be a record!
Great job!!
I went into my building room and barely have come out because of you!!!
Stayed til 4am two days in a row!!
Trying to finish my 100!
I'm sorry I didn't get the aileron throw, but I knew it was a lot. Lots of throw and lot of expo is how I like it. Not so much throw on rudder though.
Tell us about flight.
How was weather? Any wind?
How was landing?
Your CG good?
Doors stayed closed?
Landing?
Power?
Scott
Old 07-31-2012, 12:13 AM
  #616
marc s
marc s's Avatar
Carsten well done on your maiden and superb build, glad all went well and look forward to chatting at jetpower (if your going) - be sure to say hi, I'm in the same place as last year
marcs
Old 07-31-2012, 12:28 AM
  #617
bcovish
My Feedback: (8)
bcovish's Avatar
Great job Carsten. Beautiful plane.
  #618
tobba
Carsten you are a damn legend! I'm now feeling even more like a bloody snail with mine still sitting well fixed the bench.
Congratulations mate - amazing!
Looking forward to the nuts and bolts as per Scott post.
Scott I thought i was crazy at 2 x 1.00am sessions in a row!
Well done lads - I need to finish my 1.9 Futura in the next week or so to get back to the Hawk.
cheers,
Old 07-31-2012, 06:10 AM
  #619
Carsten Groen
Thanks again guys [8D]
@Scott:
The flight went well, the plane flies very! slow . We had around 30..40 km/h wind at maybe 25 deg on the runway.
No bad tendencies, slowed it down to a crawl, the plane just gently lowered the nose and kept flying.
Landing was ok (for the first landing ) I will upload some video in a week, currently at a flyingfield for the rest of the week. It is quite noseheavy at the moment, the CG is set between 310 and 325mm as per the instructions on the CD ( it dumps the frontwheel pretty fast when I push the tail down and let it go)
As the whole flight was not that fast, the doors stayed closed all the time, if there will be any problems when going fast I still don't know, but so far it looks perfect. The gears worked perfect too (I have a single JetTronics valve only), I use a Festo restictor on the gear-down line so it doesn't slam when extending. The valve opens fully in the other direction (so the release air when doing gear-up can escape without restriction)
The plane needs a P200 in my view, it takes a lot of power when just flying around doing nothing special, I found myself above 1/2 all the time, and quite often at 3/4 or full power. When going to idle, the plane stops very nicely in the air
@MarcS: Oh yes, will be at JP again, I'll come by, and if I see you in the "brennkammer" I'll buy you a couple of beers [8D]
Old 07-31-2012, 06:21 AM
  #620
schroedm
schroedm's Avatar
Great stuff mate! See you at Jetpower.
Old 07-31-2012, 07:24 AM
  #621
F86_SABRE
Congrats Carsten! Videos next!
Reuben
Old 07-31-2012, 08:01 AM
  #622
Selleri
Selleri's Avatar
Congratulations mate, can't wait to see the rapidly moving image file with sound!
Old 07-31-2012, 08:16 AM
  #623
jetpilot
My Feedback: (48)
jetpilot's Avatar
The jet flys amazing in calm conditions but can benefit from a gyro if it's windy. Making them as heavy as possible helps.
Good to hear the gear work with one valve. I have seen so many not!
Let me know if your interested in my gyro setup. I really like the JR 370 A.
Scott
Old 07-31-2012, 08:47 AM
  #624
schroedm
schroedm's Avatar
Scott, I think Carsten has gone the full monty 3-axis I-gyro route!
Old 07-31-2012, 09:11 AM
  #625
Carsten Groen
ORIGINAL: schroedm
Not mounted yet though
