Tomahawk-Design Bae Hawk 1: 3.5
Reply
Old 04-23-2013, 11:23 PM
  #776
jetpilot
jetpilot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Tomahawk-Design Bae Hawk 1: 3.5
Thanks Carsten!
What CG did you end up with. I think my other one is 315-320. This one feels lighter on the nose. I need to get it out and check.
Yours all sorted out?
Scott
jetpilot is offline
Old 04-23-2013, 11:38 PM
  #777
Carsten Groen
Carsten Groen's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The CG is a good question
If I remember correctly, it is set at the recommended position. With empty tank, the frontwheel presses down with about 1200 gram on a scale
It's all sorted again, but strugling a bit with the main gear and the springs inside it.
When I dissemble the legs, clean them etc, they work fine for a few days, after that they "stick" more and more to the point where they won't come out again. If I adjust the screw, they get too soft, and will sag.
Got some new longer springs from Diddi (also the green type, but just longer), hope they work better once I get them installed...
Carsten Groen is offline
Old 04-24-2013, 01:44 AM
  #778
tobba
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Brilliant Scott - looks bloody amazing. Love the paint.
All the best.
Craig.
tobba is offline
Old 04-24-2013, 01:31 PM
  #779
jetpilot
jetpilot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks Craig!
Whats the status of yours?
ran the motor and did all the checks. Everything ready to go!
Cant wait to see how brakes work! They seems to be good, just different than air. They dont actually lock which i guess is a good thing.
Theres a Notam all day today and tomorrow!! UGH!
Scott
ID:	1875962   Click image for larger version
jetpilot is offline
Old 04-24-2013, 02:30 PM
  #780
bcovish
bcovish's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sweet!!!!!!!!!!!!!
bcovish is offline
Old 04-25-2013, 02:30 PM
  #781
jetnuno
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi
Would a P180 be a good choice for this bird? I mean flying scale with cockpit, pilots, opnening canopy, etc...
I was just planning to have a not so fuel eater turbine like the P200
What do you guys think?
Regards
Nuno
jetnuno is offline
Old 04-25-2013, 02:39 PM
  #782
schroedm
schroedm's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nuno
I think you will struggle to fly this model in a scale fashion with a P180. The reason is that flying scale can often require more power as you are looking to keep the speed lower and thus you need more power to pull the model through climbs and loops etc rather than using the inertia from a 200mph pass!!! The Hawk isn't ducted either so there is a lot of drag to start with.
I think a P200 - 220 turbine is just about spot on.
Rgds,
Mark
schroedm is offline
Old 04-25-2013, 08:54 PM
  #783
jetpilot
jetpilot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You will definitely save a few lbs using a P180 sized motor which would help but The P200 feels perfect to me. A P160 barely flys it. I have yet to see a P180 Tomahawk fly though. 3 more lbs of thrust desnt seem like it would make that much different. I have to get into the power alot when the gear and flaps come down. It screaches to a hault. I would think you would be much happier with P200. Plus the jet probably flys a bit better on the heavier side anyways.
Scott
jetpilot is offline
Old 04-26-2013, 01:11 AM
  #784
jetnuno
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok. Clear
Thanks guys
jetnuno is offline
Old 04-26-2013, 03:43 AM
  #785
Chuchuf
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I wonder if one of you guys can do me a favor and measure the maximum opening that is on the back of the fuse where the exhaust tube comes out of the TH Hawk.
Terry
Chuchuf is offline
Old 04-26-2013, 11:50 AM
  #786
ilsan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just finish one here in Norway.
B300F Turbine
ID:	1876404   Click image for larger version
ID:	1876405   Click image for larger version
ID:	1876406   Click image for larger version
ilsan is offline
Old 04-26-2013, 12:38 PM
  #787
jetpilot
jetpilot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey! That looks familiar!! Nice job!
Looks great!
Scott
jetpilot is offline
Old 05-06-2013, 07:06 PM
  #788
roydefiant
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am getting ready to start rigging soon. Curious if most of the hawk builders are using powerboxes and if so which one?
thanks Roy
roydefiant is offline
Old 05-06-2013, 10:10 PM
  #789
Carsten Groen
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Roy,
I'm using a Powerbox Cockpit SRS and two Futaba R6203 receivers delivering SBUS signals to the Powerbox (the Powerbox can also accept Spektrum, Multiplex, HotT etc receivers)
Powerbox: http://www.powerbox-systems.com/e/po...-srs/start.php
ID:	1879884   Click image for larger version
Old 05-06-2013, 10:49 PM
  #790
schroedm
schroedm's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm using the new Royal SRS
schroedm is offline
Old 05-13-2013, 06:35 AM
  #791
argiel
argiel's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello, sorry me, but the CG in your Hawk is in wing tube ? the CG Hawk Bae and Hawk 100 is same ??
Florio
Italy
argiel is offline
Old 05-14-2013, 02:17 AM
  #792
argiel
argiel's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello, i see the work, perfect congratulation.
Please, i make the new one same to you, please the CG is in wing tube ?
Thank
Florio
argiel is offline
Old 05-14-2013, 07:37 AM
  #793
jetpilot
jetpilot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
310-325mm behind leading edge
scott
jetpilot is offline
Old 05-14-2013, 08:00 AM
  #794
argiel
argiel's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hi Scott,
thank very much, i think that the next week if the weather is ok, i make the first fly
ciao
Florio
Italy
argiel is offline
Old 05-14-2013, 08:02 AM
  #795
jetpilot
jetpilot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Do you have the Hawk 100?
Scott
jetpilot is offline
Old 05-14-2013, 08:12 AM
  #796
argiel
argiel's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
no, i have the MK66 switzerland scheme with P200 SE, total weigt without kerosene 19.96 Kg
argiel is offline
Old 05-14-2013, 08:30 AM
  #797
jetpilot
jetpilot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: argiel
Im amazed at how you guys can get it to that weight!!
both mine are much heavier!
Scott
jetpilot is offline
Old 05-14-2013, 08:39 AM
  #798
argiel
argiel's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
if you want partecipe the world master 2013 in Switzerland you must this, the first test fly i use P200 and after i use Beotech 180 gold with 200 newton,,,,,, you remember the first model that Thomas have make for world master in Israele 2009 ?? ok this is the same.....
i would like to come in Texas,,,,, Land of the guns ;-)))
Florio
argiel is offline
Old 05-15-2013, 09:01 PM
  #799
heraldoboldrin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Can someone measure the Hawk 66 for me?
I need wide, long and high measures from the Hawk 66 assembled and ready to fly...
regards
Heraldo
heraldoboldrin is offline
Old 05-17-2013, 06:13 PM
  #800
roydefiant
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
some dry transfers and a clear coat and ready to go
ID:	1882747   Click image for larger version
Reply
Display Modes
