Tomahawk-Design Bae Hawk 1: 3.5
#926
Mine are screwed at the moment but will be glued and screwed after painting.
Best place IMO for ref on a SG Hawk build is Marc S's old build thread. http://www.rcuniverse.com/forum/rc-j...-manual-6.html
Post 138 has a shot of the fences. David Gladwyn also has done some really nice work on a more scale fence setup.
#930
Iconel is there any chance I could get a set of the parachute hinges as well as the 3D pod as well? My email is [email protected] if we could discuss I would appreciate your assistance.
#937
My Feedback: (26)
Couple more questions. Did your vertical fin tube come with a cardboard tube to glue in your fuse? For the wings do you glue the front antirotation pin in the wing or fuse? I assume you glue the carbon fiber sleeve for the front pin in the opposite. Same for the rear pin do you glue it in the fuse?
#944
My stainless tubes are glued in to the wings with carbon in the fuse.
I will re do the hydraulic rams... maybe a little nicer. A few pics attached.
