Reload this Page >
Tomahawk-Design Bae Hawk 1: 3.5
Old 08-10-2014, 06:14 AM
  #1026
j.c.a.
Hi, Can someone please post the recommended throws for the surfaces and the recommended CG for the Tomahawk MK-66 Hawk. I bought a used Hawk and would like to verify all the setup.
J.C.
Old 08-10-2014, 07:25 PM
  #1027
roydefiant
for the 1:3.5 hawk
flap 47 mm for regular fields, 75 mm for very short fields
aileron with differential throw, 27mm up, 18 mm down expo 30%
elevator take off and landing +46 mm/-35 mm (15% EXPO); flying = 26 mm/- 24 mm( 45% EXPO)
rudder +/- 45 mm (60% EXPO)
CG is 310 to 325 mm from leading edge at fuse
Old 08-11-2014, 06:19 AM
  #1028
j.c.a.
Originally Posted by roydefiant
for the 1:3.5 hawk
Thanks very helpful,
Thanks again
J.C.
Old 08-11-2014, 03:54 PM
  #1029
jws_aces
My Feedback: (33)
jws_aces's Avatar
JC go check out this video from yesterday at Michigan jets. I tell you it was flying awesome.
https://www.youtube.com/watch?v=bBGcFz9dyjs
Old 08-13-2014, 07:20 AM
  #1030
j.c.a.
Yes it looked awesome you got it dialed in . Are you using recommended throws and CG? congrats. My Skygate should arrive end to middle of next month. I just bought a Tomahawk almost ready for maiden.
J.C.
Old 08-13-2014, 05:47 PM
  #1031
jws_aces
My Feedback: (33)
jws_aces's Avatar
JC
Started out with the recommended CG. After first couple oflandings move the 2 life 3600MAH from the front below the pilot to behind themain wheels. I still can't hold the nose up long on landing. That is supposedto be way to tell if you are close.
I am not sure of the throws. I do use a lot of expo. I haveabout 55% expo with 80% movement on the ailerons. They are very sensitive. Ihave as much throw on the elevator as movement will allow without touching thefuse. I also use about 40% expo on it.
Let me know how it goes with the Tomahawk.
Old 08-13-2014, 05:49 PM
  #1032
jws_aces
My Feedback: (33)
jws_aces's Avatar
I also looked tonight on my ECU and I have 369 minutes on the 210g with 30 cycles since installation before KY jets. I know of 3 cycles of bench testing.
I put 13+ flights on it in Michigan alone.
Old 08-21-2014, 03:24 PM
  #1033
j.c.a.
Here is a pic of my new toy, just finished re-doing the wiring and cleaning up the layout. ready for maiden https://www.rcuniverse.com/forum/IMG_0783.m4v
Old 08-21-2014, 05:55 PM
  #1034
jws_aces
My Feedback: (33)
jws_aces's Avatar
JC the picture is not showing up on my end.
Old 08-22-2014, 03:32 AM
  #1035
schroedm
schroedm's Avatar
Nice!! Is that Joey's?? If so, small world - that was mine that I half built and sold to him. I LOVE that scheme!!!!
Old 08-22-2014, 04:07 AM
  #1036
j.c.a.
Yes it was Joeys , small world by any chance did you do the painting and if so do you have the paint color codes
J.C
Old 08-22-2014, 04:11 AM
  #1037
schroedm
schroedm's Avatar
JC,
Afraid not. I think Joey had Shui's painters finish it for him
Mark
Old 08-22-2014, 07:39 AM
  #1038
j.c.a.
before and afterA better pic
ID:	2024689   Click image for larger version
ID:	2024690   Click image for larger version
Old 08-22-2014, 08:59 AM
  #1039
jws_aces
My Feedback: (33)
jws_aces's Avatar
I like it!! Nice job cleaning it up.
Old 08-24-2014, 02:22 PM
  #1040
j.c.a.
Got the maiden in today, I had a friend Andy Benitez do the maiden, just to get the nerves out of the equation.I did the second and third flights,And Andy did the fourth, very little trimming and on CG ajustment.plane flew on rails. I will be playing with the aileron throws and expo which I thought were not enough and they are set as per spec. ,Maybe that the gyro is holding theroll rate. on my second flight got a wheelie landing so the CG is almost perfect. Overall VERY VERY happy with the results
Old 08-24-2014, 02:25 PM
  #1041
jws_aces
My Feedback: (33)
jws_aces's Avatar
SWEET!! way to go JC...do you think you will be GA Jets next month?
Old 08-24-2014, 04:17 PM
  #1042
roydefiant
so where did you set the CG?
Roy
Old 08-25-2014, 04:23 PM
  #1043
j.c.a.
I set it at 320mm but will tweak it a little more nose wheel up landing almost perfect
Old 08-25-2014, 04:26 PM
  #1044
j.c.a.
This video is a mix of the four flights my friend Albert Fortgang did it.
https://www.youtube.com/watch?v=b5_Pb_4vEDY
Old 08-29-2014, 05:19 PM
  #1045
roydefiant
successful maiden today at Grice aerodrome
Jeti radio with airspeed telemetry (stalls at 48 mph)
Jetech 6 liter fuel cell
behotec 220 turbine
Name:	hawk maiden 1.JPG
ID:	2027061   Click image for larger version
Name:	hawk maiden 2.JPG
Old 08-29-2014, 05:23 PM
  #1046
roydefiant
access hatch with JMP air panel in the hawk, all switches, fuel fill and air fill in this hatch
Name:	hawk hatch.JPG
Old 08-29-2014, 06:34 PM
  #1047
jetpilot
My Feedback: (48)
jetpilot's Avatar
Nice Roy!
Looks spectacular!
Stalls at 48 with flaps or without? Im guessing without.
Scott
Old 08-29-2014, 06:35 PM
  #1048
jetpilot
My Feedback: (48)
jetpilot's Avatar
Do you have the new springs? Looks a little compressed.
Scott
Old 08-29-2014, 07:08 PM
  #1049
roydefiant
you are correct Scott, it is compressed. Did you get the springs from Tomahawk? How much were they? How much of a hassle was it to change out the springs?
thanks roy
Old 08-29-2014, 07:57 PM
  #1050
jetpilot
My Feedback: (48)
jetpilot's Avatar
Hi Roy,
First was the stall speed with flaps or without? guessing without. I think the stall speed with flaps will get in the 30's
Yes they came from Tomahawk. I don't think he charged, cant remember. You can open the strut up. C clip. Its a little pain especially after the strut cover is on. pull out your old springs. I think there are 3. take them to your local hardware store and see if you can find better ones. Or contact tomahawk. The squatting can actually make your strut door hit ground on landing and break off. As well the scale appearance being off. When a Hawk is up and running and taxiing it sits high in back. when powered down and off it does squat but not as dramatic as the model does with weak springs.
Scott
