Reload this Page >
Tomahawk Futura Build Thread
Old 05-07-2016, 08:02 PM
  #201
rcpete347
My Feedback: (251)
rcpete347's Avatar
HI Jay, I have the CD, I can send it to you.
Rcpete
[email protected]
Old 05-08-2016, 08:02 AM
  #202
BlueBus320
My Feedback: (57)
Rcpete
[email protected]
Thanks a million Pete! I just picked up a NIB 2.5 & it turns out the guy has the cd, so I should be all set. What did you think of the builds Pete? Is there a thread with more info on the 2.5?
Old 10-10-2016, 09:34 PM
  #203
haisanjafri
haisanjafri's Avatar
Setup below from the THD Manual
1. Heard this airplane requires a lot of down elevator while inverted, where as per manual the deflection asked to set is less than the UP stick movement?
2. What we know that to have axial rolls & reduced drag we always setup aileron going up with more deflection than the aileron going downwards, however it looks opposite in the manual! Or may be negative 17% differential compensates it?
Old 10-10-2016, 10:06 PM
  #204
Malcolm H
Malcolm H's Avatar
Not sure how the Futura ailerons are hinged but top hinging usually requires reverse differential (more down than up) to achieve straight rolls.
There are many different tests for correct differential but one of the easiest to carry out is to pull up to about 30 degrees so that you can apply full aileron for several rolls without needing to put in any elevator or rudder corrections. Watch the model carefully as it rolls say to the right. If it "walks" to the left it needs more differential (more up than down), If it "walks" to the right when rolling right it needs less differential. Do this in both roll directions as often there can be a difference in the amount of differential required.
Once you have set this, pull up at 45deg and half roll to inverted. Pull through a reversal and watch for any change in heading. Do this several times and if necessary tune the differential until there is no heading change.
Hope this helps,
Malcolm
Old 10-11-2016, 11:57 PM
  #205
MattyMatt
This is correct. I set the down for as much as you can get. Use zero exponential on the down elevator.
Yes, you'll need a bunch of negative aileron differential due to the hinging at the top of the aileron.
Old 11-27-2016, 12:07 AM
  #206
Speedf16
My Feedback: (16)
Hi Malcom I have the Futura looking at jet cat
180rx newor kingtech 210 woljld 180 b enough getting a good price on one .my email is [email protected] thanks
Old 01-29-2017, 07:13 PM
  #207
Speedf16
My Feedback: (16)
What's the Cg on the futura ?
[email protected]
Old 01-30-2017, 03:11 AM
  #208
haisanjafri
15mm behind the wing tube shall be a good start
Old 03-24-2017, 05:57 PM
  #209
Speedf16
My Feedback: (16)
I have k 210 , I just experienced some thing weird on my 2.5 futura , while increasing the throttle to full , the mid section of fuselage collapses in , ( this is with the canopy on , has anybody seen this , it sounds to me it needs more air theu the intake ,?
Any suggestions??
Old 03-24-2017, 06:28 PM
  #210
BaldEagel
BaldEagel's Avatar
This may not happen in flight because of the increased airflow through ram effect?
Mike
Old 03-25-2017, 12:52 AM
  #211
Speedf16
My Feedback: (16)
Ok thanks , a little concern there for a second , yes some pilots exp this effect also n have over 100 flights on tomohawk , it's a great build jet ..
Old 03-25-2017, 04:49 AM
  #212
rcpete347
My Feedback: (251)
rcpete347's Avatar
HI guys, looking to get a replacement wing tube for my Audi Futura.
Any leeds would be great.
Rcpete
Old 04-04-2017, 11:40 AM
  #213
AEROSHELDON
My Feedback: (99)
AEROSHELDON's Avatar
Hello all,
I just picked up a 2.5 and I am really jazzed about it. Snowing here right now so taking my time and going through everything and have a question:
Has anyone had issues with these stock control rods and linkages? I usually use titanium turnbuckles but these have been here for a while with the previous owner with no issues and I don't want to change them just to be changing them, but if they are a worthwhile upgrade I will do it.
Old 04-14-2017, 02:45 PM
  #214
AEROSHELDON
My Feedback: (99)
Anyone??
Can someone also post the surface throws they are using? Just stock or less? Thanks!
Old 04-14-2017, 03:00 PM
  #215
rcpete347
My Feedback: (251)
rcpete347's Avatar
Rcpete
Still looking for a wing tube, any dealers out their.
Old 04-14-2017, 04:24 PM
  #216
CraigG
My Feedback: (40)
CraigG's Avatar
Originally Posted by AEROSHELDON
Anyone??
Aileron: +/- 25mm Hi Rate, 70% for low rate (exponential as you like it and maybe a little differential)
Rudder: +/- 50mm
Elevator: +/- 30mm*
Flaps: 50mm Takeoff, 125mm Land
*You want the MAX down elevator you can get with little or no DOWN expo. It takes a lot of down elevator to fly this jet inverted and the throw is limited by the lower edge of the elevator hitting the rear stab spar. On the other hand, rudder is very effective and it will knife edge all day with half throw or less.
BTW, the stock linkage looks a little undersized but I used it and have never had a problem.
Craig
Old 04-14-2017, 05:49 PM
  #217
RBardin
My Feedback: (27)
RBardin's Avatar
Pete, Have you tried here?
http://dragonplate.com/ecart/categories.asp?cID=290
or here:
http://www.f3aunlimited.com/hardware...and-stab-tubes
Old 04-14-2017, 06:26 PM
  #218
AEROSHELDON
My Feedback: (99)
Rudder: +/- 50mm
Elevator: +/- 30mm*
Craig
Thank you Craig! This is great info. Yes my elevator almost hits the side of the plane on full down. I will use very little expo as you suggested.
ID:	2209724   Click image for larger version
Old 04-14-2017, 06:57 PM
  #219
AEROSHELDON
My Feedback: (99)
Rcpete
If you know the size I would try CST composites.
Old 04-15-2017, 03:01 AM
  #220
CraigG
My Feedback: (40)
CraigG's Avatar
One more thought; the Futura will waggle a little in yaw in windy conditions. A Cortex or IGyro will eliminate that completely and improve what is already an excellent flying jet.
Old 04-15-2017, 05:33 AM
  #221
rcpete347
My Feedback: (251)
rcpete347's Avatar
Hi, the wing tube is aluminum, thanks for the info
Rcpete
Old 04-15-2017, 06:07 AM
  #222
AEROSHELDON
My Feedback: (99)
Rcpete
I thought you wanted to replace with carbon. Have you tried TNT Landing Gear? They do aluminum wing tubes.
Old 04-15-2017, 06:08 AM
  #223
AEROSHELDON
My Feedback: (99)
I have a Cortex Pro that I am going to install when I get the throws done to the recommended values. Thanks again !!
Old 03-08-2018, 09:38 PM
  #224
haisanjafri
Futura 2.5 "3rd Flight" loving it
Old 03-09-2018, 03:49 AM
  #225
CraigG
My Feedback: (40)
CraigG's Avatar
https://www.youtube.com/watch?v=U7SMPXrTEA4&t=10s
Nice job and nice flying! Now you see why every other jet manufacturer has copied the Futura in some form or another.
