Multipin Connector for Servos and Lighting System
I have a full lighting system in my Global Jet Club L39. There are 6 cores going out to each tip tank which were supplied with 3 separate 2 pin connectors.
I would like to use one connector for the lights, flap and aileron servo to make field rigging quicker and simpler. Assuming I don't common any connections for some redundancy that's 12 cores. Can anyone recommend a suitable plug and socket system? At a pinch I could use 2 x 6 way connectors.
Malcolm
Malcolm
RE: Multipin Connector for Servos and Lighting System
Hi Malcolm, use the 12-way Ashlok connectors http://ashtekelectronics.com/shop/
When ordering you need to order all 4 components - male and female housings, and male and female pins
I would strongly recommend their excellent ratchet crimping tool as well, it is much better than the plain pliers type sold in model shops
Harry
Harry
Thanks guys,
That was the route I was planning but not sure I have enough room for the length of the 12 way connector and was hoping to find 2 x 6 rows. Guess I could still use 2 x 6 way Ashloks.
Malcolm
Malcolm
