If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 17 of 26 FirstFirst ... 71516171819 ... LastLast
Results 401 to 425 of 631
  1. #401
    Join Date
    Jun 2004
    Reut,Israel
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Jetlegend Mig 29 Fulcrum
    Bart,
    Any real reason why not to run clear lines all through the system ?
  2. #402
    Aussie Bart's Avatar
    Join Date
    May 2006
    Sale, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    No, other than easy line identification
    Bart
  3. #403
    ianober's Avatar
    Join Date
    Aug 2002
    San Mateo, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hey Bart, below is a video of my gear operating. Wonder if I could get you take on it. You can see that the mains are not staying in the plane and sagging out and I am wondering what could be causing this. It could be that the nose is sagging to but its just stiff enough to not be moving. The 4mm tubing is much better and I am thinking that either I am getting "blow by" in the pistons or perhaps the valve is not functioning as it should. I don't see any air in the lines and the down is fine, nice and solid, just the up is causing issues.
    [youtube]http://www.youtube.com/watch?v=_mVdezMiwRg[/youtube]
  4. #404
    Join Date
    Dec 2004
    PlaistowWest Sussex, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Ian,
    What you have looks like what mine was like before I got the new solid pistons machined up. It is fluid getting past the pistons. It may be only one, as they are inter connected it is hard to tell so what you need to do is pinch off one side at a time to confirm this. If you don't want to pinch the lines then disconnect them and fit non return valves on the end of the up and down lines. Best of luck, I've been there!
    John
    CRASHING IS NOT AN OPTION.
  5. #405
    Join Date
    May 2006
    Sale, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ian
    Nice job on the conversion. You are 100% right in that you are losing oil, but there are a couple of areas that this can happen.
    First thing that I notice is the decompression of the oil,afterthe gear retracts up and pressurizes, it takes a few seconds before the gear moves, this shows that the oil is actually decompressing and as the pressure dops off the gear starts to drop, this means that there is only a small bypass somewhere.
    The first one I would look at is the check valve between the pump and 5 port valve. This check valve (I hope you have one fitted) is imperative in locking the oil in the cylinders. When the gear is retracted, the extend side of the cylinder is ported directly to the pressure port of the pumpvia the 5 port valve, if the check valve is not sealing (or missing) the oil just pushes back through the pump into the reservoir.
    The next item to look at is the 5 port valve, if the spool is not moving all the way to the end stops, you have the potential to have the pressure side bleed back through a tank gallery in the valve with the same result, the oil goes back into the reservoir.
    Lastly would be the piston seals.
    I find the best way to track these things down is with a pair of long nose pliers. The reason for using long nose pliers is that you are only crushing a small area of line that cuts the flow off effectively.
    Starting with the line between the 5 port valve and the pressure port of the pump, cycle the gear up and when the pump stops squeeze the line with the pliers to close it off - not so hard that you damage the line though. Anyway, if the gear does NOT drop, then you have bypass through the check valve back into the pump. Remove the check valve give it a blast of air in the free flow direction to clean it and then put some air on the check side to see if it seals. If air gets pass so will oil eventually.
    If not the check, then using the same pliers you can also repeat the experiment but this time on the line (after the tee) from the 5 port valve to the reservoir return and then each line before the tee in turn, this will prove valve bypass.
    Lastly squeeze off each line connected to theROD end of the cylinder in turn. It is unlikely that more than 1 piston will have failed, this being the case if you squezze off one of the lines and the gear stops dropping then that is the offending seal. Becasuse all the cylinders are connected together, then 1 bad seal will drop all the cylinders.
    Just keep in mind, as I mentioned in an earlier post, if the oil is not on the ground then it has to bypass back to the reservoir and this being the case there are only 3 area's it can do this.
    Finally, you have installed the Festo pilot check valves on the gear down side of the cylinders, these valves are classed as leak free and as such the oil stays trapped in them forever until you let it out. However on the gear up side, the oil is held in the cylinders only against the check valve on the pump pressure line through the 5 port valve. The 5 port valve is NOT classed as a leak free valve (for the spool to slide it must have clearance, any clearance no matter how small will bypass oil). Technically we class them as 5 drops per minute, but in our planes it's probably more like2 drops an hour or more. My gear will stay up for days (unlike me) but after about a week it will start to push the doors open. Compare this to the original air design without up locks that would drop the gear like a stone as soon as power to the jetronics valves was lost, we are still miles better off.
    I am sure you will find the offending item
    Bart
  6. #406
    Join Date
    Jun 2004
    Reut,Israel
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Bart, i vote you for you "Hydraulics RC man of the year" !
  7. #407
    ianober's Avatar
    Join Date
    Aug 2002
    San Mateo, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Great stuff Bart. I do indeed have a check valve (Festo) but I did notice when I was bleeding the system that air bubbles seemed to be flowing back through the check valve towards the pump so this will be the first thing I check. I checked my cylinders under water and with air so I think they are sealed pretty good since I saw no bubbles. I will check all out and report back with my findings.
    Also, does anyone else have a suggestion for a better check valve?
  8. #408
    Join Date
    Jul 2005
    hull, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    John,
    The upgraded mains have arrived so I'll post them off to you.
    Jeff
    Exclusive UK JetLegend Dealer
  9. #409
    Join Date
    Dec 2004
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Great, Thanks Jeff.
    John
  10. #410
    ianober's Avatar
    Join Date
    Aug 2002
    San Mateo, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    So I did a little testing at home during lunch and I think I found the problem. Seems that my check valve is not "checking" . I retracted the gear and right when the pump shut off I clamped the tubing between the check valve and the distribution valve and the wheels stayed up! SO, seems that would be the problem. I have 2 new check valves on their way (in case one of them is bunk) so I am hoping this will help.
    At the same time I noticed a bit of an issue. When the gear is fully retracted into the plane they are still hitting the doors a little (just the mains). Seems that the stroke of the cylinders are not enough to get the gear all the way into the wells. I have not hooked up the doors yet but that is my next project. I am hoping that they will perform better while under pressure, we'll see. I will update again when that is up and running.
  11. #411
    Join Date
    Jun 2004
    Reut,Israel
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    How about a hydraulic system with the upgraded mains, and connect the retraction side of the "locking" cylinder of the mains with a T to the doors closing line ? that might help out a bit in locking the gear up, and might cure the issues you are having as there would now be an added "push" to lock the gear up ?
  12. #412
    Join Date
    Jun 2004
    Reut,Israel
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    My kit came without the little nose wheel steering arm
    can anyone give me the measurements of this part so i can make it by CNC myself ?
    EDIT: my builder found it in the LG where all the valves are so all good.
  13. #413
    Jim Cattanach's Avatar
    Join Date
    Mar 2003
    Larnaca, , CYPRUS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    You guys that are flying the Mig. Do you find the fuel tank capacity large enough for decent flights, using a 160 turbine? I had thought of adding some more capacity, but there ain't much room available.
    Also what CG are you using? I thought of setting mine on the spar, just rearwards of the factory setting, which someone said was too nose heavy.
    JET FLYING:- Resistance is futile. You will be assimilated.
  14. #414
    Join Date
    Jun 2004
    Reut,Israel
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Also, where did you have to mount your battery packs to get her to balance well ?
  15. #415
    Join Date
    Mar 2003
    Larnaca, , CYPRUS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    To get mine to balance on the spar ( if that is the accepted point), I have two 2300ma lifes in the nose area close to the canopy end & a 3000ma lipo for the turbine in the rear of the equipment tray. Getting it to balance will not be a problem, there is no need to keep things forward, or back.
  16. #416
    Join Date
    May 2006
    Sale, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Jim Cattanach
    Jim
    After taliking to John, I set mine on the spar and I love it, I think John has moved a little more than that now. If you take into account where the tanks are and the fact that there seems to be no need for any trim change during the whole flight, you start to get a feel for just how much lift there is from the shoulders.
    Bart
  17. #417
    Join Date
    Mar 2003
    Larnaca, , CYPRUS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Aussie Bart
    Jim
    Thanks Shane. I remember from my Avonds F15 (being the same shape), CG was not critical & had quite a range to play with.
  18. #418
    ianober's Avatar
    Join Date
    Aug 2002
    San Mateo, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I received my new check valves so I will be testing them out at lunch today to see if they will do the trick.
  19. #419
    ianober's Avatar
    Join Date
    Aug 2002
    San Mateo, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    EUREKA!!!! Looks like I got this problem worked out. I replaced the Festo check valve with an SMC one and it seems to be holding nicely, no more sagging gear. I am going to clean off my bench and I will make another video showing the movement and how I ran all the lines for anyone who may want some ideas as to how to get their system going.
  20. #420
    F15driver's Avatar
    Join Date
    Dec 2001
    New Braunfels, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ian,
    Good work! Like you, I've got mine working with the SMC check valve. Seems to hold the pressure better than the Festo valve. What sequencer are you intending to use? I've tried the Jettronic sequencer and am unhappy with it. Not consistent. Have a Tom Cook one on order which should arrive this week. Once we get the gear doors sequenced with the gear, it is going to be toooo coooool!
    Look forward to your video.
    Rob
    F15driver
    Don't look back, they may be gaining on you!
  21. #421
    ianober's Avatar
    Join Date
    Aug 2002
    San Mateo, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Rob, I am going to try the RCBee I got from Todd at Dreamworks. The price was right and supposedly there is a wide range of times to configure between the operation of the door valves and the gear valves.
    [link]http://www.rcbee.com/index.php?Page=11[/link]
  22. #422
    Join Date
    Dec 2004
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Post 361 shows where I have my CG. It balances with no lead. With the standard fuel tanks I am flying for 8 minutes and landing with a lot of fuel. (Merlin160 power). I do not have a sequencer but operate the doors by programming my (Futaba 14mz) radio. It works fine.
    John
  23. #423
    yeahbaby's Avatar
    Join Date
    Dec 2001
    FT Worth, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    damn that's inexpensive!!!!
    ORIGINAL: ianober
    work work work ......livin the dream
  24. #424
    ianober's Avatar
    Join Date
    Aug 2002
    San Mateo, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thats what I am talkin about Buck. I played with it a little tonight and I have it delaying at 8 seconds right now but I think it might be able to go a little longer. Right now I am plumbing my gear doors and brakes. As far as the hydraulic conversion though everything is looking real good. I raised the gear at lunch today and it is still holding, 11 hours now, sweet!! Video and details coming soon!!
  25. #425
    Join Date
    Mar 2003
    Larnaca, , CYPRUS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Finished building mine. I have used the new U/C as supplied & it appears to work fine. Test flights will be Saturday, if it is not too windy. Wren 160 for power.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
