If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 2 of 26 FirstFirst 123412 ... LastLast
Results 26 to 50 of 631
  1. #26
    Join Date
    Jul 2005
    hull, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Jetlegend Mig 29 Fulcrum
    You lot are so impatient!
    I'm off in the workshop now to try and get some done...
    Jeff
    Exclusive UK JetLegend Dealer
  2. #27
    yeahbaby's Avatar
    Join Date
    Dec 2001
    FT Worth, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ditto
    ORIGINAL: Rider-60
    So Jeff,
    where are the SU-27's pics??
    work work work ......livin the dream
  3. #28
    nt flyer's Avatar
    Join Date
    Sep 2005
    SaleVic, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Subscribed. Can't wait to see this one fly!
    Greg
  4. #29
    JohnMac's Avatar
    Join Date
    Oct 2002
    Leeds, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: jeff sewell
    Jeff
    That's good. You can have it ready for Sunday then!
  5. #30
    Join Date
    Jul 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well I would but its not mine...
    Jeff
  6. #31
    Aussie Bart's Avatar
    Join Date
    May 2006
    Sale, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well I started to catch up with my other build projects and repairs so it was time to take a closer look and start some actual work on the mig.
    I have a great like for hydraulic retract systems (I design hydraulics for a crust) after using it in my Catalina a few years ago and just recently in my 1:5 KS Vampire and JL T45. This being said, I could not wait hook up to the main gear just to gauge how long it was going to take to operate those big ass cylinders, I can happily report that the work extremely well and at a very scale speed and performance and am looking forward to getting all 3 legs running on oil in a couple of weeks.
    I had a good look at the mounting plates for the mains, and whilst I would prefer to see some flex plates being predominantly a grass strip flier, I don’t believe the heavy duty alloy mounts are going to fail anytime soon.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1370880   Click image for larger version.
ID:	1370881   Click image for larger version.
ID:	1370882   Click image for larger version.
ID:	1370878   Click image for larger version.
    Bart
  7. #32
    Join Date
    May 2006
    Sale, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I then removed the Stabilizer mounts to have a closer look and to set up the servo’s. These are accessed from inside the fuse and are held into the rear former by cap head screws and are a snug fit into the former mount, it was actually a bit difficult to remove the mounts even with all the screws removed. The mounts are fitted with some very smooth and close tolerance bearings that support the Titanium stab shaft. Because of the distance from the bearing mounted clamp and the outrigger bearing, the stabilizer support is very strong.
ID:	1370885   Click image for larger version.
ID:	1370886   Click image for larger version.
ID:	1370887   Click image for larger version.
ID:	1370888   Click image for larger version.
ID:	1370890   Click image for larger version.
ID:	1370891   Click image for larger version.
ID:	1370892   Click image for larger version.
ID:	1370893   Click image for larger version.
    Bart
  8. #33
    Join Date
    May 2006
    Sale, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    One of the most difficult jobs it seems on the mig is just how to get the nose wheel steering setup. Now it must be said, that JL do not provide allot of build info with their product other than a 1:1 cad drawing of β€œmost” of the important bits. However I can say that after building the JL 1:8 F16 as a kit, the JL Gripen as a kit, the JL T45 as an ARF and now the mig, the airframes are well designed and really are not too difficult even without a page by page assembly instruction.
    Anyway back to the nose gear, when I unpacked the front fuse half that has the gear installed, and cycled the gear up and down by hand, it became very obvious that the JL team had come up with something very special but the servo connection eluded me other to say that I also found this small crescent shaped alloy plate in a bag taped to the inside of the box, this bag had the innocuous words written on it saying β€œNose Wheel”.
    Upon inspection and a fair bit of trial & error, I found that you actually mount the Crescent shaped plate to a standard round servo horn and then trim the plastic back to the shape of the plate, mount it to the servo, then mount the servo inverted into the frame. This was tried a couple of times and I found that I could not use servo horns that were too thick and the only servo I could find in my stock with a low enough splined shaft were Hitec’s.
    My final combination was to use a standard White circle horn from a HS 5475, mount the alloy plate (the 2 holes in the alloy plate line up perfectly with the outer holes of the horn) and then mount that all onto a HS 7985. The 5475 would fit as well but I don’t think it would take the abuse of grass strips too well.
    The other mod I made was to β€˜concave’ the face of the alloy plate that pushes on the steering cross bar this in turn will ensure that all the forces are pushed laterally and not tend to deflect away from each other.
    Lastly I have some photo’s of the gear folding to show how the wheels are pulled up (collapse the suspension) with the aid of the centre rod running through the oleo, this allows the long leg to clear the wheel well.
ID:	1370897   Click image for larger version.
ID:	1370898   Click image for larger version.
ID:	1370899   Click image for larger version.
ID:	1370900   Click image for larger version.
ID:	1370902   Click image for larger version.
ID:	1370903   Click image for larger version.
ID:	1370904   Click image for larger version.
ID:	1370905   Click image for larger version.
    Bart
  9. #34
    Join Date
    May 2006
    Sale, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Leg Shots
ID:	1370910   Click image for larger version.
ID:	1370911   Click image for larger version.
ID:	1370912   Click image for larger version.
ID:	1370913   Click image for larger version.
ID:	1370915   Click image for larger version.
ID:	1370916   Click image for larger version.
ID:	1370917   Click image for larger version.
ID:	1370918   Click image for larger version.
    Bart
  10. #35
    yeahbaby's Avatar
    Join Date
    Dec 2001
    FT Worth, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    fantastic pix amigo!!!!! please keep 'em coming
  11. #36
    Jeremy_D's Avatar
    Join Date
    Feb 2005
    Central Coast, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Looking good Shane!! I love the nose leg and the way it retracts in to clear the fuse. I'm still waiting on an answer for you about hydrolics.
    Cheers
    Jeremy
  12. #37
    Join Date
    May 2006
    Sale, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yeah Yeah I know, I start off with such a flurry and then nothing, just left it all hanging, well your'e starting to sound like my wife.
    Anyway after some serious work time selling stuff (more money = more jets) and finishing off my Facet repairs and replacing the wing on my JL T45, I have finally got back onto the Mig.
    Time to get serious, so started off with the control surfaces and the elevators were first on the list. As with most people, I like to strip all the pre-assembled mechanisms down to check for loose bolts etc, whilst not falling apart the bolts in the elevator mounts were not very tight. A little bit of loctite later and all was good. These are tuff little puppies...
    I mounted the HS 7955 TG’s which showed up the acute angle between the control horns. JL supply very nice M3 ball links with the kit but no pushrods?? (not even on the packing list) but I had some spare high tensile ones.
    Once hooked up the whole assembly is smooth and strong. I have not mounted back into the fuse yet and looking at it may be a little fun as the servo is covering the mounting bolts so it may be done in 2 steps.
ID:	1382712   Click image for larger version.
ID:	1382713   Click image for larger version.
ID:	1382714   Click image for larger version.
ID:	1382715   Click image for larger version.
ID:	1382717   Click image for larger version.
ID:	1382718   Click image for larger version.
    Bart
  13. #38
    Join Date
    May 2006
    Sale, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    As for the ailerons, I elected to use HS 7895's for the ailerons and analogue 15 kg servo's for the flaps. I found that the aileron cavity is just a bit shallow for the full size servo but if sand the supplied wooden mount down a little on the trailing edge side it fits like a treat.
    I did find however that the position marked on the drawings for pin hinges and horn mounting blocks was not what you got on the real thing, in particular the aileron horn. All of the control surfaces come pre drilled and recessed for the pin hinges but when you go to mount the fibreglass horn it is quickly evident that you would have to cut directly through the pin hinge.
    I found the only solution to this was to offset the fibreglass horn and use ball links to cover the offset.
    The aileron travels listed is +/- 32 mm which is seems allot. I found that I needed to cut the top & bottom shroud back and extra 3mm to try and relieve some of the resistance and in addition run a warm covering iron along the shroud with the fully deflected aileron to ease the pressure.
    Flap travel is 54 mm and again I had to cut the bottom shroud back 3mm and warm it up with the flap fully deflected.
    In both cases, there is still a huge amount of shroud overhanging the control surfaces so there will be no danger of air bypassing through and generating flutter.
ID:	1382763   Click image for larger version.
ID:	1382764   Click image for larger version.
ID:	1382765   Click image for larger version.
ID:	1382766   Click image for larger version.
    Bart
  14. #39
    Join Date
    Mar 2003
    Germany
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi,
    are the pneumatic rams self-locking?
    Julian
  15. #40
    Join Date
    Mar 2003
    Germany
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    WhatΒ΄s the weight of the MiG kit so far?
  16. #41
    Join Date
    May 2006
    Sale, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: jair
    Hi,
    Julian
    Hi Julian
    The main pneumatic cylinders have a locking mechanism built internally at both ends, it works very well. I will actually be using a hydraulic system to operate the legs and the locking still works very well. As for the weight, I have not had a chance to check it but I should be able to get a figure soon.
    Bart
  17. #42
    Join Date
    May 2006
    Sale, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Sorry for being so slack but too much work on and spare time has been spent getting the Mig ready for one of our bigger meetings here in Aus last weekend. End result is a jumpy and short video of the maiden, well a compilation of the first couple of flights anyway.
    I am still trying to sort out a couple of minor issues with the retracts but all in all she flies like a treat.
    http://www.youtube.com/watch?v=cRyHzMXYb74
    I hope to get some time this weekend to finish uploading the minor mods and tricks I found during the build.
    Bart
  18. #43
    Join Date
    Mar 2010
    otis, LA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Bart, pure filth!! Porn for the kero lovers. And those landing gear, my wife thinks i stay up late looking at skin sites but when she sees the history she thinks im even more afflicted. OH WOEISME. How do i tell my wife that i have spent the cash on one of these?
    Tis far easier to ask forgiveness than permission I say.
  19. #44
    Join Date
    May 2006
    Sale, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well here is the rest of the info I promised.
    THe elevator servo assy is very robust but can be a little tricky to assemble. The kit was supplied with 3mm bearing rod ends but no pushrods so I used 3mm stainless steel allthread. The linkage length is very short. You will need to fit a high torque servo not only for the size of the elevator but also due to the fact that the servo arm thrust direction is not in line with the control horn so you will lose about 20% of the power, I used Hitec 7955 TG's.
ID:	1427599   Click image for larger version.
ID:	1427600   Click image for larger version.
ID:	1427601   Click image for larger version.
ID:	1427602   Click image for larger version.
ID:	1427604   Click image for larger version.
    Bart
  20. #45
    Join Date
    May 2006
    Sale, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The Aileron & Flap installation went smoothly except if you use a full size servo on the Aileron you will need to profile the mount to fot it all into the wing,
ID:	1427608   Click image for larger version.
ID:	1427609   Click image for larger version.
ID:	1427610   Click image for larger version.
    Bart
  21. #46
    Join Date
    May 2006
    Sale, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Now the biggest problem I had was with the landing gear and had developed after I had finished building and started testing all the systems extensively. After about 20 or so landing gear cycles I noticed that one of the main legs started to retract very slow, which seemed like it was binding somewhere. When I removed the air from the cylinder it moved extremely smooth but once the air was on it would "grind" to a stop.
    This of course annoyed me to no end so it was time to strip the landing gear down.
    As I had mentioned earlier in the thread, the landing gear is very substantial and is not made up of the usual trunnion and fork arrangement but instead some form of locking mechanism in the cylinder itself.
    Once I stripped it down it soon became obvious how this mechanism worked as well as why it was failing.
    The cylinder piston is hollow and fitted with a β€œshuttle” that has an O ring seal arrangement. This shuttle is machined with a land in the centre and a taper on each end. Around the taper are 3 steel balls that are housed in the piston and each protrude through a tapered window in the piston.
    Near the barrel end is a machined groove (one in the mains 2 in the nose). When the piston has travelled to the end of stroke and bottoms out, the air pressure will continue to move the shuttle an extra couple of mm forcing the Taper under the steel balls, pushing them further through the windows into the machined barrel groove, this in turn locks the piston to the barrel in the DOWN position.
ID:	1427622   Click image for larger version.
ID:	1427623   Click image for larger version.
ID:	1427624   Click image for larger version.
ID:	1427625   Click image for larger version.
    Bart
  22. #47
    Join Date
    May 2006
    Sale, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    When the gear is put into retract mode, air pressure is shifted into the end where the piston has bottomed out and because the piston is locked by the steel balls the air shifts the shuttle the other way thereby moving the taper from under the balls thus releasing them, this then unlocks the piston allowing it to travel to the other end. On the mains, the balls are only in one end of the piston, the photo’s here are showing the nose leg cylinder piston that is set up with balls both ends of the piston to lock in the up & down position. Due to reliability issues I ended up removing the balls from the up lock portion.
    The reason that the leg was failing, was the shuttle is made from aluminium and as the shuttle moves back & forward the steel balls were pressing a groove into the taper. This in turn would allow the balls to start β€œriding” up the shuttle taper as the piston was moving which would try and push the balls into the cylinder wall and start to jamb. If you have a close look at the photo you can se the tracks starting to form.
    Bart
  23. #48
    Join Date
    May 2006
    Sale, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    So, with the steel balls making these tracks in the soft aluminium, the only solution I could see was to modify the shuttle. I ended up machining the damage area down to 5 mm, and using some 6 mm stainless steel hydraulic tube, I machined it out to be a press fit onto the machined area of the shuttle, this was then dressed to meet the original shuttle profile. End result after a few hours was a much tougher surface for the steel balls to run on.
ID:	1427636   Click image for larger version.
    Bart
  24. #49
    Jim Cattanach's Avatar
    Join Date
    Mar 2003
    Larnaca, , CYPRUS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I was thinking about one of these, but I am slightly put off by this U/C problem. It has been some time since the last post. Anyone got any updates or longer term experience with this model?
    JET FLYING:- Resistance is futile. You will be assimilated.
  25. #50
    Join Date
    May 2006
    Sale, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Jim
    Have sent a PM
    Bart
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
