Jet Legend F16 1/6 Rudder Linkage/Flutter
FL
Starting the assembly of JL F16 1/6 and wondering who is using the internal rudder linkage, or has changed to an external linkage, and if anyone has had flutter issues with the internal linkage. Anyone using external linkage how about pics of your setup. Thanks, Steve
RE: Jet Legend F16 1/6 Rudder Linkage/Flutter
We modified the fuse .....
With that bubble you have more space for the internal linkage.
Use double ball bearing and a alu servo arm
I have used the standard under the bubble mounting since new.. never had the slightest sign of flutter in 65 flights with a P160 on board..... see the video on jetlegend web site under albums......titled Malcolm's F16.....use the designers method it works
