Reload this Page >
HABU "BIG BLOCK" UPGRADE!!
Old 02-15-2010, 11:48 AM
AFTERBURNER1
My Feedback: (80)
AFTERBURNER1's Avatar
Default HABU "BIG BLOCK" UPGRADE!!
This past weekend at the Desert Jet Storm Rally i was able to see the new SHULMAN AVIATION 68mm Fury edf unit put through the paces in the new Parknone Habu!! What a difference!!! From low end grunt to top end screaming!! The best part about it is that it drops right in and is ready to fly in 15 min or so!!
Shulman Aviation
[email protected] or [email protected]
407-951-5922
shulmanaviation.com
ID:	1379520   Click image for larger version
ID:	1379521   Click image for larger version
ID:	1379522   Click image for larger version
Old 02-15-2010, 03:48 PM
Joe C
My Feedback: (23)
Joe C's Avatar
Default RE: HABU "BIG BLOCK" UPGRADE!!
I bought one of Shui set up and had Tony Q install it for me, noticed a big differance and the sound was great. Joe C!!
Old 02-15-2010, 03:51 PM
kirkj
My Feedback: (61)
do you still use 4S or go to 5S with this set-up?
Old 02-15-2010, 03:58 PM
bcovish
My Feedback: (8)
bcovish's Avatar
Are the leads on the ESC long enough to reach the motor without modification.
Old 02-15-2010, 05:26 PM
quist
My Feedback: (198)
quist's Avatar
We are running them with 4S packs. With the 30C packs they temp out at 118 degrees after 4:30 at full throttle.
Old 02-15-2010, 05:31 PM
quist
My Feedback: (198)
quist's Avatar
When you install the fan unit a leading edge cut needs to be made to accept the lip on the fan housing. Also running the fury fan with the eflite ESC will cause a thermal shutdown after 4:30 of full throttle flying. It was pulling 60 amps. It was faster.
Old 02-16-2010, 08:40 AM
AFTERBURNER1
My Feedback: (80)
Default RE: HABU
ORIGINAL: quist
Thanks for the info T...
Old 02-16-2010, 10:17 AM
AndyAndrews
AndyAndrews's Avatar
Default RE: HABU
Great info. I'm gonna buy one if I can find it. Recommended battery for best performance? The 4S batteries? Where is the best place to buy those?
Andy
Old 02-16-2010, 10:24 AM
quist
My Feedback: (198)
quist's Avatar
Default RE: HABU
I am using the Turnigy 30C 3600 mah bat. I would like to get the 40C 3000 when they come back in stock at Hobby King.
Thunderpower 3250 45c batteries would be ideal, but it is more money then I want to spend.
I ran it on my emeter last night. With the fury fan I am drawing 63 amps, 980 watts.
Old 02-16-2010, 10:27 AM
bcovish
My Feedback: (8)
bcovish's Avatar
Default RE: HABU
Here ya go Andy
http://shulmanaviation.com/shopexd.asp?id=220
I'm using Turnigy 3300 30C from www.hobbyking.com
Old 02-16-2010, 11:07 AM
AndyAndrews
Default RE: HABU
ORIGINAL: bcovish
Here ya go Andy
Does that come with the controller? or do I need to buy that to?
Andy
Old 02-16-2010, 11:16 AM
bcovish
My Feedback: (8)
bcovish's Avatar
Default RE: HABU
ESC extra
Old 02-16-2010, 11:18 AM
drdoom
My Feedback: (9)
Default RE: HABU
Ill bet the controller is separate. What would be wrong with running a 100w CONTROLLER?
Old 02-16-2010, 01:38 PM
Ragz
Ragz's Avatar
Default RE: HABU
how much faster does the [plane fly with the new setup?  What speeds do you reckon the stock setup fly at with say a 35c 3000ma turnigy pack?
Old 02-16-2010, 02:05 PM
teg-1
My Feedback: (336)
Default RE: HABU
Good question I also would like to know as the upgrade
is not cheap to a already pricy jet
Old 03-18-2010, 02:59 PM
rolling_p51
Default RE: HABU
So what the best set up for some more speed ??? This thing needs more ....... WeMoTec ? and what motor ? or something else out there ?
Old 03-18-2010, 05:06 PM
bigplumbs
Banned
Default RE: HABU
That is almost exactly the same power as you get out of the lander 68 mm fan with the 3575 kv motor..... In fact it looks very much like the lander fan !!
Old 03-18-2010, 05:57 PM
quist
My Feedback: (198)
quist's Avatar
Default RE: HABU
ORIGINAL: bigplumbs
It is a relabeled unit. It does work well.
Old 04-01-2010, 12:15 PM
smchale
My Feedback: (67)
smchale's Avatar
Default RE: HABU
CF-Habu !!
Couldn't resist joining the fun. For those that know me, this color scheme was predictable. Inspired by the CF-5....actually this would likely make a good scheme for my Maverick one day as it resembles the CF-5.
Has a Schubeler DS-30 fan with Neu 1112/1Y motor for thrust, TP 45C 3250mha pack for fuel.
ID:	1409411   Click image for larger version
ID:	1409412   Click image for larger version
ID:	1409413   Click image for larger version
ID:	1409414   Click image for larger version
ID:	1409415   Click image for larger version
ID:	1409416   Click image for larger version
Old 04-01-2010, 12:31 PM
Bob_B
Bob_B's Avatar
Default RE: HABU
NOW that is a serious BIG Block setup!
Sean you are over the top!!! Nice work.
Old 04-01-2010, 12:34 PM
yeahbaby
My Feedback: (21)
yeahbaby's Avatar
Default RE: HABU
DUDE!!!! nice
Old 04-01-2010, 03:17 PM
SinCityJets
Default RE: HABU
Sean,
I would like to order two of those!
Chad
Old 04-01-2010, 04:23 PM
smchale
My Feedback: (67)
smchale's Avatar
Default RE: HABU
Chad, not much to it. Take your standard Habu, a couple Tamiya TS spray cans (gloss aluminum, bright red, flat black, flat clear). The graphics are dry transfers that getstencils.com ran off for me. Lines are a fine sharpy. weathering is watered down acrylic through an airbrush. A little planning and 2 afternoons of painting, etc and you're at the field flying!
Old 04-01-2010, 04:31 PM
t_burley
My Feedback: (59)
Default RE: HABU
you cant do nothing normal can ya Sean
I'll call ya this weekend, long time no talk
Old 04-01-2010, 05:41 PM
smchale
My Feedback: (67)
smchale's Avatar
Default RE: HABU
Agreed, too long. Looking forward to catching up. [8D]
