SM Viper Jet Rudder Clamp
Reply
Old 02-26-2010, 03:20 AM
ianober
My Feedback: (12)
ianober's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default SM Viper Jet Rudder Clamp
I am building a Viper Jet right now and the rudder clamp is a little unclear. Unless I have missed something in the instructions all it says is to slide the fin in and secure with a bolt. Well, I have tried all the bolts that came with the kit and none seem to fit. An M4 bolt is too small and an M5 bolt is too large. I am assuming that one side of the clamp is threaded but it is in too tight of a position for me to tell. Anyone out there have a quick answer?
ID:	1386978   Click image for larger version
ID:	1386979   Click image for larger version
ianober is offline
Old 02-26-2010, 03:50 AM
digitech
My Feedback: (10)
digitech's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: SM Viper Jet Rudder Clamp
ORIGINAL: ianober
we had the same issue,s on more vipers
it is chinese thread between imperial and metric.
the material isa bit soft what most people did was "upgrade"the thread to something bigger and DIY basicly
digitech is offline
Old 02-26-2010, 03:51 AM
Ali
Ali's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Be careful Ian, We just had one delivered to a customer and they had missed the thread out. He removed it and tapped a thread himself.
Hurry up and get this bad boy finished so that your build time is not one of Presta's excuses for why its not painted in time for Cali jets!
Regards Al
Ali is offline
Old 02-26-2010, 04:03 AM
DelGatoGrande
My Feedback: (23)
DelGatoGrande's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
just use a safety nut with your M4
DelGatoGrande is offline
Old 02-26-2010, 04:22 AM
digitech
My Feedback: (10)
digitech's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: DelGatoGrande
smart so when attaching the rudder you take out engine and thrust pipe first?
digitech is offline
Old 02-26-2010, 06:24 AM
DelGatoGrande
My Feedback: (23)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: digitech
i dont take out the fin in any of mine[&o] ..sorry
Old 02-26-2010, 07:38 AM
RCI/Skymaster
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What i did is used a 6-32 bolt and locknut. I JB Welded the locknut to the clamp and made a hole under the stab on the side of the fuse so i can remove the tail.
It's still workeing very well.
RCI/Skymaster is offline
Old 02-26-2010, 09:33 AM
Selleri
Selleri's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ian see > [link=http://www.rcuniverse.com/forum/fb.asp?m=9493545]http://www.rcuniverse.com/forum/fb.asp?m=9493545[/link]
Selleri is offline
Old 02-26-2010, 12:02 PM
Jim Cattanach
Jim Cattanach's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I used a bolt & nut that went through the hole, then drilled a hole each side of the fuz in line with each, so I can get a hex key in one side & a small socket in the other. I no longer take the fin off, as I bought a van to transport my jets.
Jim Cattanach is offline
Old 02-26-2010, 12:19 PM
ianober
My Feedback: (12)
ianober's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the replies guys, I figured I would be scr3wed like that. I guess it shouldn't surprise me. At least I am getting some good info on what NOT to do on my kit.
ianober is offline
Old 02-26-2010, 12:34 PM
Ron v U
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I was lucky, everything was OK and i had a screw in the kit.
As i already wrote in the other thread "Another Skymaster Viperjet", i just drilled a very small hole at the end
of the screw and then i twisted a thin iron wire in it, so once the screw is in the hole, you are able to tighten/loosen it, but it can't fall out anymore.
Regards Ron
Ron v U is offline
Old 02-26-2010, 12:57 PM
ianober
My Feedback: (12)
ianober's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks like yours is a newer clamp Ron.
ianober is offline
Old 02-26-2010, 01:03 PM
Ron v U
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i got my Viperjet last year october.
Regards Ron
Ron v U is offline
Old 02-26-2010, 01:22 PM
ianober
My Feedback: (12)
ianober's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yep, yours is definitely newer than this one. Anyways thanks guys, shame on me for thinking that something so simple should just work.
ianober is offline
Old 02-26-2010, 01:41 PM
Alex48
Alex48's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Id never rely on a bolt alone, the locking wire is a good idea. I'd put a temperature resistant aeronut on the bolt for added security.
Alex48 is online now
Old 02-26-2010, 03:26 PM
Duncan
Duncan's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That wouldn't work for this application Alex as most have the rudder post removable for transport. With no vibration on a jet, a bolt is sufficent for those that remove the rudder for each days flying.
I had the same clamp and bolt as Ron and did the same mod, although mine has an aluminium bar for the front location pin, which I tapped and drilled for extra security, which is how all of the Vipers Ali has had have been done.
Duncan
Duncan is offline
Old 02-26-2010, 05:25 PM
Alex48
Alex48's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ahhhh fair enough, I keep the fins on for transport. My middle name is 'over engineered' anyhow............Still recovering from Ali's request to have his wings held on with M4 wing nuts................
Did you ever finish your Viper? The thread on the other forums gone a bit quiet.
Cheers, Alex
Contact Us Archive Advertising Cookie Policy
