Reload this Page >
SM 2M Viperjet pipe diameter please.
Old 12-22-2010, 08:20 AM
furloughed ual
My Feedback: (31)
furloughed ual's Avatar
Default SM 2M Viperjet pipe diameter please.
I need the inlet and outlet diameter of the SM pipe that is included with the ARF. If anybody has one they can measure it would be greatly apprreciated.
Ryan
Old 12-22-2010, 08:36 AM
Couch Potato
Couch Potato's Avatar
Default RE: SM 2M Viperjet pipe diameter please.
I measured mine in metric, sorry !
Dual walled pipe, tapered
Inner ID 85mm at front
Inner ID 70mm at rear
Inner wall thickness 1mm
Outer OD 100mm at front
Outer OD 85mm at rear
Outer wall thickness 0.05mm
Length inner 590mm
Length outer 562mm
Inner pipe is recessed from outer at the rear by 10mm
Bellmouth ID 83.8mm
Bellmouth OD 112mm
Bellmouth depth 28mm
Total length with Bellmouth pushed home 610mm
My kit is a version 2 delivered a couple of months ago, early versions may differ.
Old 12-22-2010, 09:06 AM
furloughed ual
My Feedback: (31)
Thanks...much appreciated.
The inner and outer pipes should not be flush at the rear of the pipe. The inner should be shorter than the outer for cooling. U might wanna check with SM about this...none of my other SM pipes were ever flush at the exit. Sounds like u got a bad pipe.
Old 12-22-2010, 09:15 AM
Couch Potato
Oops, my mistake, blind old git.
You are right, the inner pipe is recessed at the rear by 10mm
I've edited my original post to reflect this.
Old 12-22-2010, 09:17 AM
furloughed ual
My Feedback: (31)
Old 12-22-2010, 11:54 AM
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
ORIGINAL: Couch Potato
Length inner 590mm
Length outer 562mm
Bellmouth ID 83.8mm
Bellmouth OD 112mm
For those who like inches
Inner ID 85mm (3.34”) at front
Inner ID 70mm (2.75” ) at rear
Inner wall thickness 1mm (0.039”)
Outer OD 100mm (3.84”) at front
Outer OD 85mm (3.34”) at rear
Outer wall thickness 0.05mm (0.0019”)
Length inner 590mm (23.2”)
Length outer 562mm (22.12”)
Inner pipe is recessed from outer at the rear by 10mm (.394”)
Bellmouth ID 83.8mm (3.3”)
Bellmouth OD 112mm (4.4”)
Bellmouth depth 28mm (1.1”)
Total length with Bellmouth pushed home 610mm (24”)
Old 12-22-2010, 01:07 PM
Couch Potato
ORIGINAL: RCISFUN
Oh no, you'll be quoting fractions next like 13/64"
No wonder your B2 is 2.54 x bigger than it should be.
Old 12-22-2010, 01:19 PM
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
ORIGINAL: RCISFUN
Oh no, you'll be quoting fractions next like 13/64''
As so not to disappoint....
File Type: pdf
Old 12-22-2010, 02:24 PM
rcjets_63
rcjets_63's Avatar
ORIGINAL: RCISFUN
ORIGINAL: RCISFUN
Rich, did you figure that all out on your combo snow shovel/calculator (scientific version)? No A.C. engineer is ever without one, at least during the winter.
Cheers,
Jim
