Fly Eagle Jet F16 1/8 Advanced
RE: Fly Eagle Jet F16 1/8 Advanced
sorry to see the crash pictures plauto...it is sad indeed to have this kind of damage due to a hole...it was the doomed 13th flight though!!
ORIGINAL: lookilook
I sent the wings, stabs and fin back to China today.
CA
Hi,
Have anyone own the FEJ f-16 1:8 scale standard version? I just wonder if the standard version canopy is operational like the advance version...
Some folks said the standard version canopy is operational like the advance version the difference is just the landing gears and some folks said
the standard version canopy is not operational it is a fix canopy. I am getting ready to purchase the standard version if the canopy is operational.
Any iput is greatly appreciated.
ORIGINAL: igniter3
Hi,
Hi,
No, I leave it that way. The dry weight was between 11-12kg.
I did the in flight CG test suggested by Kmart. 45 degrees going up inverted. The plane acted normal... didn't try to dive.
It had a very happy flight.
#36
Sorry about your misshap, that really stinks and rotton bad luck.
I too have one of these that i`m hoping to get flying for the summer although i was planning to use a p-70 in it, after reading this i`m not so sure now.
I hope your model is back in the air soon.
Take it easy
john
Take it easy
john
#37
OK I have just bought a Fly eagle F-16 in the orange tiger meet colours second hand, but it was really cheap so I couldn't resist, its version 2 I think, as it has the modified elevator controls (dose that mean the advanced one?) it has up rated door rams too, if you hadn't guessed already this is my first scale jet and what I know about jet turbines I could write on the back of a postage stamp, but i have been flying high performance 90mm EDF jets for over three years (i have six in total) plus i have a large 120 spitfire and a large p-51 mustang, so I should have the flying capabilities to handle larger heavier jets me hopes, ok a couple of questions, what power plant would I put in this? I have always over powered pretty much all my aircrafts as i would rather have too much than not enough, what servos are good (the recommended ones) and i have been looking at the Fly Eagle Five Action Multi-function Valve, are these any good? and any hints on dos and don'ts would be great.
thanks Jim
thanks Jim
#38
My Feedback: (48)
Fly Eagle jets tend to be a bit heavy. My 1/8 F-16 weighs 21 lbs. dry. I've been flying it with a Wren SS (18# thrust) and found the take offs to be long and I was at or near WOT all the time. I wanted more thrust but didn't want any extra weight so over the winter I installed a Merlin 90. It weighs same as the Wren but puts out 21.5# thrust.
I'm anxious to fly it with the new engine but am waiting for the field to dry out and weather to improve. Check out the Merlin 90. Here's the video that convinced me this would be a good combination: http://www.youtube.com/watch?v=HD-7i6xrXpg
Joe
Joe
#40
ORIGINAL: j6myw
thanks Jim
thanks Jim
The FEJ valves work fine, you will need a hi-tork servo por each elevator, for the ailerons you could use something like the DS8411 and for the rudder you will need a mini, I'm using DS3421.
The model fly very well with a 20lb engine, but now you have more powerfull and light weight options, like the jetcat 120.
If yours have the fancy landing gear it is the advanced.
#41
My Feedback: (48)
He model fly very well with a 20lb engine, but now you have more powerfull and light weight options, like the jetcat 120.
I guess I'll find out when I fly mine, but after flying it with a Wren SS a 20-22 pound engine seems about right and the M90 weighs about a pound less than a P-80 or JC Falcon.
Joe
#42
My Feedback: (67)
What is the difference between version one and version two f-16? I know they updated the scale retracts and the ram cylinders.
I just purchased a non-advanced version one that was on sell thru troybuilt. It's the earlier style as it only has the two tanks with it and I am sure it is like 1.5 years old sitting in there warehouse.
Is there anything I need address besides the retracts, ram cylinders air leaks? Did they change something in the elevator setup?
Hi all, you can see my FEJ F-16 1/8 on :
Build : http://www.dauch.fr/montageF16P1.html
Test : http://www.dauch.fr/volsF16FlyEagleJet.html
Videos : http://www.dauch.fr/video.html
Best regarrds
Frédéric Dauch from France
www.dauch.fr
Best regarrds
www.dauch.fr
#46
Perfect... sometimes the locking piston jam, but nothing serious…
By the way, I did my 13TH/B flight….
Check out the video….
http://www.youtube.com/watch?v=4GhbhOMaA-0
But it is ready to go again!! Thanks to the half fuselage I had from the first crash.
#48
Plautos, as with the Skymaster F-16 1/8, this jet has a tucking tendencyduring a turn, when tanks are full.
What I can see on the video is that once on the air, maybe the right wing stalled making the jet to bank right, and once banked, the nose tucked to the right making it to loss altitude.
You can fix this tucking tendency with tanks full, by moving the C;G afto to 175 mm.
I lost my furst F.16 because of the same reason.
Now, my C.G is at 170mm
BRG
