Diesel and 2 cycle oil for over a year
RE: Diesel and 2 cycle oil for over a year
http://www.youtube.com/watch?v=JX2u6...eature=related go to 3 min 20 sec ..you are right soot is carbon ..my point was that the carbon build up is caused by lack of oxygen which is not an issue in our turbines....all fuels are hydro-carbons...in the vid you will see the effects of oxygen...I liked this experiment alot myself [8D]
ORIGINAL: geneh-RCU
How much 2 stroke oil do you mix with 5 gal? Do you still use 5% or is it less?
Hi guys,
I have Jetcat P-80se, JJ3000 and ATJ 120Ti.
What do you say about the liqui-moly http://www.liqui-moly.de/liquimoly/p...id/e_1233.html
Worth buying ?
Worth buying ?
#31
ORIGINAL: BaldEagel
I'v been toying with the idea of using 28 second heating oil (Kerosene) in my turbines, but have not plucked up the courage, I hoped someone else would be first. [
Mike
Mike
Mike
I've been using it for 8 years along with both DTE light and normal turbine oil. Zero problems.
Jason
#32
My Feedback: (7)
Dave:
Apparently Jet-A contains more sulfur than Diesel.
http://www.generalaviationnews.com/2...s-diesel-fuel/
What do you think?
Juan.
What do you think?
Juan.
