Silane for air-starting?
CA
RE: Silane for air-starting?
ORIGINAL: Todds Models
http://www.modelaircraft.org/files/0...regulation.pdf
7. Fuels are limited to kerosene and/or propane unless approved in writing by AMA.
My Feedback: (8)
ORIGINAL: InigoMontoya
I couldn't care less about the AMA. I'm not under their jurisdiction.
CA
If you're self-insured, you had better own a few buildings and ten or twelve golf courses (to cover the law suits) if you're going to fly jets.
CA
Not sure of your intent there....
Are you saying that non-hobby apps are not welcome for discussion on this board (which I think I've been pretty clear I'm not coming from the hobby world from very early in the thread) or is that a political statement?
#31
My Feedback: (8)
You're apparently very happy just letting us know how intelligent you are and that you are going to do whatever you're going to do no matter what advice we give you.
Go blow up a few turbines...have a ball
Bye, now!
#32
CA
ORIGINAL: rjbob
Actually, non-hobby threads are NOT really welcome here as this is a hobby based forum.
#33
Come on gents, what happened to tollerance, I would have thought a rapid and safe start cycle would be of interest?
I will try to give some humble advice, though I don't regard myself as any kind of expert.....the biggest problem I think will be the differential expansion rates between the turbine wheel and the nozzle guide vanes. A very rapid rise in egt causes the lower mass wheel to expand quicker than the larger mass ngv's which can lead to blade tip contact and seizure (tip clearance is typically 0.10-0.15mm and reduces during a normal start sequence). The combustion chamber and other components also require time to heat up to achieve correct combustion, etc.
Airstart turbines do have the capability to shorten the start cycle because of the greater power available and also their localised cooling effect. Maybe a combination of multiple turbine impinging airstart nozzles and Silane could give a quicker start but I have no idea if you could achieve what you are looking for.
How do the engines you are used to dealing with get round these problems?
Rob.
Rob.
#34
Fair enough. Do you have another forum to suggest that closer matches my inquiry?
ORIGINAL: rjbob
In the first instance I feel I must appologise for some of the intolerance that has been shown to you on this thread, a lot of contributors on here do not read the whole thread, but just scan read, so they may not have realised that when you say AIR START, you do not mean running up a turbine to speed with an air gun, but starting a turbine in mid air, hence your requirement for a fast start.
Personnaly I have found the disscusion interesting, even if not hobby related it will give us a different perspective into our turbines and their use outside our normal applications.
Mike
#35
1 Post
I second the last two posts, and again although I have almost no knowledge of turbines my suggestion would be to discuss the matter with a company who might just know the options and answers to your questions.
My suggestion would be AMT turbines, and the man in the know there is Bennie, the problem might be getting hold of him as he is a very busy man, good luck.
marcs
marcs
#36
FL
I'm not sure I get your point. We're talking about replacing one fuel with another, not replacing an oxygen source with an inert gas.
Or are you trying to imply that silane can't work as an igniter (to which I would have to laugh and wonder why you would assert such a thing given that it serves that function in a number of systems on a daily basis)?
ORIGINAL: Harley Condra
One time long ago, when I was running air start engines, a know it all spectator asked me (in all seriousness I might add), why we didn't spin our engines up on dry nitrogen instead of compressed air. After all, he said ''Dry nitrogen is cleaner than compressed air, and won't introduce any water vapor into the engine during the start process''.
Duuuuh....
I replied that since dry nitrogen is an INERT GAS, just how in the hell do you intend to start a fire in the absence of oxygen?
Duuuuh....
I didn't imply or assert anything about silane. I never mentioned the word silane.
You are the only one that didn't get it. Most of us that actually fly turbines, will get asked that question or another equally stupid question now and then.
My question to you is: Why would WE want to change from propane or Powermax to something that is probably more difficult and expensive to obtain, when our current starting gas works just fine.
The gasses we currently use are proven, inexpensive, readily available, and their hazards are well known, and they are probably less dangerous.
Now, do you get it?
#38
My Feedback: (7)
I find it intresting that you don't care how many engines you destroy, but by-god it's gonna start in 5 seconds !!!!! [sm=confused.gif] As far as your self insurance.. ( The U.S. Goverment ) who in the hell do you think IS the U.S. Goverment ????? US.. The people of this great Nation. Sounds like to me you and your people got a hold of some OUR stimulus money and have to spend it on some hairbrained idea like this. This sounds alot like the Midwest college that got a $450,000.00 grant to do a study on how a Housefly lands on the ceiling... Does it roll and stick, or does it loop and stick ????? WHO CARES !!!!! Get the damn fly swatter and kill the S.O.B. !!!!! Your wearing me smooth out !!!!
Dan M.
P.S. as far as you inflight restarts of Model Turbines... I have witnessed it done many times with a Jetcat in a BVM Bobcat by Mr. Tom Dodgen.
Dan M.
#39
After reading the WHOLE thread.
1) This guy isn't trying to build something for Florida Jets or Top Gun.
So, I doubt you have to worry about this showing up at your field and going through your RV window.
2) This is either private sector or a govt. contract/grant money to move forward with some research.
3) If item #2 is correct, what makes it so hard to beleive that a $4000 turbine wouldn't/couldn't be viewed as disposable.
Cruise missle/ target drone powerpalants are much more expensive and are every bit as disposable.
4) Their are some narrow-minded, intollerant *****$ in this world.
Just because we fly RC jets doesn't put us at higher station in this hobby . . . . much less in life.
It doesn't mean we're smarter. It means we can afford it . . . that's all.
Heck, it doesn't even mean we have better flight skills.
I've been to several jet meets where people were told not to fly over XYZ spot. But, I saw it repeatedly because people couldn't fly a right-hand or left-hand pattern.
Which two waiver holders signed off on those guys ?
His question was simple. . . .
Does anyone have any knowledge of or have experience with Silane in small hobby sized turbines.
I guess his answer is No.
#41
What are you guys on? I can see very little in the way of constructive help from most of the replies. If you don't have something helpful to say then maybe it's best to keep quiet?
As for the original question, I have absolutely no idea what Saline is but would question the figures you have on start times. A kero start engine might be that slow but, at a guess, I would say a propane start is much quicker than 1 minute. You won't get the 3-5 secs you mention but what is the maximum time that would be acceptable?
#42
CA
That said, the turbines I'm familiar with employ pyrotechnics. The pyro charges all go more or less simultaneously. One blows open the fuel supply. One is a gas generator that spins up the turbine pronto-like. And one is an igniter. They start FAST. If I had to guess, I'd say that they just build to lower tolerances and just take the efficiency hit.
ORIGINAL: marc s
Now, do you get it?
Now, do you get it?
#43
My Feedback: (14)
After catching up on what I thought was a troll trying to wind us all up and laugh at us (which still may be what is going on here, and if it was, he has succeeded very well), let me try something constructive just for the heck of it.
If the problem at hand is how to quickly re-start a turbine in the air (vs. what I originally assumed, using compressed air vs. electric motor to start on the ground .. that's what we all call "air start"), then I'd suggest the following:
1) In my observations, start time has little if nothing to do with the time to ignite the starting gas (propane or powermax butane/propane mix). It has to do with the feedback loops and control system in the ECU being careful about sequencing the start to avoid damage from overtemp, or flooding the motor with kero if the propane is not burning, etc. So changing to a gas that ignites faster is not addressing the actual issue creating the time to start... if the definition of "start" is the user gets control of a stably running turbine.
2) Kerostart is much slower than gas start .. so probably not a candidate here. Reason is that it takes time to preheat the ceramic igniter (which has to be big enough to have a sufficient thermal mass so it does not cool off immediately when kero mist is sprayed on it). On the JetCat and Behotec turbines I have run, this takes 10-18 seconds, and the whole start cycle is slower than gas start.
3) A practical first step would be to make some actual measurements on a COTS turbine, and begin to understand what makes up the "start time budget". You'd do this at first by simply observing the start process with the monitor box plugged in. Then you'd have some actual knowledge about where the time is spent and what it would take to reduce it. You could easily accomplish this with a trip to the local jet flying field, without having to purchase a motor.
4) I'd then contact a few of the folks who build the ECUs and see if one of them (JetCat, Gaspar Espiell, ProJet) would be interested to work with someone on a specially programmed ECU that had a fast start mode that reduced a lot of the safety/protection features to do a much faster start in an application that could tolerate much more risk to the hardware.
I believe this would be a more constructive path to follow than dumping a "sound byte" post and then getting aggressive with people who are seeming not to be helping enough.
A more polite and productive approach would have been to state the problem trying to be solved up front, then review what work and thinking had already been done. That would have generated a qualitatively different response from the group. I'll bet they would have been standing in line to help if treated with a modicum of respect vs. a smart-alecy post.
It would also be the sort of behavior that a properly-trained scientist or engineer would display.
FWIW,
Dave
FWIW,
Dave
#44
CA
ORIGINAL: rcjetsaok
ORIGINAL: Vettdriver
1) So, I doubt you have to worry about this showing up at your field and going through your RV window.
2) Right now it's neither. A few of us engineers are observing a particular methodology and we think it's obsolete. We believe we have a better way (read: cheaper). So we're looking into an experiment that either will or won't prove our point. There is currently no money at all. On our own damned time (the "OMG, my tax dollars" crowd can kiss my ass) we're trying to put together a proposal for some discretionary funding (at which time that crowd can complain but since the goal is to spend say $100k to save many millions over time, my sympathy for them is minimal).
#45
CA
If the problem at hand is how to quickly re-start a turbine in the air (vs. what I originally assumed, using compressed air vs. electric motor to start on the ground .. that's what we all call ''air start''), then I'd suggest the following:
1) In my observations, start time has little if nothing to do with the time to ignite the starting gas (propane or powermax butane/propane mix). It has to do with the feedback loops and control system in the ECU being careful about sequencing the start to avoid damage from overtemp, or flooding the motor with kero if the propane is not burning, etc. So changing to a gas that ignites faster is not addressing the actual issue creating the time to start... if the definition of ''start'' is the user gets control of a stably running turbine.
3) A practical first step would be to make some actual measurements on a COTS turbine, and begin to understand what makes up the ''start time budget''. You'd do this at first by simply observing the start process with the monitor box plugged in. Then you'd have some actual knowledge about where the time is spent and what it would take to reduce it. You could easily accomplish this with a trip to the local jet flying field, without having to purchase a motor.
Oh, and somebody asked where I got the "1 minute start" number. Of course I can't find it now, but I was watching some youtube video of a JetCat start sequence on the recommendation of a user from another forum. They were all indicating start times of about a minute and the video corroborated that. Yes, it was a bench test, not an inflight start (there, I'm even using your terms!), but it was the best data I had to go on.
And no, I'm not a troll.
#46
ORIGINAL: rcjetsaok
Dan M.
Dan M.
#47
I asked him, ''If you don't know, who does, and how do I talk to that person?'' He named a Bob Wilcox and said to call after 10:30. Only problem with that has been that by 10:30 I've been in the field several hours and quite frankly don't often find myself in a position to have the kind of conversation I need to have (an office environment with a desk and such is nice, yaknow? ...but I'm typically out of my office by 8:00).
#48
CA
Missed this post on the first couple passes....
That's actually a damned good question. I use the 3-5 seconds (actually faster, I suspect but it's been a while so I'm willing to allow for fuzzy memory) as a benchmark of what's possible since I've seen that in the past but that doesn't mean it's a hard requirement. What is? Not sure... But figure I've got a heavy weight low-lift vehicle at reasonably low altitude that's gonna crash if I don't get that engine going. 1 minute is right out. 15 seconds? I dunno... I'm not comfortable with that number but if it turns out that this is the best that can be done with off the shelf perhaps I could just boost to Mach 0.5 with a planned Mach 0.3 takeover? IE, just overspeed the boost (reasonably easy to do) and just plan to slow way down before the turbine is up to full throttle.
BTW, I want to thank those who've responded this morning. I came back just to see if anybody had another forum suggestion. To see that there was additional discussion was a pleasant surprise.
ORIGINAL: siclick33
#49
My Feedback: (39)
IL
No matter what fuel you use to warm up the chamber its going to more costly then propane.
More exotic means much more danger and more cost, 15 secs is not alot of time. When all else fails KISS it .
Keep it simple stupid. [&:]
#50
My Feedback: (10)
Not sure, honestly. On another forum (before I found this one) I was asking questions and folks were talking about a typical start up time for a JetCat (unsure of what model) taking about 1 minute to full throttle. And the idea isn't to increase start up time, it's to REDUCE it. How? Well, as I understand it (and maybe I'm wrong, that's why I'm here asking questions) the propane is used to heat up the combustion chamber. But even that takes time as the propane is lit via a glow plug, you need the right fuel/air mixture, etc. The idea of using silane is basically to short circuit the ignition of the propane. As silane is pyrophoric you have IMMEDIATE ignition of your heater gas. No need to heat a glow plug. No worries about fuel/air mixture (within reason). Just start dumping silane and your combustion chamber is on it's way to hot.
Heck, run a small quantity of silane instead of current to your glow plug and you may be able to go instantly to kero. No need for preheating at all.
ORIGINAL: Ruizmilton
I have an airstart turbine that reaches idle in about 15 - 25 seconds after propane lights up, and to me that's a looong time, what turbine model are you talking about? Model turbines only use propane to heat up the combustion chamber because they have no actual fuel vaporizers, not for thrust generation or chamber pressure or anything on that line, can't see how you intend to increase start-up time by replacing propane with some other fuels on a kerosene burning engine, can you explain?
its all done in the software you can heat what you want it wont go faster.
it will use some timings in how long from igniton fase to fuel ramp
Fadec ecu,s this trick might work since it ramps as soon the temp gets to a pre set temperature.
but then this can also be done with propane.
in the past on some older versions of the jc ecu i could control lots of settings and could influence some timings like starter cut off rpms,.
but the good thing is with jc ecu,s that they come preset for any kind of turbine they have.
so my tip dont go there.
jc makes drone turbines p-200SX , they are started a bit different i think .
so stick to but/prop mix wich cost almost nothing at any supermarket
