Need some help finding a Tool for our CNC
My Feedback: (39)
RE: Need some help finding a Tool for our CNC
I suspect you will need someone to custom make you a broach for each style of spline for the various manufacturers. I have found various brands of horns must have different specs for the broach as some seem to slip right on and others need some pressure to fit onto the servo spline. I prefer the ones that need some pressure as they tend to have no slop.
You will also need a method of "clocking" the tool so each horn is oriented to the servo splines correctly and consistently.
PaulD
PaulD
My Feedback: (10)
ORIGINAL: PaulD
You will also need a method of ''clocking'' the tool so each horn is oriented to the servo splines correctly and consistently.
PaulD
PaulD
the clocking is no problem we can rotate at 1 degree at a time.
so if anyone knows who can make us those tools we would be gratefull
Try this company, i am sure that they can help you. I have been using them alot before.
http://www.unimerco.com/
Sandor
Try here: http://www.rotarybroaching.net/broaching101.htm they may be able to make the tool required.
If not these people do internal spline broaches: http://www.alcesterbroach.com/?gclid...FRg-lAod9A08_A
Mike
Mike
FL
Try www.pioneerbroach.com
They have been in business in Los Angeles for many years...
