Are these real???
A Delta Connection Bombardier CRJ-200 caught fire while the crew was preparing the aircraft for takeoff in Tallahassee, Florida on Saturday. The incident, on Flight 5563 to Atlanta, happened about 30 minutes before takeoff and no one was hurt. No passengers had boarded the 48 passenger aircraft at Tallahassee Regional Airport, but bags were already on board and crewmembers on board were running pre-flight checklists.
As the crew ran the checklist, the pilot noticed smoke coming out of an area between the pilot’s seat and the galley. The pilot and a flight attendant, the only ones on board at the time, evacuated the plane and firefighters arrived quickly to extinguish the flames. According to firefighters at the scene, the fire was at its strongest behind the pilot’s seat. The fire left a 6 by 18 inch hole in the airplane.
The National Transportation and Safety Board (NTSB) is investigating the incident and have not released any information yet. In a press conference, however, a firefighter said he believed the fire was in an electrical area. Of course, firefighters aren’t aircraft accident investigators so we’ll have to wait and see what the NTSB says about this.
The ground power supplied to the airplane shorted out, and started a fire behind the captain. There's an O2 mask for the jumpseater, and the O2 lines that supply it run behind the captain as well. When the fire burnt through the line, it got pretty toasty! It was an ASA CR2 in Tallahassee; the Capt. and the FA were the only one on board and they escaped. FO was doing the walkaround. A/C had ground power issues before - the plane didn't want to take it - and apparently the ground crew was trying to force the power to stay on the plane.
blowing on the ground that day. Look at the burn pattern flowing toward the rear of the aircraft.[:-]
It's definatly an O2 fed fire. There could have been a wind that morning, but have you ever seen an O2 fire before?...............thought not.
And no I don't think they are real.
Enjoy
Mike
For those of you who where dissapointed: http://www.authorstream.com/Presenta...pt-powerpoint/
Enjoy
Mike
And Dlach the bottles on planes are in safe spots and yes they have shutoff valves but I know on most of the planes I work on you open them up before flight. When your over 45 thousand feet and the plane looses pressurization you only have seconds to get a mask on or you are going to sleep. Just like the Pain Stewart crash.
O2 fed fire when it burned through the supply line. The bottles are always left open except for maintenance, and the ones in the pass cabin are seperate O2 generators (on larger aircraft) the crew still uses a seperate bottle. It's totally seperate from passenger supply. The only ones that have bottles are smaller commuter planes and corperate jets - and even some of them have seperate crew bottles.
I have witnessed an O2 fire - it's just like a blowtorch when it gets going. The aftermath was not pretty.
