2m ViperJet U/C
2m ViperJet U/C
Hi,
What are you using, the straight stock oleos or trailing link ?
If you fitted trailing link, were any mods required for the retract mount, wheel wells and doors etc.
Ta very much.
Ta very much.
RE: 2m ViperJet U/C
Couch potato, if you have your viperjet then give sandor at digitech a call as he is needing the u/c to make a set of trailing links for the a/c. I was planning on sending my u/c when i get it but no sign of v2m yet although it should be soon
Forgot to mention they would be a drop in replacement i believe so no bodging!
RE: 2m ViperJet U/C
I have the 2m VJ on order, so no retract set to send to Sandor at this time.
I'm sure Ali's 2m VJ had trailing link oleos already, maybe I imagined it, I'll ask him.
