Feibao T-33 build
RE: Feibao T-33 build
Engine IQ-Hammer 180+
Servos:
Aileron & Flaps Graupner DES707
Elevator & Rudder Hitec HS7955TG
Nose steering JR8411
Powerbox Champion RRS
Powerbox Smokepump
2x Fasst R6014
2x 2s 7,4V 2600mah 30C Receiver
1x 3s 11,1V 2500mah 15C Turbine
EV5U-Pro
IQ-Hammer Coolpipe 100mm
Carbon-Controls from Digitech
Air-Connector from Digitech
UAT from Digitech
6,2 Liter fuel
2,0 Liter smoke
Servos:
Powerbox Smokepump
2x Fasst R6014
EV5U-Pro
UAT from Digitech
6,2 Liter fuel
2,0 Liter smoke
I,m building one now, and on Mick's advice I have moved the engine forward, so it is sitting on the CG and I am getting a longer pipe made up. This way you can avoid putting a church roof of lead up the nose and keep it under the UK weight limit (20Kgs).
Nice install though.
John
John
Hey Mick, yep see you at Pampa
John, moving the engine forward in that small area around the cg will not save you a lot,
but a tube over 1 m length isn`t a good choice (even Diddi made it) , just my opinion
i3dm, its 20 cm behind the engine exaust nozzle
Have you guys noticed that it can carry !!!!! 11 Liter !!!!! fuel
3.1 Liter in each side tank and 5,15 Liter in the Main,
so i only install the side tanks in the cg and throw the main tank away ....
ORIGINAL: Eagle Driver
John
