Reload this Page >
Needed Airworld 1/5th scale L-39 Main Fuel Tank
Old 07-20-2010, 05:54 PM
turnnburn
My Feedback: (49)
Default Needed Airworld 1/5th scale L-39 Main Fuel Tank
I would like to try to put an Airworld L-39 main fuel tank in my Jet Legend L-39. Anybody out there done this or know if it will or will not work ?
I need the main tank for the Airworld 1/5 scale L-39 if anybody has one to sell or knows of somebody who might have one.
Old 07-21-2010, 09:44 AM
modtron
Default RE: Needed Airworld 1/5th scale L-39 Main Fuel Tank
Take a look here......
http://www.vogelsang-aeroscale.com/a...dalbatros.html
All meant to be in stock.
modtron
Oxford UK
Old 07-21-2010, 04:39 PM
Mike Pascoe
My Feedback: (13)
Mike Pascoe's Avatar
I have one brand new! send me your address and its yours.
Old 07-22-2010, 02:08 PM
Hawk_292
TurnnBurn
I have both the JetLegend L-39 and the Airworld L-39. The tank for the Airworld L-39 will fit into the JetLegend fuselage if you make the hole bigger. The width is fine, the tank is less than 6 inches wide, but it is over 8 inches tall so you will need to remove a bit of the bulkhead behind the rear seat to get it in. It is the same length as the JL tanks - 8 1/2 inches so pipe fittings should be fine.
For greater fuel capacity for the JL L-39 I fitted a third tank above the 2 standard JL tanks. So now it holds nearly 4 ltrs of fuel or can use the same third tank for smoke oil rather than fuel.
The Airworld tanks can have pin-hole leaks so it is worth leak checking it before you fit it.
TC
Old 07-25-2010, 01:40 PM
StuartMackay
Hi I have got a brand new tank for sale at £75 plus postage.
Stuart
