Sport jet plans for 12lbs turbine
Hi,
As i'm approaching the end of the build of my LAVI plane (powered by a RAM500), i started thinking about the next project to occupy my workbench.
because i have another RAM500 gathering (balsa) dust, i decided to build a sport jet that will be powered by a 12lbs-14lbs blower.
i am looking for suggestions and plans for a decent airframe that i will be able to build from scratch, i have no problem building (actually, take great pleasure with it).
was thinking something along the lines of the Balsa Bandit or similar sport jet, something with curves
although i know there are some great flyers like the turbinator, dv8r ect... i'd rather build something with a rounder shape and curves.
so, if any of you have any idea or suggestions, it would be appreciated.
and if you have a set of plans that you can share, it would be great.
thanks
Ravivos.
thanks
Ravivos.
RE: Sport jet plans for 12lbs turbine
thanks George, but i was thinking more of a full fuselage and swept/tapered wing design.
perhaps ill just slice down my multiplex Funjet, multiply the parts by 2.2 and build a Big ***** Funjet ...
any other ideas or plans?
http://www.rcuniverse.com/forum/m_75..._1/key_/tm.htm
ORIGINAL: erbroens
Perhaps you can find some inspiration and use Bob´s method for rounding a fuselage, whatever design you choose:
Not plans but some short kits here that are scaleable to other sizes..
http://www.laser-design-services.com/
bob is online here as well.
