New FEJ F14 1/8.5 for single and twin version
Hi All F14 fans:
FEJ is producing a small F14 1/8.5 scale with single version and twin version.
For those fans who are interested in this one, We will have them to the Jet Power 2010 show.
The releasing date will be around August 21th. More information can be found at our website soon.
James
RE: New FEJ F14 1/8.5 for single and twin version
Hi All:
Here are couple photos for the F14 1/8.5 scale single engine.
The singleenginedry weight is about 18kg (39.6lb). Twin version will be about 19kg (41.8lb)on dry weight.
More information and photos will come soon.
James
The single engine dry weight is about 18kg (39.6lb). Twin version will be about 19kg (41.8lb) on dry weight.
How do these weights stack up? Is this airframe only weight without turbines etc? If not, does adding a second turbine & onboard equipment plus additional structure/thrust pipe etc really only add 2.2lbs???!?!?!
My Feedback: (23)
ORIGINAL: schroedm
James,
Hi Schroedm:
For your question as below: This is the weight we calculate with Jet Central Rabbit engine and Behotic 180 engine.
single engine pipe 1000g
twin engines pipes 550*2=1,100g
different about 100g
extra items for twin
Rabbit1000g x2
Behotec-180 1750g
Pump 60g
valve 60g
UAT 60g
ECU 35g
wire 45g
tank 150g
battery 150g
engine former 50g
bypass 65g
Of course, if having different engines, they should have different weight.
James
Hi All:
Afew photos to see the F14 1/8.5 scale
We have one F14 1/8.5 scale single versionat Jet Power 2010. People can take a look there.
James
The bifurcated pipe will lose loads of thrust with that sort of set up......but happy to be proved wrong....looks nice though
My Feedback: (15)
CA
I would like to see the pipes configuration.
Its gonna have to be similar to like how the single Mig 29 pipe is. And it might help if they cheated a bit on the center section by making more room.
James, do you have any pics that look up into the body from the tail, that might explain it better.
My Feedback: (23)
You can tell by looking at the bulkhead just aft of the turbine and the center section of the fuselage between the exhaust nozzles its ALOT thicker in the center section. I would say at a minimum 3" where the turbine is positioned.. Looks good though for a stand off scale airplane
My Feedback: (51)
Who needs a tail pipe ? as you can see there is no pipe in the pictures.
Bolt up your big turbine in the middle of your F-14 and there you have it - a single engine F-14 ! or is that not the way it works ?
Now to be more serious - please do provide some pics of the tail pipe assembly.
My Feedback: (75)
CA
It was a pleasure dealing with all 3 of you! Now I can't wait to see them at the shows out here and KJ. I just ordered a new A-7, but I'm sure I will get the bug again to have a big cat in the stable once I see you guys out there!
Thanks again..
Lowell
Thanks again..
Lowell
Ravill - wait before u buy the electric retracts. My retracts on my f-14 and mig work flawlessly. The f-14 can hold air for hours no leaks and all original fej parts
hi friends:
If you see the web of Flyeagle you can find photos of the single engine, I like more the 2 engines, sorry but this single version not is a F-14, for my this not is an option.
Like the F-18, F-15, Mig-29 and other models in single engine version the scale shape is the same, but in the F-14....
BR from Spain.
Carlos Márquez.
_____________________________
http://cmjets.blogspot.com/
BR from Spain.
Carlos Márquez.
