My scale 1/5 F-16 B
Reply
Old 06-19-2012, 08:11 AM
  #326
k_sonn
k_sonn's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: My scale 1/5 F-16 B
Hi Peter.  Very nice project.  I have a couple of questions.  What did you use to make the formers for the speed brake plug and what material did you use to fill in the space between the formers?
TIA,
Kirk
k_sonn is offline
Old 06-19-2012, 09:01 AM
  #327
Peter Coers
Peter Coers's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Kirk, I made the formers from the same alu I use for sheeting. This works quick and the filler is polyester filler, the same u use in a car body shop. At last I put 3 layers of 200 gr on the form.
Grts,
Peter
Peter Coers is offline
Old 06-21-2012, 02:11 AM
  #328
Peter Coers
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The side of the speedbrake is finished also, next step is the other side.
Old 06-21-2012, 08:12 AM
  #329
argyris
argyris's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I used to believe that Mr Robertus Vitaly and his awesome YAK is the ultimate jet build ,and it is, but with a lot of digital help and money!!!But here you have a pure talend and only!!!You and Mr Harald Haf with SU27 project are my new high stadard !!!builders.
argyris is offline
Old 06-21-2012, 08:55 AM
  #330
Peter Coers
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Argyris, thats a big feather in my .......... , glad that you like it so much.
Greetings,
Peter
Old 06-21-2012, 10:09 AM
  #331
-JC-
-JC-'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Outstanding work Peter. Best surface detail I've seen.
-JC- is offline
Old 06-26-2012, 02:50 AM
  #332
Peter Coers
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks all.
Left side speedbrake is also finished, the sideplates are the next step.
The black spot on center under (picture above) is not of a marker but is a hole. There are more of these on the plug, they are water drains.
Old 06-28-2012, 10:50 PM
  #333
olnico
olnico's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: argyris
Vitaly was working with the Yak factory. He does not own the plane.
This is a true modeller project.
olnico is online now
Old 06-28-2012, 11:07 PM
  #334
DelGatoGrande
DelGatoGrande's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Peter why you finish the air brakes on the main fuse?..if you plan to make them factional maybe a separate mold would save more later rework ?
Great work by the way!
DelGatoGrande is offline
Old 06-29-2012, 11:47 AM
  #335
Peter Coers
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank Oli .
DGG, I finished them for the few details on it, my guess is that it is easyer molding it on its place. It is not that extra much work comparing it with the rest of the project .
Thanks for the compliment, I can use them for inspiration .
So after playing with alu now playing with sand , we all did this in the early days .
To make a sturdy mold for the windshield using vacuum I used a mix of sand and epoxy (1/10). It is a cheap way to make this strong, the other side is that it is a bit heavy .
First gellcoat or paint in the mold and then filled with sand.
First layer of mixed sand.
Tamp it with a piece of wood.
Almost filled to the edge.
Final layer has more epoxy in it so seal the top.
Tomorrow I will pop it out .
Old 07-20-2012, 02:54 AM
  #336
Peter Coers
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Not much progress, I am preparing the nozzle cone so that the turkeys will be a seperate mold. In the meantime I did some testing to make a nozzle seal from aluminium, this is much lighter and also looks great.
Underside donut.
Old 08-01-2012, 02:26 AM
  #337
Peter Coers
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Prepairing the wings for the last big step, have the ventrals also detailed, after that there are still many little details to make.
Our inspector on board.........
Old 08-01-2012, 02:30 AM
  #338
Peter Coers
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Forgot the picture with two scale nozzle seals. Alu looks better than plastic
Old 08-01-2012, 08:07 AM
  #339
FenderBean
FenderBean's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Peter, I am a huge F-16 fan, so many props to your project!
FenderBean is offline
Old 08-02-2012, 06:55 AM
  #340
Peter Coers
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Fender, I like them too .
Started with the detailing underside wing. Gladly very little screws there so riviting must go a lot quicker than the topside.
Old 08-07-2012, 06:49 AM
  #341
Peter Coers
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Underside lef is almost finished, placed the seals and lef sheeting.
First seals.
LEF sheeting.
Second seals.
Lef 20 dg down.
Old 08-08-2012, 06:49 AM
  #342
Peter Coers
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Almost ready, just some detailing and than I will make some launcers for the tip.
Old 08-09-2012, 03:16 AM
  #343
Peter Coers
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The last details for this wing. Later I will sand this area with scotch bright, than it will look much realer.
Old 08-09-2012, 03:36 AM
  #344
Ali
Ali's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Much realer Thats impossible! Every now and again I come on this thread and marvel at your workmanship Peter! For me, this is one of those models that is outside of the realms of aeromodelling. This is reduced scale aircraft manufacture in my eyes! All my planes are toys, this F-16 is art!
Regards Al
Ali is offline
Old 08-09-2012, 06:10 AM
  #345
socshooter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Peter,
I second the comment from Ali. This is not a model as per say, what you are constructing here is a Museum replica masterpiece. You are setting a new standard in rc Jets and hopefully I can follow with the amount of detail in my project.
Great work,
J
socshooter is offline
Old 08-09-2012, 06:20 AM
  #346
John Tancock
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think Ali has his eye on this one!!!!!!!
It would look good in your collection!
A true masterpiece, one those models that it would be a shame to paint!
Great thread Peter, keep up the good work.
JT
John Tancock is offline
  #347
argyris
argyris's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes i agree with Ali All my planes are toys, this F-16 is art!
Keep inspire us, thanks.
argyris is offline
Old 08-09-2012, 09:49 AM
  #348
Peter Coers
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks guys, such feedback gives me a lot of inspiration and joy . If this will be the standard for the next generation of jets there is a lot of work to do , I like doing this work .
I have two pictures of the wing, before and after sanding.
After sanding
Old 08-13-2012, 02:53 AM
  #349
Peter Coers
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The first launcer is almost ready, big stick of 55 cm you can almost hockey with it.
Old 08-17-2012, 02:43 AM
  #350
Peter Coers
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Little detail on the tip oft the wing, in real it holds a plug under it for the launcer.
Reply
Display Modes
