My scale 1/5 F-16 B
#352
RE: My scale 1/5 F-16 B
Hi Peter:
I am covering of vertical fin, I like so much, but, what do you think over this ?
Please, do not be too hard with me.
BR from Spain.
Carlos Márquez
_____________________________________________
http://cmjets.blogspot.com.es/
BR from Spain.
Carlos Márquez
#354
Hi Carlos, looking good. When it is glued to the surface it will even look better. Small tip, I made my tools from steel to get a sharper edge on the rivet.
Found nice pictures of the mirage to compare it with yours, http://www.master194.com/photo_avion...isse/index.htm
Are you counting the rivets , I didn't .... tooooo many .
Greetings, Peter
tulz161, thanks man.
Greetings, Peter
#355
Hi Peter:
Thanks for the link.
I will try change the laton tubes for steel. Now I'm sticking with contact adhesive, it is o.k. ?
Thank you very much.
Carlos Márquez.
Carlos Márquez.
#357
Work in progress.
Drew the sidewinder and are now riveting the wing sheet, after one hour still not all the rivets in place ...... so many.
Wing tank.
Wing tank.
#362
Sorry they are'n bigger.
Left LEF sheeted, some little detailing to do on the tip and sheeting the flaperon and this wing side is also ready.
20 dg angle.
20 dg angle.
#363
Peter, it looks amazing! You should bring it to Jetpower so we could see it up close, it's a piece of art!
(and, no, there are NEVER too many F-16's!!!)
#365
Sorry, it is not on JetPower this year too busy doing things on it.
Changed the LEF seals, the lips on it are difficult to mold so I carved them in the alu. Had to replace all the seals [] but this is better for molding.
#368
COOL !!!!!
The slats are really great, congrats. How do you move it ???
BR from Spain.
Carlos Márquez.
BR from Spain.
Carlos Márquez.
#369
Hi Carlos, that will be the big question. It must be strong and the max angle is 20 degrees down and 2 up.
Thats for later in 3d design.
Grts, Peter
Grts, Peter
#370
Hi Peter:
I saw that you made the lines of original hinges in the wing, why you no make the hinges like the origninal ??? is most easy copy that invent
The hinges look like perfect round, the diameter of the hinges is the maximum thickness of the wing, then you only need a shaft for rotating.
BR.
Carlos Márquez.
BR.
Carlos Márquez.
#375
ORIGINAL: Carbon-Customs
it would be nice if your pictures was larger
Grt, Peter
