My scale 1/5 F-16 B
#151
RE: My scale 1/5 F-16 B
Peter, Yes I will show some pictures soon. Been busy doing some other things. Getting ready for JWM.
I have tons of pictures from some publications that I can only rely on.
#152
Eddie, one more for you .
One more panel to go, the 'donut' and the topside is finished. Then I will start with the glassing the cockpit windscreen.
#154
While I am on the back of the plug why not make the turkey's. They are a exact copy of the real one and with closed nozzle it is precies the diameter of the big one in scale. I will later open them up a little bit more for scale look. This one will not be operationally, thats for later.
Here they are, they look scratchy but fine sanding is for later.
15 turkeys.
To compare.
Hope you like it.
15 turkeys.
To compare.
Hope you like it.
#157
Thanks Paul
Nozzle update, I hope that I can compete with this in the future with other models . The finger seals are now in place.
Next step is to make the nozzle segments and seals.
#159
Peter:
Perfect job, congratulations.
RB from Spain.
Carlos.
_________________________
http://cmjets.blogspot.com/
RB from Spain.
Carlos.
#162
I think your's will be as beautiful as mine, it's just a matter of cutting the right lines and a little bit of sanding.
Grts,
Peter
Grts,
Peter
#164
While the canopy windscreen mold is drying I did some nozzle drawing. The parts fit together finally! Not all of them are there yet but tis is the first setup.
(Thomas, too bad it is not the same as in the F14)
The real thing.
The real thing.
#165
Peter
I have been following your great efforts with amazement at the patience you have! Your working tailfeathers reminds me of a visit to the Ohain Whittle in Germany back in 2004 when I saw working tailfeathers on a turbine and also working afterburner.
I dont recall the tailfeathers actually flying but the afterburner worked well but did use a heap of fuel.
http://www.youtube.com/watch?v=lZ04gecuNlQ
The afterburner you can hear being switched on when the plane starts to go vertical and switched off when it has reached altitude. You need to turn the sound up to hear it clearly. Itw as also used for takeoff.
http://www.youtube.com/watch?v=1Ruylp7_RLE
John
John
#166
My Feedback: (23)
Peter,
The nozzle looks great. Does the F-16 your modeling have the GE F110 or the Pratt & Whitney F100? If it has the General Electric F110, then it is in fact the same as my F-14D tailpipe. The only difference being, the F-14 version has a 50" extension between the afterburner and exhaust nozzle
#168
My Feedback: (23)
ORIGINAL: Peter Coers
Thomas, we fly with the P&W F100. There is no budged for a better engine . Later I will make another nozzle for the C verson
#169
De mold for the windscreen is ready, I will make the positive later.
The panelling on the left of the CP is now in place.
This is the first part for the scale nozzle, it will be moulded with rubber to make more. (this is for the static)
#171
Hi Steven thats 291,4 km away from home, not so far .......€?
I will keep this in mind . Too bad I am not at JetPower in september, the plug is on the Open Dagen at Leeuwarden Airbase on 16 and 17 of september.
Grt,
Grt,
#172
ORIGINAL: invertmast
Peter,
The nozzle looks great. Does the F-16 your modeling have the GE F110 or the Pratt & Whitney F100? If it has the General Electric F110, then it is in fact the same as my F-14D tailpipe. The only difference being, the F-14 version has a 50'' extension between the afterburner and exhaust nozzle
Peter,
