JetCat Fuel Pump
My Feedback: (73)
KS
JetCat Fuel Pump
I have a JetCat P-120 fuel pump that won't start at the .250 start-up voltage. Even when I increse the voltage to .450 volts it won't start. If I manually increase the voltage to 2.5 volts it finally runs. Does the pump need to be replaced? Can I replace the motor?
My Feedback: (23)
CA
RE: JetCat Fuel Pump
Hi, before you change your pump ,check the connection of the wires to the pump. you may need to re solder the wires ( loose connection , and not all the st rend are connected ) this will affect the starting ,running and so forth of the voltages .
let me know your findings,
regards,
Isaac
regards,
Isaac
If the pump has not been run for a while or is new you may have to break it in. Some pumps can be sticky initially. This is not unusual for Hausel pumps. The procedure is to run the pump at around 4 - 5 volts ( do not exceed 5 volts ) for about 4 - 5 minutes then in reverse for 4 - 5 minutes. Generally this is all that is required and you should be good to go.
I had a similar problem wich was traced to the wire connections to the brush's, I eventually soldered the wires directly to the brush holders inside the rear casing, gave the wires more support and cured the problems I had, I did put a thread on here somewhere, but no idea where, do a search you may find it.
Mike
371
EDIT: found a link: http://www.rcuniverse.com/forum/m_9786876/tm.htm
Mike
371
My Feedback: (14)
Seems like someone ought to be working on using a brushless motor for jet fuel pumps .. not only because they are so much more reliable than DC motors (no brushes) but also because the ECU can command a specific RPM and know that the motor will turn at precisely this rate .. seems like it would make the whole system much better.
Dave
Dave
My Feedback: (61)
ORIGINAL: ww2birds
Dave
Dave
V..
ORIGINAL: ww2birds
Dave
Dave
Mike
