New high scale Eurofighter
RE: New high scale Eurofighter
Hi Ralle,
I have a Eurosport, latest generation, and it will be sport scale with some details added. I was wondering if your project will correct many of the incorrect details of the original?
I really like the detail treatment your doing, great job, I'm looking forward to the completed model. Do you have an estimate when it will be completed?
I cant wait to see more photos!
Chris
Chris
Hi Chris,
I´m doing this job together with my friend Burhard Dotzauer, the "father" of the Eurosport. We have used the very old original mold, made 15 years ago. Burkard has modified that mold (all incorrect details and shapes). We used very good 3 view drawings, I drawed all views in Corel draw with all details, screws, fasteners, raised panels, hatches. I´m using that files to make the templates, paint masks etc., getting all the measurements.
The new EF must be finished beginning 2011.
the bottom side is nearly finished. have to apply some hatches, engrave the panel lines. will start detailing top side in two weeks...
the original mold was painted in a very uggly green, you are able to see that green and also the old panel lines of the Eurosport:
sanded the surface today, first with 800 grit very lightly, following with 2000 grit. removed the vinyls, used black control powder.
sanded with 4000 grit today, now I have to mask and "spray" some rasied hatches, have to apply some hatches made from vinyl, engrave the panel lines.
#32
Hi Ralle!
Well, you know I do not like the two-seater, but send me some of your pills Damn, I wish I had that much enthusiasm the last months....
Cu,
David
Cu,
David
#33
David,
Ilja has used that pills too, some years ago. He did a grat job on the F-100. You can get that pills here:
http://www.grumania.com/xtcommerce/p...AZY-PILLS.html
#34
cut the paint masks for raised panels today, applied and sprayed the epoxy primer. have to wait some hours now to burn the screws.
#37
removed the masks today, sanded the raised panels. Now I have to make all the panel lines...will take some time..
#39
Hi Harry,
no and yes. yes you are "right". the most the panels are flush. its very difficult to make that curved panel lines (matching with the screws) so I decided to paint these on. that small hatches are raised a little on the real one. note much maybe 1-2 mm. Please not the hinge band with the 3 screws is 10 mm wide!
#42
Now I`have to make the top side of the fuselage...one thing will be very difficult to do....that air grill.....have tried to paint that grill....what do you think? maybe it works....?
#43
ORIGINAL: RalleKnalle
Thomas
#44
I will try to paint that white air intake behind the grill, maybe its looks much better that the "dark" black...
#50
update: turned the fuselage today...going to start detailing of top side next days. Have to make the artwork for all the templates and stencils. The first vertical stabilizer is arrived....looks good...enjoy.
