Wren 100
Banned
1 Post
Wren 100
So how come there is not much on here about the new Wren 100. 22 lbs of thrust out of the same size and weight of turbine as the Wren 54 (14.5 lbs of thrust). I saw one at the UK nats and was very impressed. Well done wren I say. I am told it should be on sale soon
Dennis
Dennis
RE: Wren 100
ORIGINAL: jason
Yes such a shame. This will be the best engine that no one knows exists.
Wheres all the Wren hype gone?
Jason
Jason
Maybe waiting until Jet Power to showcase the engine?????
I know Ron Ballard seems to have taken over from Sara to support Wren on the forums. Thoroughly nice guy!!
Regards
Shaun
RE: Wren 100
ORIGINAL: bigplumbs
RE: Wren 100
Hi All surprised you did not buy one dennis,what you did not say is that it comes with the new Fadec ecu,new soft ware and new long life plug which is similar to what is used on kero start,takes 6volts from the ecu,and lights the gas first time every time,we tryed the new plug in a super sport at the weekend,has fast spool up as well,got to be a top seller and i must have one regards Keith
RE: Wren 100
So the new plug is just a long life plug as advertised but you see it being a better performer and it's a bolt on retrofit? What's the price, anything posted or inside info yet? I really have not had any problems with my plug on my SS but it's always nice to know what the new stuff is...
Sounds like some good stuff from Wren again with this -100.
RE: Wren 100
Sorry, if OT, but yes, it is a 6V ceramic heating element-like a kero burner minus the kero line. In the UK website the price was 40 pounds. The glow power in the ECU is set on either 6V on Projet and to the maximum with a Gaspar ECU, I believe. Simply replace the glow plug with it. The startup slows down with 2-3 seconds, but it starts very well...and should last for ages.
TP.
TP.
RE: Wren 100
It's not quite as straightforward as that. Not all the Gaspar ECUs can deal with the long life plug. My 3 year old SuperSport has just been back at Wren for a routine service and I asked about the long life plug but was told the ECU can't operate it, only the more recent ones.
H.
H.
My Feedback: (39)
RE: Wren 100
We now have 18 of these motors operating with excellent results. 22 pounds of thrust @ 160,000rpm, in a lightweight package squeezed into a SuperSport envelope!!
The next run of this new motor will be available late October, early November, at the same price as the SS with a MiniPlug as standard on the propane motors. Kero-start will be added as an option in the near future. Pre-orders are being taken for the 100!
I plan on performing fuel consumption testing on the 100 during our next Open Day here in Indiana in November. We will also be demonstrating the new Wren 75...Dates to be determined by weeks end.
RE: Wren 100
Great news Ron, thanks for the feedback. I'm sure the fuel burn will reflect the increased thrust but I also hope it reflects the Supersport burn in general. The Supersport I have made it possible to get what I needed in thrust at the fuel I was able to carry (not a lot) for run times that I like (enough to make spotters nervous that I'll flame out, until they see the 12 ounces remaining in the tank, not including UAT of course).
RE: Wren 100
RE: Wren 100
I'm a huge fan of Wren especially since Ron started the USA service center. There are enough Wren SS's out there that I'm certain they will be well supported for quite a long time. In fact there are enough independent turbine maintenance guys out there than even RAM and Sophia engines can still be supported. I'm not concerned about my SS, especially since it's been such a good engine to begin with. Of course that doesn't mean I still don't want a -100
