Bandit ARF fuel capacity
Hi Guys,
I am about to fit a telemetry sensor & flowmeter in my Bandit ARF. This will monitor my fuel use and present it on my Tx screen. I will then be able to set an alarm at "Bingo" point to tell me it is time to land. What I do not seem to be able to find out is the ca[pacity in the standard two fuselage "saddle" tanks and the front centre tank. Does anyone know? I could fill it and then drain the anks into my wifes kitchen measuring jug, but she seems to get upset when I do this! Can't figure her out sometimes.:D |
RE: Bandit ARF fuel capacity
John
Stock plastic Sullivan tank in the front? its close to 3.2ltrs Dave |
The Bandit ARF has aa 2.7 liter fuel system.
www.bvmjets.com, then click on Jet Kits, then Bandit ARF, scroll down and read the fuel system size on the bottom of the pricing page. |
Why not let your sensor tell you what capacity it has by draining the tank with the sensor installed? That would remove all error.
Thanks for the info guys. The sensor has to be calibrated for the model. Differences in the fuel system will lead to some variation in reported value, so telling it what it is supposed to have in the first place is a good way to start.
Regards, John |
ORIGINAL: Harley Condra The Bandit ARF has aa 2.7 liter fuel system. www.bvmjets.com, then click on Jet Kits, then Bandit ARF, scroll down and read the fuel system size on the bottom of the pricing page. |
ORIGINAL: Dave Wilshere John Stock plastic Sullivan tank in the front? its close to 3.2ltrs Dave Thanks Dave. John |
I was inc the UAT. Does the 2.7ltr? My ARF did 10-11 minutes on a P80, thinks more than 2.7ltr?
CARF said the Hawk tank was 3.3ltrs....is 4.2ltrs! Dubro say 1500cc in a 50oz and that's 1600cc!! Dave |
Hmmmm...not sure I would hang my hat on a "sensor", could be a flame out in your future....just sayin' For me we are going to use a system that is as old as time itself, time. The timer never lies. Good luck, I hope this works 100% perfect for you...every time....
****dont take it the wrong way, just looking out for you brother....*****:D |
ORIGINAL: Dave Wilshere I was inc the UAT. Does the 2.7ltr? My ARF did 10-11 minutes on a P80, thinks more than 2.7ltr? CARF said the Hawk tank was 3.3ltrs....is 4.2ltrs! Dubro say 1500cc in a 50oz and that's 1600cc!! Dave |
Hi Dave,
No you are quite right, I will not be relying on the flow sensor, the timer will still be used as a back up. The flowmeter part of this set up is a nice to have rather than an essenstial. It will be intersting to see how much fuel use is occuring and how different weather alters the fuel burn. The important part for me is the RPM reading and alarm. This will tell me if I get a flame out. No, not on my Bandit, that will be self evident. The idea is for the F14 that I have nearly finished. I am pretty sure that if I have a flame out on this model and I cannot see which engine has gone out, I will probably loose the model. The beauty of the system is that is an alarm condition occurs, the Tx info screen will change to the relevant sensor info screen in an instant. Putting the system in the bandit is just proof of concept. |
ORIGINAL: JohnMac Hi Dave, No you are quite right, I will not be relying on the flow sensor, the timer will still be used as a back up. The flowmeter part of this set up is a nice to have rather than an essenstial. It will be intersting to see how much fuel use is occuring and how different weather alters the fuel burn. The important part for me is the RPM reading and alarm. This will tell me if I get a flame out. No, not on my Bandit, that will be self evident. The idea is for the F14 that I have nearly finished. I am pretty sure that if I have a flame out on this model and I cannot see which engine has gone out, I will probably loose the model. The beauty of the system is that is an alarm condition occurs, the Tx info screen will change to the relevant sensor info screen in an instant. Putting the system in the bandit is just proof of concept. |
