Alternative uses for turbine engines
So what else have you used your prized turbine engine for? other than in a plane for thrust.
I've got two so far. 1. Drying large areas - We have a large concrete area with a lacquer protecting a colouring, this doesnt absorbe water so it beads and hangs around for upto a week. So after cleaning the patio with a high pressure water cleaner, fired up my 8kg turbine (in plane), full throttle and used it like a 400 degree blower vac. Worked wonders. 2. Pissing off the neighbours - This happened to a friend doing engine tests and the police came and knocked on his door upon a neighbours noise complaint (all in one day only). Police told him off and to keep the noise to a minimum then asked if they could come in to see the jets because theyre so cool. Imagin if they asked to fire them up again, HA. Anyone else got some nifty uses for our expensive tin cans? |
RE: Alternative uses for turbine engines
Driveway de icer.
Rob. |
Don't forget the helicopters !!
this is my EC135 I built .. ( Jet Cat power ) [youtube]http://www.youtube.com/watch?v=QW7h9MVTzIo[/youtube] this is my bell 412 ( built by Ian Thornley) with Jakadofsky power that I just put my first full flight on today :) [youtube]http://www.youtube.com/watch?v=pOH3rygAgR4[/youtube] ~V~ |
I had issues with the neighbours cats crapping on my front lawn - don't have that problem anymore[>:]
What a great post!:)
JT |
I've been known to use an 80 as a weed killer in the back garden. ;)
Its good for supermarket runs.
http://www.youtube.com/watch?v=HuI1AQJSR_M This happened to a friend doing engine tests and the police came and knocked on his door upon a neighbours noise complaint (all in one day only). Police told him off and to keep the noise to a minimum then asked if they could come in to see the jets because theyre so cool. Imagin if they asked to fire them up again, HA. |
Blowing the FOD off of the run way after someones misfortune [:@]
1 Attachment(s)
A few of the uses I have found for a P200 over the years.
hey ausfester
don't forget the coppers also did say i was doing nothing wrong and took heaps of photo evidence to show the crew back at the station. still don't know who complained.but have run up two new K100G turbines recently ken kmrc jets kingtech turbines oz |
Turbines are great for setting off the neighborhood dogs. In fact it has led to a new classification system for turbines. For example, my Jet Central Bee II Kerostart is a class 2B turbine....it sets off every dog in a two block radius.
sp |
Use 4 P200's in a 4 engine 747 Ultra light
This is a clever idea, I can use this to dry our runway fast when wet because last time I flameout because of water.
http://www.youtube.com/watch?v=9NGZgumxe04 |
Leaf blower and hand warmer.... Boomerang Fuse works great for both....
