RE: HOBBYKING L59 for JETCAT P20
Actually
I have seen that before Magic |
AR another one
What about a Wren Gold 44 Pipe size Croc |
Henke
Tell me more Re: test bench Thanx Croc |
ORIGINAL: CrocEnd Henke Tell me more Re: test bench Thanx Croc |
What I need is the diametter of a pipe for a Wren 44 or and Wren 54
Had to put 5 oz (125 g) of lead in the very nose of mine to get it to balance. I had also put the P20 quite a way forward. The problem is the tail on this plane is quite heavy. I will weigh the all up dry weight in a moment
Just put her on her wheels and it is obvious that the CG in the manual looks wrong as it is very bouncy on the nose. I just read the trread on this plane on RC Groups and it says the cg should be 60 mm back at 240 mm and not as the manual which says 80 mm back at 240 mm. I thorefore opened up the nose from the bottom at the very front and put in another 110g of lead and that has done the trick. All I need now is some good weather Just weighed it and the all up dry weight with the header empty and no fuel but everything else included is 3.2 kg which is7 Lbs. I am quite pleased at this weight the EDF Boys seem to be comming in over 8lbs. I recon with the amount of wing area thatthe L59hasshe should fly well with a P20 (5.2 lbs of thrust) |
ORIGINAL: TimWatson Had to put 5 oz (125 g) of lead in the very nose of mine to get it to balance. I had also put the P20 quite a way forward. The problem is the tail on this plane is quite heavy. I will weigh the all up dry weight in a moment Just put her on her wheels and it is obvious that the CG in the manual looks wrong as it is very bouncy on the nose. I just read the trread on this plane on RC Groups and it says the cg should be 60 mm back at 240 mm and not as the manual which says 80 mm back at 240 mm. I thorefore opened up the nose from the bottom at the very front and put in another 110g of lead and that has done the trick. All I need now is some good weather Just weighed it and the all up dry weight with the header empty and no fuel but everything else included is 3.2 kg which is7 Lbs. I am quite pleased at this weight the EDF Boys seem to be comming in over 8lbs. I recon with the amount of wing area thatthe L59hasshe should fly well with a P20 (5.2 lbs of thrust) The plane has a weight of 3370g which i believe is very good. |
That EDF weight of 8Lb is probably with batteries as you have said your 7Lb weight is with no fuel on board, so possibly you are coming out at the same weight near enough.
Mike |
ORIGINAL: BaldEagel That EDF weight of 8Lb is probably with batteries as you have said your 7Lb weight is with no fuel on board, so possibly you are coming out at the same weight near enough. Mike |
I don't know though I have certainly lost a battery in flight from my EDF Habu, so it was lighter when it arrived. LOL
Mike |
POWER JET here is the video of your flight i took last week with my mobile...flare didnt go as planed
[youtube]http://www.youtube.com/watch?v=0GQKMUHRn14[/youtube] |
ORIGINAL: DelGatoGrande POWER JET here is the video of your flight i took last week with my mobile...flare didnt go as planed http://www.youtube.com/watch?v=0GQKMUHRn14 So,you did all this!!!!! It was your trembling hands that shaked and crash my plane!!! It's perfectly sycronized!!!! http://www.rcuniverse.com/forum/js/f...ngry_smile.gif |
lol:D .. im sure its ready for this weekend
very nice and stable flight power jet but must be very windy at the airport!!this video is HD or not?the ideal plane for this turbine!!
ORIGINAL: DelGatoGrande lol:D .. im sure its ready for this weekend So the solution is easy....i ordered two new kits from Hobbyking!http://www.rcuniverse.com/forum/js/f...wink_smile.gif |
ORIGINAL: terryjet very nice and stable flight power jet but must be very windy at the airport!!this video is HD or not?the ideal plane for this turbine!! |
ti vra to sabbato?
ORIGINAL: terryjet ti vra to sabbato? Sorry about that my friends...it's greek humor!! We're justarrange what time we're gonna meet at our flight academy club field on weekend!!http://www.rcuniverse.com/forum/js/f...eeth_smile.gif |
Hi Guys Anyone any feedback/ install pics on the P20 instal,l I have just ordered one from hobbyking uk and ordered the retracts from the Germany hobbyking so should have them in the next few days
If it helps my 8S5000 powered EDF version is 3.2kg AUW. Not flown yet. Waiting for a fan. Just in case you haven't read the RCG thread most important mod is the reinforce the area around the mounts for the mains LG with carbon cloth. Several have landed and the retract punch straight through the wing.
any chance of a link to that thread sounds interesting thanks for the warning about the retract mounts
You may wish to look at this thread as well: http://www.youtube.com/watch_popup?v=jEjUAnPc2VA#t=20
Mike |
brilliant but its a pigeon not an albatross lol
Got the kit today, I have had a look at the wing retract mounts they seem quite well braced there is a ply mount with a quadrant brace under the ply, has this been added since earlier models ? ,Not too sure about a lot of the formers in the fuz they look like they need Hysol reinforcement. Overall though. it looks like it will make a very nice model with a bit of tlc.need to get a thrust pipe sorted next,I think the P20 will sit quite a way forward to get the c of g, looks like the tank will sit nicely on the c of g, plenty of room for that
