RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   RC Jets (http://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Large SM Hawk questions (http://www.rcuniverse.com/forum/rc-jets-120/11238432-large-sm-hawk-questions.html)
ddennison 09-23-2012 05:41 PM
I am on the verge of ordering a SM large Hawk and have a few questions for those who have been down this road already..I am planing on the Navy Trainer scheme.
I have read through many of the Hawk threads but thought I would ask the direct questions.
I usually buy the plane with the least done at the factory so that I can inspect/setup things the way I usually do etc...
How have most of you ordered your plane - flaps/ail hinges done? I plan to go with the BV upgrades and metal hinges for the main doors - so I figured I would order it without all of that stuff and do it myself.
I have a 160SX for this - enough?
Lights - who is using what? I have used D4S for other projects but would like a bright nose light and simple install. Is D4S best?
I have never used the Skymaster struts oil/air - do I need anything special to set these up?
Cockpit/pilots - from SM? Seems to be a good deal if bought with the plane?
Thanks in advance,
Dave
quist 09-23-2012 05:53 PM
RE: Large SM Hawk questions
1 Attachment(s)
Quote:
ORIGINAL: ddennison
BVM manual and trays helped.
I have a 160SX for this - enough? p140rx is fantastic in our 100 degree weather.
Lights - who is using what? I have used D4S for other projects but would like a bright nose light and simple install. Is D4S best? D4s lights look great but you have to mold your own wingtip lenses.
I have never used the Skymaster struts oil/air - do I need anything special to set these up? Tools are included with the kit.
Cockpit/pilots - from SM? Seems to be a good deal if bought with the plane? This setup looks great and fits.
Thanks in advance,
Dave
dubd 09-23-2012 08:58 PM
My plane I my had the landing gear and doors installed. I'm using D43 lights and SM cockpit and pilots. You can see them in this video. Also running a 160... More than enough.
[youtube]http://www.youtube.com/watch?v=C5J-49quZx0&sns=em[/youtube]
ianober 09-24-2012 09:51 AM
Retract that airbrake before taxing back!!!!! ;);):D
ddennison 09-26-2012 06:40 PM
Thanks for the information, my Hawk is now ordered, Goshawk...
Dave
Joe Westrich 09-27-2012 06:44 AM
I have 10 flights on mine and it was the sweetest maiden flight that I have ever had. There are a few mods that need to be done. Get with me later and I can give you all the info.
Its funny, I nearly contacted you about a possible trade between my Hawk and your A10 for sale. I figured you were looking for cash only.
Joe
rc4flying 09-27-2012 08:19 AM
I am in the 9th week of my SM Large Hawk order. Hope to hear somthing soon.
What kind of mods do you think need to be made ?
I am looking forward to it's arrival, but sometimes I wish I had decided on a Tomahawk L-39 after watching many more videos and talking to a few people. But from what I have seen in person with the Hawk, it will be a great flyer. Anyone interested in a Navy Trainer scheme Hawk with everything ?
What size motor are you using ?
Joe Westrich 09-27-2012 09:10 AM
I am running a 160SX and when I was finished building it, I thought it might not be enough. I was wrong. It flys great with 36lbs of blow. The vertical is great too.... not unlimited but more than I thought for sure.
Some mods are fuse opening edges need reenforcement so they don't crack over time. The belly of the fuse needs some CF so that you don't cruch the bottom sitting it on a stand. I replace the hinges with BVM ones. The gaps on the ail and rudder ends need a little attention. Overall, not bad. It makes for an impressive flyer.
rc4flying 09-27-2012 09:19 AM
I have heard guys mention about the belly reinforcement and hinges, but not that the edges need to be looked at and the rudder ends. Good info. Thanks. I have a 140 that I plan on using. What do you think ?
Joe Westrich 09-27-2012 09:46 AM
I think it will fly it fine but would prefer 36lb of thrust. Mine is about 41lb dry.
rc4flying 09-27-2012 10:44 AM
Wow...... That is heavier than I would have thought.
What kind of field do you fly off? Grass or paved ?
quist 09-27-2012 10:53 AM
The p140 is great in the Large Hawk. I am flying at 1800' and 100 degrees. But it is a constant speed jet. According to Wilcox most P140's are putting out 33 -34lbs of thrust. So it is about the same as the Titan was.
Joe Westrich 09-27-2012 11:05 AM
The website says 36lbs dry but the manual says 38 to 42lbs. I do have the wing tanks and wingtip pylons/missles. If you left that stuff off, you may be around 39lbs dry.
I have flown off pavement and use about 400ft but I could use less if I wanted.
I don't think grass wouldn't be too much different. The wheels are large on the Hawk.
I think with your 32lb turbine, you could fly off of 500ft of grass and be ok. Your ascent may be shallow but the rest of the flight would be comfortable.
rc4flying 09-27-2012 11:15 AM
Thanks guys, some good info. I do not have any tanks or missles planned on this new Hawk. I have a JC 180 ordered for my present plane because I think I want to be able to get off the grass easier. The 140 was going to be moved over to the Hawk. But I guess I can decide on which engine to put where after I fly both. I will mainly be flying from grass, and it is alittle on the thick side.
ddennison 09-27-2012 02:55 PM
Thanks Joe,
I am putting the 160SX in the Goshawk. I am still looking to sell the A10 though...
Glad to hear the information, thanks for posting!
Dave Dennison
jetpilot 09-27-2012 05:08 PM
Mine flew with a P120sx and flew great. Flew off grass too! No problem!!
A hawk doesnt need one to one to fly great. Some guys really like to haul with them though.
Scott
Boating Bob 09-27-2012 05:47 PM
1 Attachment(s)
MINE HAS ARRIVED These are pictures at the factory. have not had time to take some here.
rc4flying 09-27-2012 05:50 PM
When did you order your plane ?
Trying to get an idea how much longer on mine.
Thanks.
Boating Bob 09-27-2012 05:56 PM
About the middle of June. I think it took longer becouse of the paint sceme. It was worth the wait.
rc4flying 09-27-2012 06:00 PM
Wow.... I ordered mine the middle of July. I may still have a little wait. Oh well.......... Looks like it will be worth it.
Nice scheme, by the way.
Don Perry 09-27-2012 06:11 PM
Just got my red arrows hawk ordered yesterday. So I'm on the hurry up and wait list too.
ddennison 10-01-2012 06:20 PM
I am looking for a servo list to make sure I have everything I need:
Guessing 8711s for aileron(2), flap (2), elev (2) and rudder (1). I plan on using my weatronic so wont use the HV servos.
What size do I need for the nose steering, is it standard size?
thanks!
Dave
ddennison 10-01-2012 06:44 PM
just to clarify, I only was checking on flight surfaces.
Dave
Boating Bob 10-02-2012 03:17 AM
Highly recomend getting BVM supplementary manual. Some good information.
ddennison 10-02-2012 03:19 AM
Hi
Manual is on the way, just trying to figure which servos I will need to include with the final order.
DD
