expired date turbine oil
hi every one
i have a few cans of expired date turbine oil . can i use them? i talked to friend of mine which is aviation engineer and he told me thet i can use it with no problem i will be glad to hear more opinions thanks |
RE: expired date turbine oil
I'm curious to know (as a new RC turbine pilot) what experies in the turbine oil? Is there a "best if sold by" date on the side of the container you have?
No problem to use, the oil has several additives for full size use which deteriorate over time hence the sell by date.
All products used in full sized aviation must have a shelf life or expiration date on them. There is no "best before". This date, is the amount of time after manufacture or packaging, that the OEM guaranties that their product will still meet the required specification. I.e, if the shelf life of a paint is 4 years, then 4 years after the date of manufacture, if you were to apply that paint product, it would have the correct viscosity, soild content, coverage, etc during application, and then it would take the same amount of time to flash off, cure, and finally if would have the same final finish qualities as per the minimum required by the specification that it was sold as meeting or exceeding.
In full sized RPT (regular public transport, millitary, etc ) we discard many products because they have reached their shelf life. (General aviation are a little less concerned at times) The product can be perfectly ok, but must be discarded. I discarded over $5000 worth of paint products after an audit 2 weeks ago for this very reason. would I use it for my models? Damn straight;):D I would not hesitate (just mixed a batch of fuel last week with time ex oil) to use the oil in for my models as long as there is no signs of rust on the tin and there are no contaminates as you pour it out. Thanks dave |
Please send all of your expired turbine oil to me, and I will be pleased to dispose of it for you, saving you both time and the expense of legal disposal methods.
How many years was it in the ground? ;)
Dw |
Hi i have been using turbine oil that was canned 20years ago for two years now no problems what so ever regards Keith;)
Glad you said that Keith, I've got a ton of 2010 vintage :D
ORIGINAL: FlyinTiger I'm curious to know (as a new RC turbine pilot) what experies in the turbine oil? Is there a ''best if sold by'' date on the side of the container you have? Nothing other than the FAA. For "real" or "Full Scale" aircraft... they set dates on the oil. But, in reality, the oil is fine, if the can was never opened. It's kind of like putting an expiration on a twinkie. It's just a precaution, and to put a limit on the manufactures liability. |
for me too!!!
Jose ;) |
ORIGINAL: Harley Condra Please send all of your expired turbine oil to me, and I will be pleased to dispose of it for you, saving you both time and the expense of legal disposal methods. Thanks dave |
No problem, you can use it, been doing it for years.
Paul G |
If you think about it, we only use the oil once. most of it goes through the combustion chamber and is burnt..the tiny remainder goes through the bearings once, and then is burnt in the exhaust..
Full scale, it is circulated, pumped, filtered, heated, cooled, piped over and over until the next oil change.... |
ORIGINAL: Wayne22 If you think about it, we only use the oil once. most of it goes through the combustion chamber and is burnt..the tiny remainder goes through the bearings once, and then is burnt in the exhaust.. Full scale, it is circulated, pumped, filtered, heated, cooled, piped over and over until the next oil change.... Tailwinds, John |
ORIGINAL: cactusflyer ORIGINAL: Wayne22 If you think about it, we only use the oil once. most of it goes through the combustion chamber and is burnt..the tiny remainder goes through the bearings once, and then is burnt in the exhaust.. Full scale, it is circulated, pumped, filtered, heated, cooled, piped over and over until the next oil change.... Tailwinds, John Well, our 737-700`s with CFM`56`s use about 4 quarts every 48 hours , so it sort of replaces the oil regualry by itself :) |
