Powerbox RRS
I was upset today when I wanted to buy a Powerbox RRS to find that they are no longer being made. I have had 3 over the years and the unit is excellent it is small, low cost and provides the simplest method of having 2 receivers and complies with UK Large Model Association rules for system diversity. What a pity, I guess that there had not been enough demand for them. The alternative new product is 3 times the cost!
John |
RE: Powerbox RRS
John
Your Champion RRS is in progress. Features built in Regulators, Switching, signal boosting for better servo resolution...Plus so much more Dave |
RE: Powerbox RRS
ORIGINAL: Jgwright I was upset today when I wanted to buy a Powerbox RRS to find that they are no longer being made. I have had 3 over the years and the unit is excellent it is small, low cost and provides the simplest method of having 2 receivers and complies with UK Large Model Association rules for system diversity. What a pity, I guess that there had not been enough demand for them. The alternative new product is 3 times the cost! John |
RE: Powerbox RRS
John, are you aware of the emcotec device http://shop.rc-electronic.com/e-vend...=6&c=705&p=705
RE: Powerbox RRS
Harry
Yes I checked the Emcotec web site and see that they do a similar product to the old RRS unit. It seems I must be getting out of date and should be changing to S bus to take advantage of the cheaper receivers. Odd though that Powerbox have effectively given the market for those with older receivers who want a simple system for 2 receivers with redundancy to their rival. John |
RE: Powerbox RRS
I understand your voice on this point of view but I'm nt sure this system was "the thing".
This system only gives you a redundant Rx for your plane, and that's all. Why put double Rx system if you don't have a double battery system ? In fact, there is more battery failure than receiver failures, right ? So using Powerbox RRS system you have to add a meaning to feed your servos with redundant batteries feeding. This is in fact a Powerbox Champion/Royal RRS system... ;) OK, it's not the same price, but this includes, as said, dual batteries, dual receivers, signal boosters, etc, all included in a single and secured box. For me the Powerbox RSS system was made for guy owning before a Powerbox without RRS system and wanting to update a plane with dual receiver without changing all the costly box system. Not sure there was a huge demand on it. But you will be surely smilling again when you will found on the market this : [link]http://www.lamb-air.com/central-box-200.php[/link] This the Jeti equivalent of the Powerbox RRS system... But this includes the dual battery... Impatient to see the cost ! |
RE: Powerbox RRS
I had dual battery systems on my larger planes with 2 receivers. On 2 planes I used a simple Powerbox sensor switch which has twin battery inputs and feeds and A123 batteries. These planes though were not very fast flying and on the next larger heavier plane I have used a Powerbox Base log with its more powerful regulators.
I have never had an issue with Powerbox products which are excellent. Not sure I would trust Jeti though. John |
RE: Powerbox RRS
Why don't trust Jeti system ? They are manufacturing electronic systems for 15 or 20 years ago, and those are first quality system.
Electric brushed and brushless controlers are on top for years ! (Hacker motors is working with them) Jeti duplex 2.4Ghz system is working for years now and is very good. They have start to seeling teir new transmiter DC-16 for few month now and it's a winner... The central box is only a concentration in the same box of old systems that are working for years (EN links, Maxbec, etc...) |
RE: Powerbox RRS
ORIGINAL: HarryC John, are you aware of the emcotec device http://shop.rc-electronic.com/e-vend...=705&p=705 <br type="_moz" /> |
