RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   RC Jets (http://www.rcuniverse.com/forum/rc-jets-120/)
-   -   BMT turbine parts help. (http://www.rcuniverse.com/forum/rc-jets-120/11258312-bmt-turbine-parts-help.html)
GRVW 10-10-2012 05:22 PM
1 Attachment(s)
Hi all
Does anyone remember the BMT 120KS turbine and if so can you help?
I've been given one which needs some work, but Im having difficulty chasing parts (BMt are out of production).
In particular I'm after a NGV and the propietry TCU (FADEC).
The NGV I have is damaged - see photos.
Does anyone recognise its maker, assuming that BMT didn't make them in-house?
Also, what do you make of the damage (see second photo)? Is it a write-off, dangerous, or merely likely to be inefficent?
Any help gratefully received.
Dr Honda 10-10-2012 05:52 PM
RE: BMT turbine parts help.
It may drop the efficacy... but it could probably be welded, and ground back into shape.
I've TIG'ed inconel with 625 rod... but it was virgin material. I'm not sure how well "used" metal will weld. (never tried that)
jetpilot 10-10-2012 06:13 PM
Andre bisits here occasionally. I think Turbotronic his name
Scott
chrigui 10-10-2012 09:57 PM
take some dimension and try with www.jetmax.ch
GRVW 10-11-2012 01:02 AM
Thanks but just measured and the jetmax NGVs are different.
Does anyone know of other manufacturers of NGVs that look like the one above (around 72.50mm OD)?
chrigui 10-11-2012 01:05 AM
jet joe? or you must made one by CNC milling or laser soldering adding steel
basimpsn 10-11-2012 03:07 AM
Look like you still have 2 years worth out of it. ;)
GRVW 10-11-2012 08:23 PM
So you think it looks still serviceable?
chrigui 10-11-2012 09:42 PM
yes..is possible to repair
s3nfo 10-12-2012 11:40 AM
Last I knew you could still contact Andre through his website.
http://www.bairdtech.com/
jetdriver 10-12-2012 07:22 PM
try [link]http://ibaird@africa.net[/link] watch out, he is a BIG TIME crook and thief. Owes me 10 motors that I paid for and never saw, long ago. I also need some BMT 120KS TCU's to help guys out that I sold engines to. He won't have any. IF he says he does, he is BSing you. he may by chance have a spare turbine wheel and ngv. BE CAREFUL!!!!!
Mickey Edmonds
Mickey
mr_matt 10-12-2012 07:43 PM
I thought BMT was still a viable company ?? I thought these were decent turbines?
jetdriver 10-12-2012 09:38 PM
No Matt, Andre and BMT are long gone. ( with my money, unfortunatly ) Please guys be careful when dealing with Andre. Ask anyone that knows me will tell you the horror story that I went through begging him for engines and parts
Mickey Edmonds
owner A-1 Hobby ,former BMT importer and repair facility. now I am just another sucker that he got to. I know for a fact that he owes Jesus Artes a ton of money for turbine wheels that the ordered and never paid for. I wish I had some parts so I could help you guys out. The BMT KS was a great engine but Andre is a horrible businessman
GRVW 10-12-2012 10:16 PM
Do you reckon it might be an Artes NGV then?
And, has anyone tried using a Xicoy Kero start plug and ECU setup with one of these turbines?
GRVW 10-22-2012 09:30 PM
Pleasingly Jetmax have a blank cast NGV to suit, but I'm not sure my machining skills are up to it. Does anyone know the typical gap between the turbine wheel blades and the NGV? Is it approx 0.1 - 0.15mm?
chrigui 10-22-2012 11:43 PM
i can do the modify for fit jetmax ngv
GRVW 10-25-2012 03:42 PM
chrigui, PM sent.
