Ultra Flash almost completed!
1 Attachment(s)
See pics. I am almost completed with decorating my Comp-Arf Ultra Flash. The building is completed except for the turbine install.
I'm waiting for my new Wren 140 but all else is done. I got an "all white" version that made it easy to finish by masking off, priming and painting to duplicate a typical "NAVYTRAINER"scheme. I used Rustoleum UltraCover 2X primer and paint and the rest is vinyl from a BTEReactionX jet kit. Ilike the Navy Trainer scheme since it is highly visible in the air and quite easy to do. The jet should weigh between 25 and 26 lbs and with 32 lbs of thrust it should be a real performer!!! |
RE: Ultra Flash almost completed!
Was missing pics until now.
Ali and Afterburner1 had p140 in there U. Flashes and THEY. WERE. FAST.
I've never been the slow one in my little BARF, but I was sittin' in the back of the bus. Until we meet again. http://img.photobucket.com/albums/v2.../evillaugh.gif http://i281.photobucket.com/albums/k...ne/dr-evil.jpg |
Raffy. Lets get you a 170, You wont be in the back of the bus on the next round for sure!! :D:D
Nice colour scheme :-)
Simple but looks like it will be effective in the air, always nice to see a non-standard scheme too Stuart <br type="_moz" /> |
ORIGINAL: Flynstuff Raffy. Lets get you a 170, You wont be in the back of the bus on the next round for sure!! :D:D |
Yes its fast. I had a 160 in mine, and we never did open it up.. it would do 150 at half throttle no prob.. I saw one go with a cheetah in it, and it had no issues running w the bandits
Oh man you were reading my mind, I was thinking of redoing my Thunderbird Scheme Classic Flash in a T-45 scheme....
Looks great! p.s. I have a Cheetah in my classic, I open it up on occasion, then I chicken out and pull the stick back to 1/2 go go :D:D:D |
ORIGINAL: Flynstuff Raffy. Lets get you a 170, You wont be in the back of the bus on the next round for sure!! :D:D Correct,,,, it won't be in the back of the bus... It will turn into confetti....:D |
Not my BARF. ;)
It has been modified. [8D] |
geh3, just as an FYI, my UF came in at 24.5 lbs with saddle tanks, wing tank (for smoke), and main tank. Smoke system also installed. Your guess of 25-26 is right in the ballpark. Mine is P-180RX powered. :D
WOW 180
260 mph? |
love it
1 Attachment(s)
I tinted the canopy + added an anti-glare panel and a black nose tip
now it looks BBAADDDDDDD |
1 Attachment(s)
OK all decorations done, now onto the next project!!!
Iused Tamiya # PS-31 SMOKE poycarbonate paint on the inside of the canopy and more Rustoleum for the frontal black areas... |
What did you use on the tail cone? Plane looks great. |
ORIGINAL: geh3 WOW 180 260 mph? :D :D |
Ijust painted the back half flat black then applied small triangular
srips using that blue painters tape and sprayed over it all with silver krylon It sort of looks like a typical military tailcone that contracts hydraulically! |
curious about your statement. You dont push it as hard because it can easily get smokin at that altitude while at the same time its likely the VNE drops (as with most aircraft)?
ORIGINAL: furloughed ual ORIGINAL: geh3 WOW 180 260 mph? :D :D |
ORIGINAL: dbsonic curious about your statement. You dont push it as hard because it can easily get smokin at that altitude while at the same time its likely the VNE drops (as with most aircraft)? No...meaning the rated thrust is less here at altitude than sea level. We use 160's here to power what u guys at lower altitudes push adequately with 120's. |
