RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   RC Jets (http://www.rcuniverse.com/forum/rc-jets-120/)
-   -   3mm shut off valve (http://www.rcuniverse.com/forum/rc-jets-120/11297703-3mm-shut-off-valve.html)
raptor30se 11-14-2012 06:46 PM
3mm shut off valve
The P20 feeds are 3mm lines, jetcat sent 4mm shutoff valves, is there any 3mm shutoff without halving to make a reducer from 4mm?
rcjetsaok 11-14-2012 08:17 PM
RE: 3mm shut off valve
Dreamworks
Dan
Dr Honda 11-15-2012 04:57 AM
Quote:
ORIGINAL: rcjetsaok
Dreamworks
Dan
I don't know if Todd has a 3mm valve or not.
Raptor: Is it 3mm coming out of the pump? My Wren 44 uses 3mm hoses... but it's 4mm from the pump. So... I run 4mm to the valve, and filter... then I use a 4mm to 3mm Festo right at the engine.
S_Ellzey 11-15-2012 05:41 AM
Quote:
ORIGINAL: raptor30se
my P20 came with 4mm to 3mm reducers. I came off the fuel tank with the 4mm tubing to the shutoff and then to a reducer.
HarryC 11-15-2012 06:37 AM
afaik, festo do not make a 3mm valve, which is why Wren sells the special 4-3mm adapters for the valve, see "plug-in reducer" about half way down the page http://www.wrenturbines.co.uk/access...sto-connectors
rcjetsaok 11-15-2012 08:03 AM
Quote:
ORIGINAL: Dr Honda
Quote:
ORIGINAL: rcjetsaok
Dreamworks
Dan
Your right... Brain fart... I was thinking 6 & 4 , not 4 & 3... Can't say I've ever seen a 3mm valve..
Dan
smchale 11-15-2012 10:06 AM
This is about as close as I could find with a simple google search:
http://global.rakuten.com/en/store/a...4516830720415/
Dr Honda 11-15-2012 10:52 AM
Quote:
ORIGINAL: smchale
Only problem with that is... the seals inside of it may not like Kero.
smchale 11-15-2012 11:18 AM
Quote:
ORIGINAL: Dr Honda
Quote:
ORIGINAL: smchale
Agreed. There isn't much out there. Until something becomes available a 4mm valve with increaser then reducer is the best solution.
Henke Torphammar 11-15-2012 11:51 AM
Quote:
ORIGINAL: smchale
Why not trust the solenoids? From what I have seen an extra valve causes more trouble then it helps. Removeing the valve would eliminate atleast 3 connections points(potential leaks) in this case, free up space and save some weight. (I know this wasn't the question)
smchale 11-15-2012 12:05 PM
Quote:
ORIGINAL: Henke Torphammar
Quote:
ORIGINAL: smchale
Here in the USA our governing body requires it. See point #8.
http://www.modelaircraft.org/files/510-a.pdf
joeflyer 11-15-2012 02:38 PM
This is the one I've been using on my Wrens for years. You have to heat up and stretch the tubing to force it over the 4mm nipple. It forms a tight seal and works great.
http://dreamworksrc.com/catalog/imag...esto/a1013.jpghttp://dreamworksrc.com/catalog/jetc...alve-p-98.html
Joe
aquaskiman 11-15-2012 02:48 PM
Check with Ron Ballard at Wren USA, I used to get them (3mm Festo) from Sara at Wren
rcand 11-15-2012 04:17 PM
Quote:
ORIGINAL: rcjetsaok
Dreamworks
Dan
I did not see any 3mm stuff except for a straight connector, and that was 2 weeks ago when I bought some festo fittings
DelGatoGrande 11-15-2012 10:07 PM
never used a shut off valve.never had a problem with my jet cats ..
