DS 8411 Question.....
Has anybody ever had a JR DS8411 just completely freeze (lock up). It is under no power, just me trying to freely spin the gear train.......Crazy, i have never seen this. It allowed me to move the servo only one direction until it hit it's limit and now it is completely locked out (will not move at all.....Thanks in advance...
RE: DS 8411 Question.....
ORIGINAL: NickC5FE Has anybody ever had a JR DS8411 just completely freeze (lock up). It is under no power, just me trying to freely spin the gear train.......Crazy, i have never seen this. It allowed me to move the servo only one direction until it hit it's limit and now it is completely locked out (will not move at all.....Thanks in advance... |
Didnt want to do it on my good battery/receiver setup so this weekend i was going to put it on a spare receiver/batt setup and see. I just cant imagine it will be good if i am unable to move it by hand. I have owned many 8411's before and all other models of their high power servos and have never seen this.
I do however, recall back in the day that the 8411 was under a lot of heat for bad gear train slop, but that was only after much use......... |
ORIGINAL: NickC5FE Didnt want to do it on my good battery/receiver setup so this weekend i was going to put it on a spare receiver/batt setup and see. I just cant imagine it will be good if i am unable to move it by hand. I have owned many 8411's before and all other models of their high power servos and have never seen this. I do however, recall back in the day that the 8411 was under a lot of heat for bad gear train slop, but that was only after much use......... |
I would pull the top off and inspect the gear train before I plugged it in. If there are teeth missing on one of the gears or there is trash in the gears that are blocking rotation, powering it up and having it try and center is not going to do it any good...
Bob |
Hey Bob, that is what i am thinking has happened. The servo is used, and as far as i know it has never been shocked......We shall see.. I am going to inspect under the cover tonight..
I presume the movement was free before it locked? Coreless motor servos can have the motor go bad and tighten before locking completely. The servo is very tight to turn, like driving a dynamo.
Dw |
Nick,
I had an 8611A work completely fine one sunday, then 2 weeks later after being stored in the trailer it would lock up and or make a horrible grinding noise. Come to find out, one tooth of the only plastic gear in the gear train has broken free and would jam between two metal gears on occassion. |
All gears looked good......nothing i could see. Then powered it up and it is still locked....strange. Off to HH it goes..
Nick,
After you determine the cause of the servo malfunction I would return it to Horizon for service or replacement. My jet partner recently sent in all the DS 8411s off his CAFEurosport to Horizon and they repaired them at No Charge. I had a similar experience withsome high end JR servosfrom a couple of used jets that were purchased a while ago. Just include a nice, couteous letter to Horizon's customer service department and they should repair and/or replace the servos at No Charge. Art ARRO |
Thanks Art, yeah i have sent stuff in to HH before and have had nothing but good service. The servo will head off next Monday......
I had one of those... in the first Viperjet U-boat! [&o]
Ha Nick hope you and the family are doing well. I had one lock up because I was useing A123's with out regulators. It was a old servo. Dan
Even a bent tooth will lock up a gear train. The nearer the bent tooth is to the motor the easier it is to be locked up.
Make sure the pockets the gear pins sit into are not damaged. The gears could move to one side under load and lock when going the other way.
Just wanted to say that I got the servo back today and want to send a huge THANKS to Horizon Hobby and staff! They found a "top case pivot point" worn and swapped it out for no charge!! That is customer service right there, and that is why I have stayed JR all these years..
ORIGINAL: NickC5FE Just wanted to say that I got the servo back today and want to send a huge THANKS to Horizon Hobby and staff! They found a ''top case pivot point'' worn and swapped it out for no charge!! That is customer service right there, and that is why I have stayed JR all these years.. You have 15-25kg high power servos relying on a pin going into a plastic hole, servos of this power should be using alum cases. |
