RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   RC Jets (http://www.rcuniverse.com/forum/rc-jets-120/)
-   -   DX18 Binding Problem (http://www.rcuniverse.com/forum/rc-jets-120/11404978-dx18-binding-problem.html)
never-enuff 02-10-2013 03:03 PM
Hey guys, well with all the good advise I received I could hardly wait to go pick the 18 up. I had a R1221 already in the F16 I am working on so I just bound the new 18 to that receiver and worked perfectly. Then I decided to add some extra goodies to the jet such as canopy and lock, probably just because that new receiver that came with the radio and the expansion receiver that I picked up also was just setting there. So when I tried to bind the new receiver I got only a glitch of light on the receiver when I plugged the battery into it. I can not get a flashing light and I do have the bind plug in. Yet when I try the receiver I took our it binds fine. Bad receiver? I don't know. I will take it back to the hobby shop tomorrow and check it with another one just to see. Any insight is greatly appreciated. Thanks
Thommo 02-10-2013 03:14 PM
RE: DX18 Binding Problem
I had a similar experience with my 18 turned out to be low battery voltage.
never-enuff 02-10-2013 03:37 PM
I checked battery voltage 6.77 volts.
madmodelman 02-10-2013 04:06 PM
Your rx is shot, send it to Horizon and they should replace it.
George 02-10-2013 05:11 PM
I'm not sure how the 18 works (haven't played with it yet), but are you trying to bind a DSMX Rx with the Tx set to DSM2? I saw this the other day with a DX8 and it turned out the wrong "modulation" was set in the Tx and wouldn't bind with the Rx until it was changed.
Isn't the R1221 DSM2 and the Rx that comes with the 18 DSMX?
Just a thought.
Dr Honda 02-10-2013 05:12 PM
Do you have all the Satellite Rx units plugged in? Some of the Rx's will run with one Sat... but I think the 12xxx needs all 4 plugged in.
yeahbaby 02-10-2013 05:30 PM
Could be a bad rx but I had something similar happen with only one satellite blinking.....I moved the transmitter a little farther away and it worked fine.
Try this, Turn everything off, insert bind plug, turn rx on, turn transmitter on with bind button.
I think the manual says something about transmitter being too close may effect binding
never-enuff 02-10-2013 05:43 PM
I've tried each of your suggestions but still no go.
Dustin Buescher 02-10-2013 05:46 PM
Post a photo of your connections with bind plug.
never-enuff 02-10-2013 05:55 PM
Dustin I will do it tomorrow if we don't get it figured out. I've left my shop for the night. But I have the bind plug in the bind data port and batt in the batt port with negative facing to the outside. I've tried the battery in any open slot as the manual said but doesn't change anything.
never-enuff 02-10-2013 06:32 PM
George its supposed to be compatible with both? Thanks
never-enuff 02-10-2013 06:39 PM
And to add to that, it switches on its own from what I can tell.
George 02-10-2013 06:43 PM
Quote:
ORIGINAL: never-enuff
Yeah,
I'm not sure on the 18, but I just saw the non-binding issue due to DSMX vs. DSM2 with the 8 last week; that's why I brought it up. It might be something to look into.
JimJones1 02-11-2013 12:00 AM
I have had this with a few receivers. Assuming nothing is switched on and then you plug in the receiver to a battery with the bind plug connected if it does not flash rapidly it is a bad RX. Check or try the battery the other way round first which I assume you have done as the markings on the new RX's can be confusing.
This problem has nothing to do with binding. If the RX does not flash continiously when powered up with the Bind plug in and the battery the right way round it is faulty. The TX should be off at this point
madmodelman 02-11-2013 01:02 AM
As I said earlier I'm sure your rx is shot.
It's happened to me a few times, even on an AR7000 which had hundreds of flights, when I finally went to rebind it showed no flashing lights no matter what. Don't waste your time.
Gary.
exfed 02-11-2013 06:01 AM
I recently received a new JR 9 channel rx that would not bind with my 9503 tx. After trying everything I could, I finally attempted the binding process with a different rx battery. I had been using a well charged 5 cell pack. When I replaced it with a 4 cell pack, it binded with no problems. I called Horizon and discussed the issue with their tech reps. They say they haven't heard of this before, but trust me, it happened. The new radio works flawlessly and on the 5 cell pack. Just won't bind....
JimJones1 02-11-2013 10:33 AM
Quote:
ORIGINAL: exfed
Interesting that one as I use an old 5 cell pack (6v) to bind all my receivers
luv2flyrc 02-11-2013 12:28 PM
Assuming this is a power safe receiver, remove the soft switch. Install bind plug, attach batteries, that should put receiver in bind mode.
Mike
uncljoe 02-11-2013 01:16 PM
Try another bind plug making sure that is seated.. (had your identical problem, swapped the bind plug ..Presto now works ...
Semper Fi ,Mac
Joe
Rob2160 02-11-2013 02:27 PM
Some things to try...
1. is the Bind plug in the correct port?   I had two identical JR receivers, and one binds perfectly with bind plug in the marked bind port.. the 2nd RX did exactly what you described if I put the bind plug in the marked port.. It turned out that the actual bind port was on the oppostive end of the ports and using this position (incorrectly marked on RX) worked perfectly..
2. correct polarity of the Battery on the RX?
3. DSMX or DSM2 modulation set in your radio?  It won't actually make a difference because the RX will / should bind either way.. but select DSMX because it is a better protocol ..   ( whatever your TX is set to will not affect the RX flashing in bind mode)
HOpe that helps.. Please post if you fix the problem.. just out of curiosity..
</p>
never-enuff 02-11-2013 02:34 PM
Ok guys, embarrassing to say but the problem was I had the bind plug in the wrong port. I looked at it again and thought I would try it in another port and presto! The 9020 receiver is very unclear the way it's marked. Thanks for all the info. This is a great thread I've learned a lot more than what my original post was about.
madmodelman 02-11-2013 03:12 PM
I just don't believe I'm reading this.
BaldEagel 02-11-2013 03:46 PM
That's nothing have a look at this thread: http://www.rcuniverse.com/forum/m_11403527/tm.htm
Mike
George 02-11-2013 04:17 PM
Quote:
ORIGINAL: George
I'm not sure how the 18 works (haven't played with it yet), but are you trying to bind a DSMX Rx with the Tx set to DSM2? I saw this the other day with a DX8 and it turned out the wrong ''modulation'' was set in the Tx and wouldn't bind with the Rx until it was changed.
Just a thought.
I have to correct my post above^^^
It was NOT that the rx wouldn't bind, it was the fact that it wouldn't work the controls when set to DSMX.
I just wanted to make that clear, Sorry!
Rob2160 02-11-2013 04:49 PM
Great to hear it worked.. I guess the bind position on some JR RX is incorrectly labelled.. one of minedefinately is.. .
