Futaba splines on hitec servos
Why have hitec HS-8380TH servos have futaba splines, is this a move by futaba to buy out hitec ?
RE: Futaba splines on hitec servos
Yep just counted the splines on futaba, jr, spektrum, hitec
Futaba 25T JR. 23T Hitec. 24T Spektrum 23T HS-8380TH 25T |
Hitec website confirms that they are Futaba compatible.
http://www.hitecrcd.com/products/ser...s-83680th.html |
move to consistency within the industry.....the 8000 series will be spline compatable with a large number of other servos making them a viable upgrade particularly to the surface crowd who have constraints of specialized OEM steering lingages.....and, incidently, a huge market for servos..... They buy a lot more servos than us airplane guys......
well what are JR and Airtronics planning on doing? Also if this has a move to consistency, then other manufacturers should also adopt futaba style Plugs with the J to avoid putting the servo in the wrong way.
If you look close on the Hitec link Siclick33 provided it says :
"Note: Due to it's ultra narrow dead band this servo is not recommended for aircraft use.".... Are you guys using these in Jets ?? Danno |
