BVM - SABRE 63 " - Exhaust Pipes
Hello everybody, Could someone pass me the exact measurements of the two EXHAUST PIPES ( DOUBLE STAINLESS STEEL TAIL PIPE ) for BVM SABRE - 63 "; length and width of the two ends of the two pipes .
So could ask for TAMJETS do to me! Thanks, Math PLEASE, SOMEONE COULD HELP ME? |
Is that the original kit built Sabre which can be converted to turbine?
John. |
Originally Posted by Math
(Post 12200071)
So could ask for TAMJETS do to me! Thanks, Math PLEASE, SOMEONE COULD HELP ME? I can get the exhaust end measurements if you need them, but have no plans to pull the turbine out to get at the front.... Hope that is of some help to you... |
Hi Wayne22,
If you can pass the measures I thank you. |
At the exhaust end, the inner pipe is 2-5/8" diameter....the outer pipe is 3" dia. Sorry I can't get any other measurements.....
