Smoke oil?
https://cimg5.ibsrv.net/gimg/www.rcu...38cd390488.png
https://cimg7.ibsrv.net/gimg/www.rcu...635831b9a0.png Has anyone used the Aeroshell smoke oil? According to them, it is good for rc applications. what are you using now. |
1 quart baby oil and 1 gallon of diesel. 80-90% as good as smoke oil and 25% the cost. |
Thanks for the video, I will consider it.
https://cimg0.ibsrv.net/gimg/www.rcu...16daaba835.png
Has anyone used the oil from B & B. |
https://cimg1.ibsrv.net/gimg/www.rcu...ee5e16ba86.png
Originally Posted by why_fly_high
(Post 12537091)
1 quart baby oil and 1 gallon of diesel. 80-90% as good as smoke oil and 25% the cost. https://youtu.be/okFOFSXO8UQ |
report back..... :)
I will, since the KC has 60 oz of capacity for smoke then this will be a good solution to have it at any time for a reasonable price.
I've been using 1 gallon of mineral oil from the feed store to one gallon diesel... Works great
I found a case of the Bennett's Best in the garage. It's probably fifteenth or twenty years old and cost about $8 a gallon back then. I put a half of a tank in my T-One which has a cheap pump out my foamie Super Viper and no hopper to see if it was still good. |
Originally Posted by CARS II
(Post 12537095)
I wilĺ try your formula, found this B oil, 80 oz for $10.
Thanks! |
Not yet, will do that in 3 to 4 weeks.
Originally Posted by T3chDad
(Post 12546147)
Have you tried this yet? How did it work?
Thanks! Checking the density of the smoke, a mix of 1 gallon of Diesel + 1 qrt of mineral oil, $8.00 per gallon. I may have to increase the pumps speed, it is at its slowest rpms. |
https://cimg1.ibsrv.net/gimg/www.rcu...5c84d870e1.png
I used this oil from the Wally store. |
I think I will be using this mix from now on, specially because the ingredients are easy to get locally.
A big thanks to Why fly high and desertlakesflying for the tip. |
Thank you so much. Looks great to me!
Agreed. Add a tiny bit of algiecide to the can to prevent its growth.
Here is my Boomerang XL having a taste of the new smoke cocktail :)
I also tested it during a flight, it looks as thick as the super dry fluid, no diferinces that I could see, I wish one of the guys watching the flight had filmed it, but they were too busy watching the jet fly |
https://cimg8.ibsrv.net/gimg/www.rcu...b56b01c577.jpg
Left the flying field a little late. |
(Post 12551041)
I also tested it during a flight, it looks as thick as the super dry fluid, no diferinces that I could see, I wish one of the guys watching the flight had filmed it, but they were too busy watching the jet fly https://youtu.be/OuhyAfSWRQg |
That's why I did the vid on the ground, see the column of smoke floating away. I'm Terran :) |
Cars II, which pump are you using? |
I will take some vids tomorrow!
Rick, the pump in my Boomer is a TamJets pump, around 12 years old, the pump in the KingCat is also a TamJets pump also around 12 to 15 years old.
https://cimg3.ibsrv.net/gimg/www.rcu...73182ca541.jpg
Thanks Raffy, I have the mineral oil your requested :) |
https://cimg2.ibsrv.net/gimg/www.rcu...f016b2db3a.png
One last post from me for this thread. For those that wanted to see the smoke trails, this is my Boomerang XL smoking. |
