RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   RC Jets (http://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Need help with B-2 Project (http://www.rcuniverse.com/forum/rc-jets-120/1976901-need-help-b-2-project.html)
Rodmunch 07-09-2004 11:36 PM
1 Attachment(s)
This is the first model pulled from my mold. I am going to set it up for slope soring first. This airframe is 100% scale. Any Ideas on where the CG is???? It has a 93 inch wingspan. I am trying sloap soring first to make sure she flies.
Terry Holston 07-10-2004 06:41 PM
RE: Need help with B-2 Project
Maybe you could see what the CG is on one of the New GWS electric B-2s, that might be a starting point for your Slope Soarer. Just a thought.........;):D
jetflyr 07-10-2004 09:57 PM
Quote:
ORIGINAL: Rodmunch
You might want to contact Bob Parks who runs the RC-Jets list. He and Ivan Munninghoff went through the process for Ivan's big B-2.
Greg
wojtek 07-10-2004 10:37 PM
cool, ! what are you doing about yaw controll ??? are you using split drag tupe devices for rudders like the real one ??
Wojtek
Rodmunch 07-10-2004 11:44 PM
Yes on the yaw axes with a gyro, this thing will fit wren 44's, if everything works out should be pretty cool.
thanx everyone for the replies.
Just want to make sure she flies before I invest to much.
HORNETONE 07-11-2004 12:31 AM
Cool project .......... Send me your email address and I will forward some of the very helpful links ,also if you could send all the dimensions , weight and airfoils I might be able to help you out with the first initial C.G as I'm working on the process of a drawing on a bigger scale of which wingspan is about 123in.
Sonny !
