RE: To Gyro or not to Gyro?
Hi.
It doesn't feel nose heavy in flight other than the rotation is a bit quick. I think that it would be able to rotate and take off much earlier if it had a more rearward CG. I have balanced it at 133 mm / 5-1/4" according to the recommendation from the manufacturer (Tamjet). I will try experimenting with moving the CG back a little. ORIGINAL: Craig B. Hi tahustvedt, Sounds to me like you have a nose heavy aircraft. My 2 1/8 F16 rotate that smothly you would probably be unable to pick the point at which the model left the ground, but my c of g (skymaster F16's) is at 175mm ("recommended" is around 140!) My model flies beautifully right way up and inverted, rotates and lands well. Where is your c of g and how are you measuring it? Mine has been measured accurate to a mm using a suspension jig. The gyro won't be able to compensate for what may be a fundamental problem with the setup. As an aside, a fellow very experienced jet modeller just did some calculations using a aerofoil program on the correct c of g for our F16's.....guess what the majic number was? 176mm! 140mm puts the c of g on the leading edge at the MAC, ludicrous! Gyro won't fix that, especially in rate mode. Hope that helps, Hi David, thanks for your input. Regards, Craig. |
Check to be sure your aircraft isn´t sitting at negative incidence either. That will cause the nose to "pop" up as you rotate as well. 0 or even +1 degree is best.
Hi,
one question: When you use a gyro on nose gear (for take off and landing) you use Heading lock mode or normal mode? For take off no problem i think in HH, but for landing... during flight, gyros is desactivate and you don't know the direction lock by the gyro during retract and activation for landing... I have kust tested normal model on my F15 skymaster nose (gyro ASSAN G410, cheap and well) Regards, Sébastien |
ORIGINAL: autorot Hi, one question: When you use a gyro on nose gear (for take off and landing) you use Heading lock mode or normal mode? For take off no problem i think in HH, but for landing... during flight, gyros is desactivate and you don't know the direction lock by the gyro during retract and activation for landing... I have kust tested normal model on my F15 skymaster nose (gyro ASSAN G410, cheap and well) Regards, Sébastien |
yes with gyro on elevator or rudder or aileron, but with the gear nose i think it's different.
for example: If i switch in HH mode or activate gyro before landing , the gyro lock a cap but the plane will change is direction (last virage/ correction..etc) so when the nose gear touch the runway, the wheel will not be centered! Another example: With HH during take off, no problem. i retract the gear with gyro activate and for landing same problem, i don't know what cap keeps the gyro! so the nose will be not centered for landing... you unterstand my example? Regards, Sébastien |
1 Attachment(s)
Raf,
The JR G410T Tail Lock Gyro is no longer availble. What JR Gyro out now do you think best replaces it. Thanks, Wayne This description of the 410 describes what I am looking for the nose wheel. JR G410T Tail Lock Gyro: Great for beginners and intermediate pilots. Not only is the G410T unbelievably easy to use and inexpensive, it is also extremely compact. |
