RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Graupner Inspiration build thread-Flown (https://www.rcuniverse.com/forum/rc-jets-120/9218127-graupner-inspiration-build-thread-flown.html)
Dave Wilshere 10-31-2009 03:55 PM
1 Attachment(s)
Hopefully the others building this will chip in, but the bench is clear and it's time to start...
Unusually for a Graupner kit the manual is ready, multi language and colour pixs!
Servo choice seems to be full size on everything except elevators (3301/3328) I will probably go JR3401 and make side mounts.
8231/8411 on everything except nose steering where I'll use my usual JR 579. Nose steering servo is inverted to allow Y lead.
Bye Pass ducting is limiting turbine dia to less than 100mm turbines. I'm going P70 if the ducting allows the length. Tail pipe will suit any P60-70, G80/90 and Super Sport, Merlin 90 etc.
Tanks look small, but I filled one with water in the office and they are over 1 ltr each.
Looking at wing last week, the wheels need off-set to miss wing sculpting to clear turbine-will know more when I start that bit! The kit is designed around Harpoon trailing link legs. AT, Behotec or Eurokit retracts should fit.
Nose removes with two screws only.
Thats it till I get the kit home tomorrow.
Dave W
trevor Skedge 10-31-2009 05:39 PM
RE: Graupner Inspiration build thread-Flown
Dave,
Looking forward to picking up my kit on Monday and hope to start mine this week too. just looking at the above page the build should be very straight forward.
Trevor Skedge.
Bob_B 10-31-2009 07:06 PM
Dave,
Looks good, watching with interest.
Bob
BaldEagel 11-01-2009 12:11 PM
Dave et all
I think a build thread is so much easier to read if comments can be kept to a minimum so that the thread contains only relevant build information.
Trying to be helpful.
Mike
Dave Wilshere 11-01-2009 12:36 PM
Mike
I fear for your wish...;)
I have the tailplane infront of me, looks like the JR3401 will fit with Graupner 3893.20 side mounts
Dave
Dave Wilshere 11-01-2009 12:44 PM
1 Attachment(s)
Tail set up
digitech 11-01-2009 02:07 PM
need a light gear for that?:D
Ragz 11-02-2009 01:32 AM
how much does this plane cost? go fly price? less vat.
Dave Wilshere 11-02-2009 02:56 AM
Anurag
UK price £1913 is less VAT Kit, Gear, Trailing link legs and ball-raced wheels with brakes.
Dave
steverobertsuk 11-02-2009 05:53 AM
Dave & Trev
Weather forecast is looking good for Saturday morning............ will you both live up to your promise that they will be finished ;-)
Who will win the build race????
Steve
trevor Skedge 11-02-2009 11:11 AM
Stevie,
Not trying to turn this into a mission are you? Excuse me I have to go now.
Trevor Skedge.
steverobertsuk 11-02-2009 12:09 PM
Trev
Urrr no ;) just a friendly contest!!
Steve
Dave Wilshere 11-02-2009 12:10 PM
Stevie
It is my intention to show I (again) can build a jet in less than a week. Trevor picked up his kit today, we looked at it a bit more and noticed several details missed on my initial look.
Rudder servo slot started in fin...nice
All servo mounting holes drilled...nice
Aileron servo mount fixed in wing, wood parts only need finishing to install servos...nice
Fuel tank mount fixing pre installed...nice
Just coating wood in epoxy now...then it begins, after fencing!
If only we could get the canopy glass installed it would be brilliant!!
I think it's possible even for two duffers to get it done...maybe for Sunday
D
PS Luke is collecting his too!
Dave Wilshere 11-02-2009 04:33 PM
1 Attachment(s)
OK
Elevator servos in.
The mounts are Hysol glued to the top skin as the foot print is reasonable. Would have liked a ply spreader but tail is too thin for this.
Keep the servo towards the back of the opening as full down takes the arm well forward.
Dw
Dave Wilshere 11-03-2009 06:04 PM
1 Attachment(s)
Not much achieved tonight, most of my family are pretending to be ill so I have to nurse them!
Canopy glass fits well, aileron servo mounts assembled, ready to screw into factory mounts
Tank bungs started, I've added Dubro barbs for a good seal.
Dw
trevor Skedge 11-04-2009 03:04 AM
Dave,
Looks like yours is coming along nicely. I have made some progress and will post up a few pics later but it always seems difficult to take pics during a speed build:). Once you start building this airframe it is clear the extra money for this kit is in the detail like the clever use of rectangular slots to mount the extension leads for the tailplane servos and all the servo mounting plates are pre-drilled. Canopy base is completely pre-fitted which for me saves a huge amount of time and that's important for. Unfortunately I am busy for most of the day so doubt I will get much done however can see that without distractions this kit is an easy week to complete and the most pre-fab model I have done yet.
Trevor Skedge.
steverobertsuk 11-04-2009 04:36 AM
Trev
Looks like Dave is doing ok with his so you'll have to come to the patch and fly his one at the weekend ;)
Steve
Dave Wilshere 11-04-2009 05:05 AM
If its done it's a free for all...except crasher Simon
DominicM 11-04-2009 07:48 AM
Dave - Would be interesting to know if the Inspiration would suit EDF conversion. Would 120mm fans or the new larger DS94HST (135mm OD) fit?
Dave Wilshere 11-04-2009 12:34 PM
Not with the inlet tracks supplied. I think the inlet size is OK, but the sleeves reduce for the turbine tank system, the tail outlet could be 100mm (4") so plenty of scope. It is light the wing from the box is 1227gram (about 43 oz)
If you could mould foam inlets then yes.
Dave
DominicM 11-04-2009 01:21 PM
Thanks Dave. Having to bespoke intakes is a given with most turbine airframes it seems. I saw from your earlier post that the fuel tanks were already installed but I presume they would come out easy enough. Unfortunatley, the DS94HST needs 11cm diameter at the end of the thrust tube. Thanks again. Look forward to seeing yours fly on video.
Dave Wilshere 11-04-2009 02:17 PM
Not installed, just installation points installed!
You could shortern the tail cone and gain dia.
regards
Dave
trevor Skedge 11-04-2009 03:55 PM
Steve,
What are you trying to say?[sm=punching.gif]
Trevor Skedge.
Colin Gontier 11-04-2009 04:03 PM
ORIGINAL: Dave Wilshere
IF? Thats not the sort of attitude that wins prizeshttp://www.rcuniverse.com/forum/js/f.../msn/72_72.gif
Put me down on the list for a flight on Saturday then - Iwill bring my own fuel ! and latte fuel as well as you will obviously be staying up all night Friday to finish.
and Trevor make sure you don't let the side down - don't let Dave kid you that he's not progressing - its all smokescreen !
<br type="_moz" />
Dave Wilshere 11-04-2009 04:15 PM
1 Attachment(s)
I've hardly touched it all day being so busy at work ;)
Only completed one tank since coming home, strangley last night she was ill, now she is at the Theatre!? go figure
D
